Brake Trouble - BMW Luxury Touring Community
post #1 of 9 Old Sep 25th, 2012, 3:05 pm Thread Starter
deanwoolsey's Avatar
Brake Trouble
Posting for a stranded traveler. 2008 K1200GT with 78,000 miles. Front brake lever intermittently goes clear to the bar but once released has normal function. Foot pedal seems unaffected. Dealer replaced ABS pump and problem is still there. Any ideas? No leaks anywhere. Fluid changed every year.
deanwoolsey is offline
post #2 of 9 Old Sep 25th, 2012, 6:52 pm Thread Starter
Re: Brake Trouble
Re-posting, Please help.
post #3 of 9 Old Sep 25th, 2012, 7:10 pm
Re: Brake Trouble
Sounds typical of a failing master cylinder.
André Strydom
BMW MOA #140995
Acts 4:12
andres is offline
post #4 of 9 Old Sep 26th, 2012, 7:14 am
rusmckay's Avatar
Re: Brake Trouble
I agree, however after having similar problem with my 2009 K1300 GT, and three visits to the dealer. They told me they fixed it by changing the REAR brake pads! Ok ok stop laughing, It fixed the problem. Now everyone can speculate about what the dealer really did. The bike is still in warranty,and the pads were $77.75 and the filter screen was 11.50, with tax my warranty work came to 95.50.
EVERY DOLLAR THEY CAN
Rusty Mckay
Titanium 02 LT Parted out
'09 K1300GT
rusmckay is offline
post #5 of 9 Old Sep 26th, 2012, 8:45 pm Thread Starter
Re: Brake Trouble
Turns out it was a wheel bearing. When the tech turned the front end side to side the lever would then pull clear back to the bar. The bearing being bad allowed the rotors to press the pistons back with the slack in the front end. Mind you this was no average bad bearing. The cage and balls were missing. Saw it with my own two eyes. So that's a new one for me. A bad front axle bearing can present itself as a failing brake system. While it is perfectly logical, how weird is THAT?????
post #6 of 9 Old Sep 26th, 2012, 10:59 pm
Re: Brake Trouble
What puzzles me is how one would ride a bike with a wobbly front wheel and not notice it? With the cage and balls missing that wheel could not have run true!
André Strydom
BMW MOA #140995
Acts 4:12
andres is offline
post #7 of 9 Old Sep 26th, 2012, 11:09 pm Thread Starter
Re: Brake Trouble
Not only did he ride it that way, he checked it and missed the bearing issue. The tech rode it and missed the bearing issue. My theory is the calipers helped hold it true and the left bearing was able to take the torque. The good news was when Engles found the problem they stepped up and just charged him for the real problem. Two thumbs up for the Engles crew.
post #8 of 9 Old Sep 27th, 2012, 7:59 am
rusmckay's Avatar
Re: Brake Trouble
I'm going to pull my front wheel and do a bearing check/ replacement
Rusty Mckay
'09 K1300GT
rusmckay is offline
post #9 of 9 Old Sep 29th, 2012, 6:10 pm
Re: Brake Trouble
I replaced the front wheel bearings on my '07 K12GT at 73K miles. Not as serious of an issue as described above, but I did notice a little bit of play/roughness and so I just swapped them out.
Never noticed any additional problems with them over the next 65K miles.
Brake System Recall; Late model R1200GS, R, ST Dan-A Other R-Bike Discussion 1 Aug 13th, 2010 8:25 pm
Brake servo oddness Mashambiker K1200LT 2 Mar 17th, 2010 11:42 am
Brake light Problems BillE K1200LT 5 Aug 24th, 2009 8:07 am
Brake, Brake, BRAKES!!!!!!! Jabrown K1200LT 15 May 15th, 2008 9:51 pm
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 10:37 am
