K1200GT issue - BMW Luxury Touring Community
post #1 of 8 Old Sep 10th, 2010, 3:26 pm Thread Starter
K1200GT issue
I have a 2006 K1200GT. I have had a strange issue latley. When I accelerate or even at cruising speed the bike will have a sudden loss of power. It acts like it is going to stall then all of the sudden it gets the power back and goes. I usually have to throttle up to get it back. The first time it happened I was going about 65 mph and in cruise control. It lost power and i thought it was stalling. When it got power back it almost threw me off the bike. A bit scarey. I took it to my local BMW mechanic and he says he can't find anything. Has anyone else had this problem? What is it?
buchanan25 is offline
post #2 of 8 Old Sep 10th, 2010, 7:21 pm
avonfloater's Avatar
Smile Re: K1200GT issue
Others have had a similar issue and they will chime in. Some had new software installed that seemed to cure the problem. Scary for sure when the surge comes.
Denny
avonfloater is offline
post #3 of 8 Old Sep 11th, 2010, 11:33 am
Re: K1200GT issue
Search for "BBS" on this site, and also over at k-bikes.com and i-bmw.com (especially k-bikes.com). BBS stands for "Bucking Bronco Syndrome". Also search for "high idle".
Many 2006/2007 K1200GTs had various throttle and fueling problems similar to what you describe. The fix was to replace the airbox and upgrade the software. You may want to check to see if the airbox has been replaced on your 2006 K1200GT.
XMagnaRider is offline
post #4 of 8 Old Sep 13th, 2010, 2:39 pm
Re: K1200GT issue
I've had similar a couple of times. Looking back I'm pretty sure it was water in the fuel. Both times it had been after extended riding in very heavy rain. It took a few days riding to clear on both occasions.
Paul_C is offline
post #5 of 8 Old Sep 15th, 2010, 10:58 pm
halrkent's Avatar
Re: K1200GT issue stalling
I have K2006GT that stalled when decelerating. I have the latest software update and the new air box. It occurred often enough to be a safety issue. I installed a product called BoosterPlug that enriches the fuel mixture 6%. The BoosterPlug made a big difference in throttle response smoothness and stopped the stalling. Check it out at http://www.boosterplug.com.
Hal
halrkent is offline
post #6 of 8 Old Sep 17th, 2010, 3:29 pm
SRM
SRM's Avatar
Re: K1200GT issue
WOW! That's excellent Hal - have you noticed any change in your gas mileage?
I experienced the BBS aud nauseum on my old LT and the solution I could find was to dump in a half-bottle of Chevron's 'Techron fuel additive - only to have concerns later about the impact of those solvents on the internal fuel pump...
The enrichment device you mention MAY just be the ticket!
Stephen Malm
'07 GT - Blue Tooth
'03 LT - Silver Bullet
'85 HD Sportster - junk
'84 Suzook GSX 1100 EF
2 many dirt bikes to mention
Prisoner of the white lines on the freeway.....
SRM is offline
post #7 of 8 Old Sep 19th, 2010, 6:53 pm
halrkent's Avatar
Re: K1200GT issue
There doesn’t seem to be any change in my gas mileage, the idle did go up from 900 to 1100 RPM’s. I recently volunteer to be a motorcycle marshal at a bicycle rally. This necessitated riding slow over two days in 90+ degree heat. This is the conditions that use to cause the motor to stall but not anymore.
Hal
halrkent is offline
post #8 of 8 Old Sep 20th, 2010, 8:49 pm
noRThwind's Avatar
Re: K1200GT issue
Any chance that you have been riding in wet weather (rain) lately, if so and if you have not already done so, check your air filter, it might be wet.
noRThwind is offline
My new K1200GT . . . Day ONE! messenger13 K1200/1300GT (The Next Generation) 49 Jun 27th, 2006 10:12 am
New K1200GT to debut in US at Long Beach IMS eljeffe K1200/1300GT (The Next Generation) 1 Nov 17th, 2005 7:11 pm
MapSource lnowell GPS 8 Nov 9th, 2005 3:32 pm
