ABS Module from K1200S on a K1200LT - BMW Luxury Touring Community
post #1 of 5 Old Jun 2nd, 2014, 3:00 pm Thread Starter
I need a replacement ABS module for my 2006 K1200LT and have found a module from a 2006 K1200S. Visually they look identical, but I'm wondering if there are differences in the pressures or logic that would make them non interchangeable. Does anyone happen to have any experience?
pricebri is offline
post #2 of 5 Old Jun 2nd, 2014, 3:32 pm
Dragonwing's Avatar
Re: ABS Module from K1200S on a K1200LT
They may look identical, but I suggest that you match up the part numbers--ALL the part numbers--to be doubly sure. But you knew that, right?
DW
"A severed foot is the ultimate stocking stuffer."
BMW K1200LT "Carpathia"
Suzuki GV1400 Cavalcade "Paladin"
Kawasaki ZX14 Ninja "Shashka"
Kawasaki GPz1100 "Sicarius"
Buell S3 "Pazuzu"
Honda GL1100 Gold Wing "Aurore"
Honda PC800 Pacific Coast "Octavia"
Honda CB750F "Genvieve"
And other remnants of a misspent youth.
Dragonwing is offline
post #3 of 5 Old Jun 2nd, 2014, 5:06 pm Thread Starter
Part numbers are different, hence my question. I'm guessing it is not compatible, but with the availability of the modules and the price of new units from BMW I'm looking for an alternative solution other than bypass and go with regular hydraulic brakes.
pricebri is offline
post #4 of 5 Old Jun 2nd, 2014, 7:35 pm
Dragonwing's Avatar
You're probably correct in your assumption, but, if the fittings and the wiring are all in the same places, and you DO decide to try it, and it works.....you will be dubbed Hero of the Day! No, really!
Good luck!
DW
Buell S3 "Pazuzu"
post #5 of 5 Old Jun 2nd, 2014, 8:12 pm
If you want it for parts I am sure the pump motors are identical but the diameter of the metering ports and other pistons as well as the firmware in the "brain" are most likely different. Just like an "S" tranny will not work on an LT.
Didn't make it back home - anybody got a spare ABS module? N5PN Curve Cowboy Reunion 15 Sep 11th, 2011 8:49 pm
ABS Failure K1200LT sglover005 K1200LT 3 Mar 1st, 2011 9:38 pm
More ABS headache... pozo_izquierdo K1200LT 9 Jun 26th, 2007 11:20 am
