Who is Number 1? - BMW Luxury Touring Community
post #1 of 8 Old Jan 11th, 2010, 3:59 pm Thread Starter
blouw's Avatar
Who is Number 1?
This is a cross post from k-bikes. Nobody seems to know the answer there
I have just done a valve check on my '08 K1200GT. Turned out a lot easier than I thought and they were all in spec at 18k.
My question is which cylinder is number 1?
It doesn't really matter for the valve check, but I am curious. WIth the camshaft marks lined up flush with the cylinder head surface, 1 and 4 are at TDC. So, which is which? It doesn't tell you in the RepRom.
-Brian Louw
Arroyo Grande, CA.
2016 R1200GSA
blouw is offline
post #2 of 8 Old Jan 11th, 2010, 8:24 pm
AlaskaFish's Avatar
Cool Re: Who is Number 1?
Don't know the GT but if they follow industry standards it would be from left to right as you straddle the Bike. It is from front to rear if the cylinders are in line with the frame, like on the LT.
HTH,
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #3 of 8 Old Jan 11th, 2010, 8:49 pm
Originally Posted by AlaskaFish
Don't know the GT but if they follow industry standards -----------------------------------------------
BMW knows nothing of "industry standards"! If BMW did not invent it, it does not exist.
I have a BMW car with a V8, and found that they number the cylinders from front to back as normal, but 1,2,3 and 4 are the left bank, 5,6,7 and 8 on the right bank. All theV8's I ever worked on before were in order of the cylinders on the crankshaft, so they alternated left to right, with 1,3,5 and 7 on the left, 2,4,6 and 8 on the right.
I thought BMW was strange at times, until I bought a Toyota Tundra truck with a V8. This one is stranger yet, with the water pump driven by the TIMING BELT, so you have to remove just about the whole front of the engine to get to it, and the starter is UNDER THE INTAKE MANIFOLD! In the past I thought Toyota was the best about thinking of mechanics who have to work on them, but now there is a group of engineers sitting at their desks in Japan laughing until they cry.
For an old mechanic/engineer like myself, nothing seems to be sacred any more!
post #4 of 8 Old Jan 11th, 2010, 9:49 pm
TxWhiteKnight's Avatar
I got this from the manual, it is as close as I can find
facing forward #1 will be the left cyl
Steve
DFW
'02' F650GS Dakar
'06' K1200GT Blue
Motorcycle Road Show
TxWhiteKnight is offline
post #5 of 8 Old Jan 11th, 2010, 10:33 pm Thread Starter
blouw's Avatar
Ding Ding! Looks like we have a winner. Thanks, Steve. That must be somewhere in the RepRom. I'll look harder.
That was what I initially thought, but the camshaft drive on the right side threw me.
It would be nice if they all numbered in the crankshaft sequence with the front being the opposite end of the drive side.
-Brian Louw
Arroyo Grande, CA.
2016 R1200GSA
blouw is offline
post #6 of 8 Old Jan 11th, 2010, 10:38 pm
it was in the valve adj area
even a nice little sheet to keep score for each one
Steve
DFW
'02' F650GS Dakar
'06' K1200GT Blue
post #7 of 8 Old Jan 11th, 2010, 10:49 pm Thread Starter
blouw's Avatar
And my flat-6 Boxster is numbered 1-3 on the right and 4-6 on the left!
-Brian Louw
Arroyo Grande, CA.
2016 R1200GSA
blouw is offline
post #8 of 8 Old Mar 9th, 2010, 10:25 pm
Razel's Avatar
Ford V8's were numbered 1-4, 5-8. Firing order was therefore different, but turned out to be the same if you numbered the cylinders like GM or Chrysler.
Razel is offline
LT air filter part number mjac K1200LT 2 May 17th, 2009 6:42 pm
factory clutch bleed fitting part number? hmmmm90s K1200LT 7 Aug 15th, 2007 3:57 pm
OEM Part Number Help Please... gulfxray K1200LT 4 Mar 25th, 2007 1:57 pm
Factory Xenon conversion - first part number Randy K1200/1300GT (The Next Generation) 4 Dec 19th, 2006 6:21 pm
Rear Drive bearing number DanMartin K1200LT 7 Feb 4th, 2006 10:20 pm
