CENTERSTAND 08 LT - BMW Luxury Touring Community
post #1 of 6 Old May 27th, 2014, 7:23 am Thread Starter
CENTERSTAND 08 LT
Got the Lt out yesterday after waiting for showers to pass, had to shut the shed door, and centerstand inoperable. I was messng with the sidestand earlier, wondering if the switch on sidestand is sticky, causing fault code for centerstand operation.
Bike running, in neutral, no brakes applied, getting fault code on dash...
Can I test sidewsitch by bypassing it to eliminate that switch for diagnostic purposes?? Thanks, Donn
dgfolkmann is offline
post #2 of 6 Old May 27th, 2014, 9:21 pm
Re: CENTERSTAND 08 LT
What are you getting for a "fault" symbol on the dash. The lightening bolt is low voltage, hourglass is overload (but this usually only shows up following repeated lifts) or the "call" symbol which means one of the interlocks is tripped (could be the side stand switch).
In all cases the EHCS symbol light will flash 2 Hz normal, 4 Hz fault.
post #3 of 6 Old May 28th, 2014, 8:13 am Thread Starter
Im getting an "!" on the display....
post #4 of 6 Old May 28th, 2014, 8:47 pm
That would be the "call" symbol described in the manual (I couldn't remember what it looked like). That means either the bike is in gear (or thinks it is), the brakes are applied (or a brake switch is stuck but you would hear the servos) or the side stand switch is buggered. Or the F-R switch is not fully into F. Worth a recheck of the side stand switch if everything else checks out.
post #5 of 6 Old May 29th, 2014, 7:18 am Thread Starter
John, got home from work yesterday, took the LT and ran some errands, stopped to show off the bike to a friend, and the Centerstand now works.
Go Figure.....Oh Well, glad it decided to work.
Thanks for Your input, much appreciated.
Happy Trails, Donn
post #6 of 6 Old Jun 3rd, 2014, 11:56 am
bmwbagby's Avatar
It's possible the bike was thinking it wasn't on level ground when it wouldn't work OR the hydraulic center stand actuator might be going out. (unfortunately I know this from experience)
Jim
IBA 31981
2005 BMW K1200LT
2006 HD FLHRCI
bmwbagby is offline
