squealing clutch on 07 k1200gt - BMW Luxury Touring Community
post #1 of 5 Old Oct 4th, 2013, 2:23 pm Thread Starter
rlv
rlv's Avatar
I have purchased a very nice looking k1200gt with around 17,000 miles.
I have never seen such a sensitive clutch on a motorcycle.
It is either all or none with the clutch.
Most of the time when applying the clutch from a standstill to takeoff the thing squeals like crazy.
I have also noticed that the throttle is either on or off, no easing into it at all, a real bummer when applying the throttle when coming out of a curve.
Lol, also have noticed that you can be running down the road and the thing will stall, but takes right back up and goes on.
Anybody have any clues about these three problems.
Richard Vogt
2007 (Silver) R1200RT
2010 R1200GSA (Gertrude)
rlv is offline
post #2 of 5 Old Oct 4th, 2013, 2:35 pm
Re: squealing clutch on 07 k1200gt
Unfortunately, all quite "normal" for that bike . . .
The 1300GT introduced some improvements to those areas. The 1300 has a completely redesigned top end and airbox/idle control valve which helps, but can't be easily retrofitted onto the 1200. The newer 1300 clutch can be retrofitted to the 1200, but it ain't cheap . . .
More good clutch squawk discussion can be found at this link.
On the fueling issues, some guys have had good luck installing a Booster Plug which tends to smooth out the on/off transitions and stalling. Or else you have to go with a full Power Commander and get it dyno-tuned.
But the first thing you need to do is make sure you have the cam chain jump guard and latest cam chain tensioner. Check with your local dealer to see if those were done on your bike. If not, get it done, as it may well save you from a munched engine . . .
More cam chain info can be found at this link.
Also, have a read through this thread to learn more than you wanted to know about the K1200GT.
If you can sort out these issues (or learn to live with them), then it really is a fine bike, honest.
post #3 of 5 Old Oct 4th, 2013, 2:58 pm
My '07 K12GT has had a squealing clutch for the last 25,000 miles. When the clutch craps out, I guess I'll have it replaced. My bike also has most of the other "undocumented features" you mentioned, but they just don't bother me. As Ken said, I guess I've learned to live with them. I love this bike! I far prefer it to my last LT, due to its lower weight and higher power.
- Bob
Cowboy Bob Menton
Greenville SC USA
'07 K1200GT, '69 R60US (mint!)
'83 R80S (nee '83 R80RT)
bob_menton is offline
post #4 of 5 Old Oct 9th, 2013, 5:56 am Thread Starter
rlv
rlv's Avatar
Hey Meese and Bob, thanks for the information.
Been doing some good reading .
Richard Vogt
rlv is offline
post #5 of 5 Old Mar 24th, 2014, 1:04 am
pockomoth's Avatar
My clutch is fine but I had the fuel injection problems you mention plus a lot more. My dealer made some minor adjustments, but I finally installed a Power Commander and most of the problems are gone. You have to use the version for the K1200S, PC didn't make one for the GT, but many on this and the other forums have had luck with this. Mine still makes me long for carburetors but at least I don't want to give up bikes now !
pockomoth is offline
Take off, 'eh? Starting the LT from stop... petevandyke K1200LT 26 May 30th, 2012 9:48 am
Unreliable clutch advice please cyclecamper K1200LT 11 Dec 1st, 2008 10:23 pm
k1200gt 03 clutch be gone garthspeaks Other K-Bikes Discussion 2 Feb 10th, 2008 5:22 pm
