ABS modulator/pump change - BMW Luxury Touring Community
post #1 of 1 Old Oct 20th, 2011, 2:33 pm Thread Starter
Has anyone changed out an ABS pump on a 2006 K1200GT, the later type pump.
Is it easy to do, if its changed out, will the light reset, or is it a dealer only task to reset.
How easy is it to flush/bleed the system.
Also-are the k1200gt & k1300gt modulators compatible, have checked MAX OEM fiche, & part numbers are the same-34517715109, but saw a k1300gt pump & number was 34517715107, so am rather confused.
Any info wellcome.
Regards
Stevie
stevie1 is offline
Integral ABS Brake Fluid Change Question blkhwk34 K1200LT 12 Aug 24th, 2009 8:32 pm
ABS modification JerryAttrick RT Series 0 Nov 25th, 2008 5:18 am
ABS 2 Reset works on RT's as well as LT's JPSpen RT Series 0 Aug 9th, 2008 2:27 pm
ABS and REVERSE GUIDENCE JTEC K1200LT 5 Jul 18th, 2008 3:58 pm
