Parkade Metal Sensor - BMW Luxury Touring Community
post #1 of 14 Old Feb 21st, 2010, 2:26 pm Thread Starter
I like to ride my GT to work during the summer, but am having problems because the GT doesn't have enough metal on it to activate the sensor to let me into the buildings underground parking lot. Since there is usually no parking attendant around, it makes getting in a big PITA. I was wondering if one of those magnets that you attach to the bottom of your bike to activite traffic lights would work and if so, would anyone have a supplier and model that they would recommend.
Thanks!
ronk1200lt is offline
post #2 of 14 Old Feb 21st, 2010, 2:33 pm
JPSpen's Avatar
Re: Parkade Metal Sensor
If the sensor is a loop of wire in the ground. It "might" work. It might not...
If the vehicle is sensed in some other way. Probably not.
You'll need to get the magnet as low as you can...It is just a big magnet.. So go find a big one someplace and try it...No need to spend a bunch of money on magnets..Got an old speaker ? Pop the magnet off the back of the frame with a chisel.
You could get a few from old hard disks, Then stack them together. Fasten them to your boot... Then wave your boot over the loop... That'd likely work for sure.
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #3 of 14 Old Feb 22nd, 2010, 8:22 pm Thread Starter
Thanks John! I will try the magnet off an old speaker. I appreciate you showing me how to save a few bucks. Ron
post #4 of 14 Old Feb 23rd, 2010, 12:51 am
I bet that the magnet doesn't help, but do let us know.
Traffic loops use a high-frequency oscillating current to induce currents in the metal of your vehicle. The traffic loop wires are connected to a sensor, which detects the effects of the induced currents on the traffic loop.
The magnet won't help, other than providing some additional conductive metal. A same-sized piece of non-magnetized (but conductive) metal would have the same effect.
How do I know? I will never forget the bet I made with my physics prof on this topic, and for the last three years I have worked on the traffic loops and sensors that operate the gates of our neighborhood association. We have the sensitivity set very high - motorcycles and most bicycles can trigger them, but I have demonstrated for disbelieving neighbors that neodymium magnets cannot.
XMagnaRider is offline
post #5 of 14 Old Feb 23rd, 2010, 9:51 am
Thanks!
Hey neighbor, we'll have to meet for a ride sometime, when the roads are clear.
P.S. Born and raised in Edmonton, escaped to little ole Leduc 3.5 yrs ago
08 K1200GT
08 F800S
00 K1200LT
Rickmick is offline
post #6 of 14 Old Feb 23rd, 2010, 10:06 am
deanwoolsey's Avatar
If it has a coil sensor in the pavement try moving slowly across it while sliding the kick stand on the pavement. That usually works.
deanwoolsey is offline
post #7 of 14 Old Feb 23rd, 2010, 12:32 pm Thread Starter
Hi! Rick the roads were clear enough on Saturday for me to get my bike out for a 1/2 hour ride. I live near St. Albert so we will have to get together for a ride.
Ron
post #8 of 14 Old Feb 23rd, 2010, 12:34 pm Thread Starter
I never thought of it, but lowering the kick stand will put metal closer to the ground. I will give that a try.
post #9 of 14 Old Feb 23rd, 2010, 1:07 pm
Putting the side stand down in gear will kill the bike (I think) so neutral it first and coast it across.
post #10 of 14 Old Feb 23rd, 2010, 3:36 pm
It won't kill it until you let the clutch out...
post #11 of 14 Old Feb 24th, 2010, 10:32 pm
Sit
Sit's Avatar
Do you have a center stand? Use it instead of the side stand, won't have to mess with finding neutral etc. Just roll up, clutch in, push the center stand down onto the loop and it may go for you. If it does, just ride in. I used this method on several of the lights around my house until I got tired of doing that and just called state highway to have them turn up the sensitivity. May want to check with owners of the garage and see if they can adjust the sensor loop, after all, you are a paying customer.
Sit is offline
post #12 of 14 Old Feb 24th, 2010, 11:59 pm
Huh? I ride my 2007 K1200GT into the garage, in first gear, stop with the clutch in (still in first gear), and kill the engine by lowering the side stand. Because it is in first gear, the bike is less likely to roll off the side stand if the bike is bumped by accident.
post #13 of 14 Old Feb 25th, 2010, 7:28 am
WOW !!! Hold my beer and watch this! Careful lowering either stand while moving and possible leaning..
I hit a large piece of metal in the road last month and lost the springs holding up the kickstand. Kickstand dropped down, killed the engine and I slowly rolled over to the side of the road. I had been planning to turn right, off of the interstate. Left turn would have been ugly. It could have been a pain with a pivot point to one side and me having to go the other way because of traffic.
post #14 of 14 Old Feb 25th, 2010, 10:24 am
I tried one of those magnets back a few years ago. IMHO save yourself time and money. The one I had didn't accomplish anything except to make my wallet lighter. Talk to the garage people. There should be an adjustment for sensitvity for the sensors for that system. I know the traffic light sensors can be tweaked as necessary to recognize a motorcycle.
lawretj is offline
Help, O2 sensor cables mixed! pozo_izquierdo K1200LT 4 Oct 20th, 2015 10:24 pm
Rain Sensor Problem - X5 bbbngai Chit Chat 15 Nov 10th, 2008 6:43 pm
Question on Oxygen Sensor MNTodd K1200LT 1 Sep 21st, 2008 3:05 pm
Rear brakes, skreeeeeeach, metal on metal BecketMa K1200LT 11 Feb 6th, 2007 4:59 pm
O2 Sensor Replacement STYLNLT K1200LT 3 Sep 27th, 2006 11:02 am
