New Farkles! - BMW Luxury Touring Community
post #1 of 5 Old Sep 20th, 2010, 11:35 am Thread Starter
SRM
SRM's Avatar
New Farkles!
Over the weekend, I put on a new pair of Avon's - scrubbed 'em up a bit for the first 100 miles; then, put them through the paces on the commute through the mountains this morning -- all I can say is - WOW! Incredibly sticky and I feel a lot more confident on these tires!
I'm waiting on my Stebel horn and haven't put on the additional HID lighting & motolights - probably next weekend, but did have a few minutes to put on the 'Aero flow - aero gards' -- then went for a 'wet' ride on the coast yesterday for the 'tire scuff ride' - it was misting/wet and I felt like I was back on my old LT - very comfortable!
This GT is VERY much the bike I've been looking for - for a long time -- light, quick and comfortable!
Stephen Malm
'07 GT - Blue Tooth
'03 LT - Silver Bullet
'85 HD Sportster - junk
'84 Suzook GSX 1100 EF
2 many dirt bikes to mention
Prisoner of the white lines on the freeway.....
SRM is offline
post #2 of 5 Old Sep 20th, 2010, 12:00 pm
Re: New Farkles!
Yeah, we know.
post #3 of 5 Old Sep 20th, 2010, 12:42 pm Thread Starter
SRM
SRM's Avatar
Re: New Farkles!
Yeah - I'm not telling you anything Ken! BTW - I read a post a while back on your install of a Stebel horn -- where'd you put it???
Stephen Malm
'07 GT - Blue Tooth
SRM is offline
post #4 of 5 Old Sep 20th, 2010, 2:19 pm
Re: New Farkles!
I've seen three good places to mount a Stebel on the GT.
The easiest is under the left body panel, on the shelf in front of the ABS pump. There's lots of room there on the '07 and newer bikes. The '06 bikes had a larger power ABS pump, but there is still room behind or above the ABS pump.
The next place is under the right body panel, just below the ZFE module. It's a bit tight, but it does fit in there. Plus, that's near the original horn, where the new relay trigger wire ties in to the stock wiring.
The third place is up in the nose cowl, under the windshield adjustment mechanism. Again, it's a tight fit, but does work.
I also know a couple of guys that split the horn's motor/blower assy from the plastic horn section and used a rubber hose to connect the two. That gives more flexibility in terms of mounting locations, but can add a delay depending on the length of the extra hose.
Mine is under the right body panel, since my ABS shelf has four HID ballasts taking up that space. I sometimes wonder if it's not quite as loud as it could be, since it's pressed up pretty close to the actual fairing panel (you need room for the air to move to make the sound). I've thought about moving it to the nose cowl, but haven't bothered yet.
There's lots of info if you search for Stebel here or over at the K12/13GT forum at K-bikes.com. Specifically, look at post #11 in this thread for pics and ideas.
post #5 of 5 Old Sep 20th, 2010, 2:42 pm Thread Starter
SRM
SRM's Avatar
Re: New Farkles!
Thanks Ken -- greatly appreciate the assistance!
Stephen Malm
'07 GT - Blue Tooth
SRM is offline
Do Farkles add any REAL value. HDusenbery Bike Talk 19 May 14th, 2009 4:03 pm
Loading up with Farkles!!! hifiman K1200LT 2 Mar 7th, 2008 5:36 pm
Farkles, lots of Farkles but........ Jentine RT Series 1 Mar 8th, 2007 4:39 am
Group Buy Prices On All BMW Farkles Forever!!! JoyfulSoul Bike Talk 2 Feb 13th, 2007 7:16 am
all threads in Farkles? CarSalesman BMWLT Site Support Forum 0 Oct 10th, 2005 8:15 pm
