Has anyone had a front master cylinder failure? - BMW Luxury Touring Community
post #1 of 27 Old Jun 1st, 2014, 5:27 pm Thread Starter
zippy_gg's Avatar
Question Has anyone had a front master cylinder failure?
and how do you troubleshoot?
I am bleeding the brake system on the 05 as I have done in the past and following the instructions from John Zeiler's DVD.
Lately the front brake handle was getting spongier and spongier and the brakes were no longer the brakes I used to have. I am now riding the RT.
While doing maintenance work I found a leaky front fork tube, worn out brake pads and dried up original brake lines. I replaced the fork seal, front pads, and multiple brake lines.
While going through the bleeding procedure I found that the front lever does not come back, or comes back very slowly when the bleed valve is shut. If I pump quite a bit it eventually come back to its original position and firm. There are no air bubbles coming out of the bleed valve, and the level in the MC reservoir was normal and never low.
While waiting for an answer or advice on this I am going back to the garage to finish the bleeding on the other 3 circuits.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #2 of 27 Old Jun 1st, 2014, 5:53 pm
Scouter-50's Avatar
Re: Has anyone had a front master cylinder failure?
Not that I know, but is the small hole that usually squirts fluid on the paint open?
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #3 of 27 Old Jun 1st, 2014, 6:00 pm
I don't have an '05 but isn't the front master a different circuit than the bleed on the front calipers?
I think that there is another bleed valve just for the front master cylinder .
Jack
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #4 of 27 Old Jun 1st, 2014, 6:02 pm Thread Starter
zippy_gg's Avatar
Robert
It sure is and tried very hard to do just that...
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #5 of 27 Old Jun 1st, 2014, 6:04 pm Thread Starter
zippy_gg's Avatar
Jack
Yes it is a different circuit. But if the control circuit has an issue it won't send the correct signal to the electronics and braking is affected.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #6 of 27 Old Jun 1st, 2014, 6:37 pm
Gilles,
I have found a few that would be slow to return on a full stroke. That usually means you are getting the piston into an area it seldom sees and there could be corrosion in that end of the cylinder. Best to not use a full stroke in that case. Try it again with short strokes and see if that doesn't clear it up. Also try pushing fluid up to the reservoir from the ABS unit. That usually gets a stubborn air pocket out.
post #7 of 27 Old Jun 1st, 2014, 7:03 pm
I had one do that on either the K100 or K11, do not remember which, got new piston kit from beemerboneyard
Yours seems kind of new for it to be bad but anything can fail
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is online now
post #8 of 27 Old Jun 1st, 2014, 7:26 pm Thread Starter
zippy_gg's Avatar
Originally Posted by jzeiler View Post
Gilles,
Thanks John, I'll try pushing fluid up.
The rear control and wheel circuits went fine.
Now moving to the front wheel circuit, then try your suggestion.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #9 of 27 Old Jun 1st, 2014, 7:27 pm Thread Starter
zippy_gg's Avatar
I was very surprised to have an issue as I don't recall anyone mentioning a problem with the MC.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #10 of 27 Old Jun 1st, 2014, 8:44 pm
You could be the first LT needing one - something new to complain about
The one I had fail was pretty dirty in the bore on the outside, I ride in the rain, the bore and end of piston were marked up but new piston went in OK and performed fine, no leaks, cleaned up well before inserting new piston.
Beemerboneyard sells a kit for the LT
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
post #11 of 27 Old Jun 2nd, 2014, 9:46 am
pburhoe's Avatar
I recently went to the dealer to have the codes read, they confirmed front servo malfunction. The exact code was 00430B "pressure modulator, front pump"
Although I had an excellent interaction with the dealer (Second Wind BMW, Merrimack NH) the fix is to replace the abs control unit (sometimes referred to as the modulator). Part cost: $2400!!!!!!!!!!!!!!!
I will not be purchasing said control unit, therefore I will become intimately familiar with it as I disassemble and attempt to repair.
"good news" is that this appears to be mechanical, as opposed to electronic, failure...now why do I think that? Not sure.
Tech note says "modulator did not acuate" i guess i will find out!!!!
Peter
2002 K1200LTE (July 4, 2008)-"Dragonfly"
1984 Goldwing Aspencade-"The Mighty Pickle" (think of Arlo Guthrie)
1982 Yamaha Maxim 750-"Little Pickle" (sometimes "Gherkin")
1980 Honda 750 Four-utilitarian, classic
1978 Honda 450 Four-took it apart, couldn't put it back together...
1976 Suzuki GT 250-2 stroke screamer
pburhoe is offline
post #12 of 27 Old Jun 2nd, 2014, 8:43 pm
Good luck as there are two pump/motor units and two pairs of pressure transducers as well as all the little pistons and check balls.
