Sea Foam - BMW Luxury Touring Community
post #1 of 4 Old Aug 4th, 2011, 2:12 pm Thread Starter
TwoBrittanys's Avatar
Sea Foam
Has anyone ever used this stuff called Sea Foam? Would you use in your own BMW? Is there any benefit or is it just snake oil?
2009 Honda Shadow Spirit Red (wife's bike)
2008 BMW K1200GT2 Adventurine Silver (looks like green to me)
2006 Triumph Scrambler Red/White
2005 Harley-Davidson FLHTCUI Lava Red Sunglo/Vivid Black
2002 BMW R1200C Black with white pinstripes
Frank Drecchio, Forest Hill MD
"if it ain't broke, fix it 'till it is"
Lifetime Member IBF (International Brotherhood of Freeloaders)
TwoBrittanys is offline
post #2 of 4 Old Aug 4th, 2011, 2:40 pm
Re: Sea Foam
I ran some Sea Foam in my K13GT without any problems. Just follow their directions as to concentration. I also did it on a long trip where I could just ride the whole tank out rather than let it sit.
If you have small bits of varnish built up in the fuel system, this is a good way to clean that out.
It didn't help in my case, but that's because I later discovered that the problem I was having was caused by a different issue.
When I'm just riding around, I'll usually grab the cheapest gas I can find, regardless of brand. If I'm on a timed trip or a really tight schedule, I'll grab the easiest, most convenient gas regardless of cost.
And every so often, I'll hit a Chevron or similar to run some Techron-gas through the bike. That seems to keep things clean and flowing well enough.
post #3 of 4 Old Aug 4th, 2011, 5:02 pm
Re: Sea Foam
Sea Foam is good stuff!!
Brian Heller
2001 LTC-Pacific Blue
Brian_H is offline
post #4 of 4 Old Aug 4th, 2011, 5:02 pm
RonKMiller's Avatar
Re: Sea Foam
If you don't ride your bike for extended periods of time Sea Foam is a good choice to keep your fuel stabilized.
I'm also a fan of running a small amount of Techron through engines about 500 miles prior to an oil change. I've got a 1987 Chevy truck with the original throttle bodies still working great at 230K miles. It has had the Techron treatment once every couple of years, and I've never had fuel related issue.
"Like Butt-ahh!"
RonKMiller is offline
Foam piece in front of gauges BMWCharlie K1200LT 9 Jul 24th, 2011 7:10 am
Foam inserts MountianMama K1200LT 3 Apr 19th, 2010 9:41 pm
Blowing foam? budzee K1200LT 10 Aug 20th, 2009 1:28 pm
Sea Foam For Oil randykling K1200LT 0 Jan 15th, 2009 4:32 pm
Foam blowout quickbeemer K1200LT 11 Feb 28th, 2008 1:08 pm
