6K mile oil change - BMW Luxury Touring Community
post #1 of 10 Old Sep 24th, 2009, 2:36 pm Thread Starter
6K mile oil change
Hi,
I would like to tackle the 6,000 mile oil change myself. I know, I'm not dealing with a full roof over my head.
Anyway is there a manual that covers this?
Steve
smartypants is offline
post #2 of 10 Old Sep 24th, 2009, 3:54 pm
Re: 6K mile oil change
This is one of the easiest things that you can do for your bike. A search will provide you with lots of info. Simply remove the filter on the bottom ( three screws) let oil drain. Replace new filter ( fill it with oil first) screw in three screws gently and then add oil. Search site for specifics... Don't forget newspaper and cat litter.....
check "similar threads" at the bottom of this page.
post #3 of 10 Old Sep 24th, 2009, 3:59 pm
seahabit's Avatar
+1 with dandiver, Also, get a Clymer manual. It's 40 bucks well spent.
seahabit is offline
post #4 of 10 Old Sep 24th, 2009, 4:48 pm
blueknightga6's Avatar
And as a plus, you can use regular automotive oil and not motorcycle specific oil. But seriously if you can change the oil on a car you can change the oil on this bike. I just did mine today. You'll just need the right sized "cap" style filter wrench.
This weekend I'll also be changing my spark plugs, transmission oil, FD oil,air filter and fuel filter. But first I'll have to get the big girl naked for the first time.
Chris Ehlbeck
blueknightga6 is offline
post #5 of 10 Old Sep 24th, 2009, 5:39 pm
Just one other note. The first time I did my oil, ( actually all three fluids) I had help from several others from this forum and that really made the task easy. Maybe check to see if there is anyone in your area up for a tech session. Gather a few bikers in your garage, especially someone who has done it and then proceed. Maybe change all three main fluids at the same time as I do every 6,000 miles. Dave Dragon, John Ritter and company helped me the first time.
I'm due for changing all three in about a 1,000 miles and you are welcome to come and watch..........
post #6 of 10 Old Sep 24th, 2009, 7:18 pm
You guyz with LTs --- do the GTs use the same oil and fluid change procedures?? Just as easy to do?? I've never looked up under a GT to see how it's done, so am just curious.
post #7 of 10 Old Sep 25th, 2009, 9:31 am
OOPS. I just now noticed that this thread was the GT and not LT. But by the looks of my Clymer manual, some of the work on the GT is easier. But then again there's always the "remove the gas tank" step too.
Chris Ehlbeck
post #8 of 10 Old Sep 25th, 2009, 2:23 pm
kapod2t's Avatar
I wouldn't use automotive oil. This bike has a wet clutch. I'm pretty sure you need a friction agent in the oil.
Ride fast. Take chances.
2008 K1200GT
2004 Harley Road Glide "Kapo"
kapod2t is offline
post #9 of 10 Old Sep 25th, 2009, 3:44 pm
LIKE I SAID. It was my mistake. I'd stay away from automotive oil for a wet clutch. I misread the header and mistakenly thought LT instead of GT.
Chris Ehlbeck
post #10 of 10 Old Sep 26th, 2009, 7:37 pm
Note that this is in the Next-Gen GT forum, so the procedure is a bit different than on the LTs and older RS/GT models.
There's a lot of info on our sister site, K-Bikes.com, including a very thorough Technical section. Check the Hall of Wisdom, Maintenance section for the info you need.
As for the type of oil to run, it seems that even BMW can't figure this one out so what are us mere mortals to do?
Oil change Southern style seahabit K1200LT 17 Jul 19th, 2009 8:52 pm
03 LT Oil Change tkirklan K1200LT 22 Jun 23rd, 2009 11:13 pm
Oil Change Help ssnowgun K1200LT 7 Apr 3rd, 2009 8:04 pm
rear drive oil change - TBob K1200LT 25 Oct 28th, 2008 5:37 pm
LT - Tranny Oil Change... How often do you? hallzee K1200LT 16 Jun 30th, 2008 1:46 pm