Name:	Control Section Plungers 11.JPG
ID:	57745   Click image for larger version
Name:	Control Wheel Interface 12.JPG
ID:	57753   Click image for larger version
Name:	Control Wheel Interface Valves 14.JPG
ID:	57761   Click image for larger version
Name:	Electronics internal board 6.JPG
ID:	57769   Click image for larger version
Name:	Integration section front 8.JPG
Name:	Motors Exposed 15.JPG
ID:	57785   Click image for larger version
Name:	Solenoids Control Section 9.JPG
ID:	57793   Click image for larger version
Name:	Integration section back 7.JPG
post #13 of 27 Old Jun 3rd, 2014, 2:00 pm Thread Starter
zippy_gg's Avatar
So that's what $2,400 look like...
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #14 of 27 Old Jun 3rd, 2014, 2:32 pm
johnbaker15's Avatar
Not really...for $2400 it comes all in one piece.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #15 of 27 Old Jun 3rd, 2014, 4:58 pm
Enjoy The Ride
saddleman's Avatar
I've had to rebuild one front brake cylinder.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #16 of 27 Old Jun 3rd, 2014, 11:48 pm Thread Starter
zippy_gg's Avatar
That's the way I am going; ordered the kit from beemerboneyard, but vacations will get in the way of getting work done. Dang!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #17 of 27 Old Jun 5th, 2014, 4:42 pm
pburhoe's Avatar
Can you share specifics?
Peter
pburhoe is offline
post #18 of 27 Old Jun 5th, 2014, 5:41 pm
Enjoy The Ride
saddleman's Avatar
I installed the rebuild kit from Beemer Boneyard on a LT . I don't remember why it wasn't my bike.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #19 of 27 Old Jun 7th, 2014, 10:23 pm
jwb4207's Avatar
That would have been my bike. The front master was sticking causing the servo to run with out my knowledge.
jwb4207 is offline
post #20 of 27 Old Jul 9th, 2014, 8:45 pm
jenkinskg's Avatar
My master died last night.
Rode home with only rear brake and downshifting, all the way home from NYC 25 miles.
Any advice about rebuild?
Just ordered kit from beemer boneyard
jenkinskg is offline
post #21 of 27 Old Jul 10th, 2014, 8:09 am
what year bike?
perhaps you have blown rubber brake line, for me hard to imagine a master cylinder would totally fail all of a sudden
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
post #22 of 27 Old Jul 15th, 2014, 2:25 pm
jenkinskg's Avatar
Mine was a 2000 lt
I installed new rebuild kit ( piston with seals complete from BB)
went right in, not sure old was bad
Bled the hell out of system both calipers then abs unit
After that brakes are better than they ever were.
Another trick I learned, one caliper bleed screw was so stuck, flair wrench did not work, was afraid to break it.
Took a 6 point socket and was able to losen it, then I just used that socket to bleed both calipers and abs unit.
Previously using bleeder container did not work as well as using socket and just hold handle, while I tighten the screw.
It did drip fluid around a little but no big deal.
hope this helps
post #23 of 27 Old Jul 17th, 2014, 2:41 pm
deputy5211's Avatar
Gilles, how is the brake project going? Been a while since you posted an update.
Antony (Tripod)
Dallas' Northern Suburbs
and many, many others.
deputy5211 is offline
post #24 of 27 Old Jul 17th, 2014, 8:48 pm
jenkinskg's Avatar
So front now feels pretty good, but I think I need to bleed some last air out, may be a little squishy, maybe hoses?
Now rear feels worse than ever and something started leaking.
Leaks onto exhaust.
Now maybe rear master, maybe when I am done ABS will work?
post #25 of 27 Old Jul 20th, 2014, 11:39 pm Thread Starter
zippy_gg's Avatar
Update on my fix, after several weeks in hiatus due to girls going to college.
I replaced the piston assy on the front master cylinder, started putting things back together and tested the new MC; Good pressure!
But... brake fluid started squirting where the line from the MC connects to the hard line. That was the culprit all along but I had not seen any sign of leaks until today. I now know why I could not effectively bleed that circuit and actually I feel relieved to find it is not the ABS unit.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #26 of 27 Old Jul 22nd, 2014, 5:27 pm
jenkinskg's Avatar
Going to rip brakes lines off of front system tomorrow.
Then Thurs will get new lines made, about $25 each
I can write down lengths and see how it goes, I had a line made before with great results.
If my set goes well could have more made up.
My bike is a 2000
post #27 of 27 Old Jul 22nd, 2014, 5:51 pm Thread Starter
zippy_gg's Avatar
My bike is a 2000
Make sure the new lines are clocked just like the old ones so they will fit correctly and will be long enough. $20 per line is dirt cheap!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
Front master cylinder going south? Family_fun K1200LT 2 Mar 17th, 2011 11:03 pm
49 L Top case lock cylinder question REWDOC Rider's Gear & Luggage 4 Oct 14th, 2009 7:12 am
master cylinder leak gpolakow K1200LT 5 Sep 24th, 2008 1:18 am
Final Drive Failures at 4% rate? hallzee K1200LT 27 Nov 24th, 2007 4:49 pm
now for something different: front fender failure docwagner K1200LT 18 Nov 27th, 2005 5:22 pm
