Initial Setting For Ohlins Rear - BMW Luxury Touring Community
post #1 of 6 Old Jun 2nd, 2014, 9:09 pm Thread Starter
Dragonwing's Avatar
So the PO was kind enough to do some upgrades to the LT before I acquired her, and that included an Ohlins rear shock. I noticed that there are no markings--just a very light center detent. To you Ohlins owners out there: If you're a dainty 225 as I am, where do you have your shock set.....like in terms if turns left or right past center, or turns off of full hard or soft? Yeah, yeah, I know I have to toy with it, but I'm looking for a starting point used by similarly weighted riders, since, without any instrux, I'm shooting in the dark here. Thanks!
DW
"A severed foot is the ultimate stocking stuffer."
BMW K1200LT "Carpathia"
Suzuki GV1400 Cavalcade "Paladin"
Kawasaki ZX14 Ninja "Shashka"
Kawasaki GPz1100 "Sicarius"
Buell S3 "Pazuzu"
Honda GL1100 Gold Wing "Aurore"
Honda PC800 Pacific Coast "Octavia"
Honda CB750F "Genvieve"
And other remnants of a misspent youth.
Dragonwing is offline
post #2 of 6 Old Jun 2nd, 2014, 11:27 pm
Re: Initial Setting For Ohlins Rear
If you are talking pre-load then you want the suspension in the center of its travel with you sitting on it. So you will have to do some measuring.
If you are talking about the rebound damping (little black knob on the lower shaft) I run mine about 25 clicks from full clockwise.
post #3 of 6 Old Jun 2nd, 2014, 11:37 pm Thread Starter
Dragonwing's Avatar
What about compression damping via the knob on the remote reservoir?
DW
Buell S3 "Pazuzu"
post #4 of 6 Old Jun 3rd, 2014, 6:28 am
That is not a damping adjuster. It is a preload adjuster for the rear spring to control ride height when loaded heavily.
post #5 of 6 Old Jun 3rd, 2014, 7:02 am
murray's Avatar
DW first off consider purchasing a Ohlins front shock if not the F & R will never be balanced. Certainly try the suggested preload and R dampening settings others suggested. Also inspect the shock spring for its rating . Then consult Kyle Racing to see if you have the correct spring. How many miles are on the Bike front shock and Ohlins Shock. FYI if the stock front shock has over 25 K on it you are due to replace. Let us know where you are at.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #6 of 6 Old Jun 3rd, 2014, 9:33 am Thread Starter
Dragonwing's Avatar
Murray: Absolutely refuse to shell out that kind of dough for a front shock. And, since the weak link in the front suspension is the stock spring, and not so much the shock, I found a 6000 mile stock assembly for $30, paid a similar amount for a brand new Ohlins 485# front spring, paid a suspension shop $20 to swap out the Ohlins for the stocker, reinstalled everything, and saved myself several hundred dollars. I'm 'balanced' enough. Now, to get those rear settings.....
DW
Buell S3 "Pazuzu"
Tires-Avon Storm 2 Ultra Rear on 05LT dualbmw K1200LT 20 Aug 15th, 2013 8:32 pm
Another Rear Drive Bites the Dust - Question lad K1200LT 63 Jul 19th, 2013 1:34 pm
Can I make it home with oil on the rear wheel av8trto K1200LT 23 Jun 25th, 2011 1:54 pm
Thought I had blew by rear drive slmorley K1200LT 2 Oct 29th, 2010 11:51 am
Rear Brake Seizure kapod2t K1200/1300GT (The Next Generation) 13 May 4th, 2010 10:44 am
