'05 LT Center Stand not working - BMW Luxury Touring Community
post #1 of 16 Old Jun 2nd, 2014, 3:19 am Thread Starter
After the awesome response from my previous thread (http://www.bmwlt.com/forums/showthread.php?t=100625), I hope someone can help me out with the next problem.
As stated in the previous thread, the center stand on the LT is no longer working after I replaced the clutch. It was functional before I started.
It is at the moment standing on the side stand. Depressing the center stand button results in the stand light flashing on the instrument cluster but nothing happens other than that.
What other switch have I broken off?
Jughead is offline
post #2 of 16 Old Jun 2nd, 2014, 7:14 am
Re: '05 LT Center Stand not working
I'll bet JZ will know...
post #3 of 16 Old Jun 2nd, 2014, 9:24 am
+1.
post #4 of 16 Old Jun 2nd, 2014, 7:55 pm
so, was this fixed in your other post?
http://www.bmwlt.com/forums/showpost...9&postcount=15
post #5 of 16 Old Jun 2nd, 2014, 8:09 pm
OK I'll see if I can live up to your expectations.
To remove the tranny you pull the center/side stand carriage. On the carriage is a limit switch (magnetic) and harness that detects when the stand is deployed. But before you check that the center stand actuator will only deploy if the following is true:
1. Side stand up
2. Bike in neutral (not in reverse either)
3. Brakes released
4. Bike is relatively level (yes there is a sensor).
post #6 of 16 Old Jun 3rd, 2014, 12:16 am Thread Starter
Starting issue was resolved, center stand issue not. Thus the new post.
Jughead is offline
post #7 of 16 Old Jun 3rd, 2014, 12:18 am Thread Starter
1. Side stand up
3. Brakes released
Thanks John
Yes, all 4 conditions are as above. Is there any way to test the limit switch or even to bypass it for now just to take it out of the equation?
Jughead is offline
post #8 of 16 Old Jun 3rd, 2014, 12:23 am
The EHCS is also tied into the brake lights system, as John mentioned (brakes released).... if a brake globe is out or faulty it will cause the same effect... just another thing to check.
post #9 of 16 Old Jun 3rd, 2014, 12:34 am Thread Starter
Ahhh. I have the rear panel with the tail light out as I still need to fit a new rear tyre. Will plug it back in and check again.
Jughead is offline
post #10 of 16 Old Jun 3rd, 2014, 12:37 am
Man the stuff people know here is amazing..who would have thought that the center stand would not work without a tail light bulb. Prolly is his problem.
Dave1955 is offline
post #11 of 16 Old Jun 3rd, 2014, 12:48 am
Its one I personally suffered and it took quite some time to figure it out... I'd replaced a dead globe with a "faulty" globe, which seemed to function properly but it took out the EHCS.
post #12 of 16 Old Jun 3rd, 2014, 2:23 am Thread Starter
Yeah, who would have thought. Well, you guyz rock!!
Plugged the rear light arrangement back in and BINGO!!! Center stand working!!
Jughead is offline
post #13 of 16 Old Jun 3rd, 2014, 2:24 am
nice.
post #14 of 16 Old Jun 3rd, 2014, 12:50 pm
John Z wrote:
1. Side stand up
3. Brakes released
I know John is right but...
I regularly use reverse to hold the bike in place on a slope where I can't hold the bike still w/o the brakes to put it on the center stand. Read the method on the forum many years ago. Did it this morning.
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #15 of 16 Old Jun 3rd, 2014, 6:11 pm
Foiler's Avatar
Best Forums on the Interweb
Foiler is offline
post #16 of 16 Old Jun 3rd, 2014, 8:06 pm
Originally Posted by alabrew View Post
John Z wrote:
1. Side stand up
3. Brakes released
Good to know. It is not in the manual and I assumed it to be the case. Thanks.
Center Stand evomind RT Series 34 Jun 18th, 2014 5:25 pm
Center Stand Lifting Helper saddleman K1200LT 6 Jul 29th, 2013 12:00 pm
Evaporative Cooling Vest Instruction wa1200lt K1200LT 1 Jul 24th, 2010 6:51 pm
2002 Model Center Stand Broke MattKas K1200LT 7 Nov 6th, 2006 1:37 pm
Center Stand Lubrication for Pre 2005 MattKas K1200LT 9 Oct 19th, 2006 1:16 pm
