Alternator install tips? - BMW Luxury Touring Community
post #1 of 6 Old Jun 5th, 2014, 4:31 pm Thread Starter
GBarnes's Avatar
OK, do any of you have any tips on how to line up the slots in the rubber cushions when installing the alternator?
TIA
GB
George Barnes
'06 K1200LT
'01 K1200LT, totaled with 180,000 miles, 10/18/07,
'97, '99, '01, '05, '07 & '09 Iron Butt Rallies, (won the '99)
IBA#146
GBarnes is offline
post #2 of 6 Old Jun 5th, 2014, 7:16 pm
Re: Alternator install tips?
It is a lot easier if they are new. But the old ones will be fine if they are not deformed. Place them in the alternator side and spray a little lube where they need to mate with the drive flange and it should slide right on. Try it dry - be there all day trying. Just use a little tire lube or silicone spray on them. Just tried it on my spare and no go dry, but popped right in with the lube.
ID:	57905   Click image for larger version
ID:	57913   Click image for larger version
ID:	57921   Click image for larger version
post #3 of 6 Old Jun 5th, 2014, 8:18 pm
K100Dennis's Avatar
Yep, and if the "monkey nuts" are no longer connected, i.e. 6 separate rubber blocks instead of 3 pairs, simply position them in the housing using silicone (silastic), allow time to set then assemble. Works fine, you're only holding them captive till the coupling is assembled. And detergent applied to the rubber is ok as well, if you don't have the silicone spray. HTH
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #4 of 6 Old Jun 5th, 2014, 11:40 pm Thread Starter
GBarnes's Avatar
Thanks guys, I'll try the lube.
BTW, Jerry, the rubber cushions don't seem to be installed in the drive housing correctly in the photos. Are they just in that way to show the lube process?
GB
George Barnes
'06 K1200LT
IBA#146
GBarnes is offline
post #5 of 6 Old Jun 6th, 2014, 6:09 am
K100Dennis's Avatar
They look to be installed correctly to me George. The alternator drive coupling lugs on the engine side need to slide in between the ends of each pair of rubber blocks, not in the centre of each pair as that would cause metal/metal contact between the coupling drive lugs. HTH.
Dennis
1987 Yamaha TY250R
post #6 of 6 Old Jun 6th, 2014, 7:58 am
They will work either way, I just find it easier this way. It seems to hold them better.
Offbeat Tips and Tricks for RT people hopz RT Series 87 Jun 11th, 2012 7:05 am
2004LT Brake pump install....advice or tips please.... loser K1200LT 1 Sep 28th, 2011 12:36 pm
Tips On Pumping Gas nelson61 Chit Chat 4 Mar 23rd, 2008 9:06 am
Holiday Eating Tips jkersh1 Humor 6 Dec 19th, 2006 8:15 pm
