Heated Seat not Working - BMW Luxury Touring Community
post #1 of 5 Old Dec 15th, 2013, 3:36 am Thread Starter
With temperatures dropping in London I turned on my heated seat (2010 K13GT) for the first time the other day and . . . . nothing! It appears in the display as 'on' but no heat
I've checked the connector - seems OK, any suggestions as to where I should look next?
I have a voltmeter so was going to see if the seat is getting power - anyone know what should be there when its on?
Finally anyone know if the seat a covered under the extended warranty?
Doug
dougunn is offline
post #2 of 5 Old Dec 16th, 2013, 10:04 pm
Re: Heated Seat not Working
If you have stock heated seats is the rear also out?
For your front, check voltage at the seat connector. If you've got some its probably the seat though I've got to say that such failures are uncommon to rare AFAIK. If you've got none, switch is the suspect. The older style switches are better than current but have been know to fail sometimes. Checking it is a matter of checking to be sure it has power in- and if nothing is going to the seat you've likely found the problem. There is always a chance of a broken wire so do your switch checks at the switch.
racer7 is offline
post #3 of 5 Old Dec 17th, 2013, 7:01 pm
r
Doug
check the fuse for the heater located under the seat.
Extended warranties vary from provider to provide so check the fine print of your policy.
2013 BMW Damask Red K1600GTL
2014 BMW K1600GTL-E EXCLUSIVE
2001 Honda C-250 Helix
Smokin'
SmokinJoe is offline
post #4 of 5 Old Dec 27th, 2013, 7:35 am
slparry's Avatar
Fuse?? the new K's don't have fuses ... unless I'm misinformed
Steve Parry
Current fleet is
14 BMW R1200RT LE
07 BMW K1200GT SE
03 BMW R1100S BoxerCup
14 BMW F800GS
87 BMW R80RS
... oh and the 330Ci for suit days
slparry is offline
post #5 of 5 Old Dec 27th, 2013, 7:39 am
slparry's Avatar
Doug
Mines the same Doug, my GS911 shows open circuit for the riders seat. From my tests with the meter it seems the current is sent to the seat as pulses by the bike, when the seat heater is set to high the bike makes the pulses faster and when set to the lower setting the pulses are slower.
The seats as far as I'm aware are not covered by the ext warranty, neither is the switchgear
Steve Parry
Current fleet is
14 BMW R1200RT LE
07 BMW K1200GT SE
14 BMW F800GS
87 BMW R80RS
slparry is offline
Kontour Seats tholdroaddog K1200LT 103 May 25th, 2015 12:16 am
Factory heated seat for 2003 K1200 LT Skipdempsey K1200LT 7 Jun 23rd, 2013 5:09 pm
Heated seat vertical adjuster question JnKDad K1200LT 9 Jan 22nd, 2013 5:34 am
Four-Prong Heated Seat Connector Dragonwing K1200LT 4 Dec 7th, 2012 6:18 pm
R1200RT Heated Seat Option gr8ridn RT Series 3 Jun 23rd, 2009 2:54 pm
