Oil sensor problems? - BMW Luxury Touring Community
post #1 of 12 Old Sep 29th, 2010, 12:18 pm Thread Starter
SRM
SRM's Avatar
Was driving into work this morning - check the temp with the recent heat wave, and observed the 'Oil' with a check mark at idle. As soon as I got above 2 grand on the tach, the 'Oil' check disappeared and temperature displayed...
Got to work shortly thereafter and check oil - I'm full up - been on the watch after reading Dave's experience with oil loss on his old post...
Don't have the 'goofy' manual with me --- any ideas? Oil sensor??
Thanks!
Stephen
Stephen Malm
'07 GT - Blue Tooth
'03 LT - Silver Bullet
'85 HD Sportster - junk
'84 Suzook GSX 1100 EF
2 many dirt bikes to mention
Prisoner of the white lines on the freeway.....
SRM is offline
post #2 of 12 Old Sep 29th, 2010, 1:59 pm
Re: Oil sensor problems?
From memory I'm pretty sure that the oil check only registers when you are stationary. Once on the move it switches to another reading... eg ambient temperature.
Paul_C is offline
post #3 of 12 Old Sep 29th, 2010, 2:17 pm
slparry's Avatar
Oil level tick is only visible when stationary and on mine as soon as I start moving the tyre pressure monitor displays
Steve Parry
Current fleet is
14 BMW R1200RT LE
07 BMW K1200GT SE
03 BMW R1100S BoxerCup
14 BMW F800GS
87 BMW R80RS
... oh and the 330Ci for suit days
slparry is offline
post #4 of 12 Old Sep 29th, 2010, 2:25 pm
slparry's Avatar
Thanks!
Stephen
download a pdf of the manual here
http://www.bmw-motorrad.dk/dk/da/ser...s_service.html
Steve Parry
Current fleet is
14 BMW R1200RT LE
07 BMW K1200GT SE
14 BMW F800GS
87 BMW R80RS
slparry is offline
post #5 of 12 Old Sep 29th, 2010, 3:49 pm Thread Starter
SRM
SRM's Avatar
Excellent! Many thanks for your replys!
Cheers,
Stephen
Stephen Malm
'07 GT - Blue Tooth
SRM is offline
post #6 of 12 Old Sep 29th, 2010, 5:34 pm
I sure wish I could see that oil check mark again... I am still getting the <!> almost 5,000 miles now with <!> instead of the friendly check mark and dealer still can't fix it.
mikeyr is offline
post #7 of 12 Old Sep 29th, 2010, 10:58 pm
My dealer has been trying to fix my oil level light for 6 weeks. I got
Bmwna involved and they emailed a custom software patch. Not sure if that fixed it as they are now stuck on a xeon light problem. Unbelievable!
remphoto is offline
post #8 of 12 Old Sep 30th, 2010, 12:18 am
I have told my dealer about the custom software and he says there is no such thing. I even printed out some posts to show him...no go...still <!>
mikeyr is offline
post #9 of 12 Old Sep 30th, 2010, 10:37 am
My 09 did this and it was a software thing. If you can call A&S BMW or SFO BMW but it took a day to get the update done >
Nathan is offline
post #10 of 12 Old Sep 30th, 2010, 4:56 pm
avonfloater's Avatar
Exclamation Re: Oil sensor problems?
What indicator are you seeing when the oil tik doesn't seem to be working and it turns out to be the software? I see my "out-of-range" image and it goes on and off - when I manually check the oil level it is at max.
Denny
avonfloater is offline
post #11 of 12 Old Sep 30th, 2010, 9:03 pm
Denny
It is the <!> symbol on the instrument cluster. Comes on when you are stopped for a minute or so with the engine idling (like at a traffic light) and stays on until the engine is restarted. Normally you should get a check mark that the oil level is ok under these conditions
remphoto is offline
post #12 of 12 Old Mar 30th, 2011, 1:45 pm
larrykay's Avatar
Re: Oil sensor problems? <!>
I finally got my <!> fixed. BMW wrote a custom software patch for my VIN number. It took 3 separate attempts at downloading it, so it would "take" Max's BMW finally used a special BMW computer and it now works properly.
Larry
2009 Deep Blue K1300GT
larrykay is offline
First Solo Oil Change - Complete! hschisler K1200LT 40 Mar 13th, 2016 11:28 pm
Oil analysis results after 23,782 miles RealWing K1200LT 22 Aug 11th, 2013 9:15 pm
An Oil Man's View robasay Chit Chat 38 Jun 25th, 2009 7:28 am
$65 oil is coming (maybe) RTTommy Chit Chat 17 Oct 10th, 2008 8:43 am
Oh no!, another post about oil? cantdrive55 K1200LT 6 Sep 24th, 2008 8:07 am
