I need a stickier seat - BMW Luxury Touring Community
post #1 of 33 Old Jun 17th, 2009, 6:26 pm Thread Starter
I have a Rick Meyer seat for my 2007 K1200GT. The seat is leather so I end up sliding forward when I take a corner or brake. Is there anything I can put on the leather to make it more adhesive or is there another solution anyone could suggest other than getting the seat recovered?
ronk1200lt is offline
post #2 of 33 Old Jun 17th, 2009, 6:47 pm
MrsKatnapinn's Avatar
Re: I need a stickier seat
Get knee grips that go on the side of the tank. I'm not sure who makes them but someone that has them should chime in soon. Grif, David Taylor, Meese ???
Sammie Shreeve
2012 K1600GTL
on the rear seat only
MrsKatnapinn is offline
post #3 of 33 Old Jun 17th, 2009, 7:27 pm
dpancerz's Avatar
Always check out Jerry's inventory when in doubt.
http://piratesk12site.net/TechSpec.htm
David
dpancerz is offline
post #4 of 33 Old Jun 17th, 2009, 7:46 pm
Lexol leather cleaner and conditioner always makes my car seats sticky. Or you could fasten your seat belt a bit tighter!!!
Bruce
beartooth is offline
post #5 of 33 Old Jun 17th, 2009, 11:17 pm
Talk to Rick and get your seat fixed right. A properly fitted and sculpted seat won't allow you to slide forward like that. Everything else is just a band-aid fix.
post #6 of 33 Old Jun 18th, 2009, 1:20 am
Super Moderator
DavidTaylor's Avatar
Some adjustments from Rick will help. I also highly recommend the TechSpec Gripster pads. There is very little friction for your knees when you grip the tank during braking and these work like a charm.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #7 of 33 Old Jun 18th, 2009, 6:38 am
REWDOC's Avatar
I agree with David. I slipped forward badly with the stock seat and Grif told me about the Gripster pads. I got them and cured the problem. I received my saddle from Rick Mayer in November and have not had a problem. I think you will have the problem with any saddle without the grip pads due to the design of the bike (Spout Touring). The bike is designed to have a slight forward leaning position, which I have about eliminated with Rick' s seat and the handlebar set backs. If I could just do something with the pegs, it would as good as the LT.
Look down towards the bottom of this site for the K1200GT pads.
http://www.techspec-usa.com/products/gs_bmw.html
Dick Wood
Previous 1995 HD FXDL
IBA #7393
REWDOC is offline
post #8 of 33 Old Jun 18th, 2009, 10:02 am
Super Moderator
There is a peg lowering kit out there somewhere. I think Ken had one on his GT for a while.
David Taylor
San Jose, CA
AMA, BMWMOA
Booze Brother #4
post #9 of 33 Old Jun 18th, 2009, 11:44 am
No, I disagree. A properly fitted seat will eliminate that sliding forward business. There needs to be a bucket for you to sit in that supports your butt and your upper thighs, which spreads the weight over a larger area for better long-distance comfort. And the seat should raise up at the front so that your hips stay in position even on hard deceleration. Yes, the GT is a sport-tourer, but we don't need to be hanging off in corners or bent over holding the front axle to hustle this bike along. Trust me, I've embarrassed much sportier, "faster" bikes with a combination of skill and confidence while sitting upright with the iPod blasting . . .
Suburban Machinery does make a set of peg extenders for the GT, as does Verholen. I put the Verholen 40mm (1.5") peg extenders on the day I got the GT. The SM extenders are fixed, but the Verholen extenders are two-piece with a serrated interface which allows a bit of fore-and-aft adjustment if needed. But I found that once they're set you don't really need to move them.
With those and the seat in the high position I actually had slightly more leg room than the LT. But it's much easier to drag the lowered pegs in the corners, so if you're an aggressive rider then you might want to consider that.
Or you could always go with these.
post #10 of 33 Old Jun 18th, 2009, 7:20 pm
RonKMiller's Avatar
OR:
You can use a layered composite of different densities and thicknesses of military specification 3M visco elastic foam that molds to your butt bones and vectors forces in all different directions - to create the "bucket" INSIDE the seat.
AND:
a knitted, mesh polyester top cover that was specifically designed to grip you and keep you from sliding forward while allowing a tremendous amount of air to flow underneath your butt.
Isn't modern technology great?
"Like Butt-ahh!"
RonKMiller is offline
post #11 of 33 Old Jun 18th, 2009, 7:33 pm
OK, but it's still a "bucket" tailored to your own butt. Same basic idea, then.
Yes, and a tremendous amount of water, too.
Yep - right up until it rains.
post #12 of 33 Old Jun 18th, 2009, 7:57 pm
cccpastorjack's Avatar
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #13 of 33 Old Jun 18th, 2009, 8:49 pm
Smile Re: I need a stickier seat
Rosin will give you a tight grip!
post #14 of 33 Old Jun 18th, 2009, 9:15 pm
mdm_rides's Avatar
Wear leather pants. I have a pair of Langitz that stick to the seat like a suction cup which I hate. Personally I believe it is better to be able to slide around, set your cg to the corner, and move across the bike L to R to balance the action to make things work in a smooth, safe but fast manner. So, most of the time I wear belstaff pants.
May be to many dirt hours though
mdm_rides is offline
post #15 of 33 Old Jun 18th, 2009, 9:51 pm
REWDOC's Avatar
Now that I think about it, you are right Ken. Since I got my seat from Rick, I hardly ever have to squeeze the tank very hard. With the stock seat, I'd just about slide up on the tank without the gripers, especially during hard braking.
It's not that the pegs are too high, as I only have a 30" inseam. It's that they are too far back and make my feet angle downward causing my calf below my knee to ache, especially the left one. I have to straighten my leg out every 50-75 miles. If I could just bring it forward and make it flat, I think I would be more comfortable.
Dick Wood
IBA #7393
REWDOC is offline
post #16 of 33 Old Jun 18th, 2009, 9:52 pm Thread Starter
OR:
AND:
It sounds like you are saying that I should dump my current seat and buy one of yours.
post #17 of 33 Old Jun 18th, 2009, 9:53 pm Thread Starter
What type of Rosin would you be referring to????
post #18 of 33 Old Jun 18th, 2009, 10:03 pm
On the street? Where are you riding that you feel you need to be sliding around?
Seriously, there are very few public roads where you can safely ride at the level where you have to be sliding around that much. That doesn't mean that you can't ride very quickly, but the sliding around just seems excessive, unless you're trying to "drag a knee" at a much slower pace than a particular corner really requires for that action.
But what I really wanna know is, will you show me where? I bet I can keep up with my feet on the pegs, my lower back firmly tucked into my backrest, and my arms smoothly rolling the bike through the corners at speeds that would probably get us both arrested.
post #19 of 33 Old Jun 18th, 2009, 10:59 pm
Super Moderator
OR:
AND:
David Taylor
San Jose, CA
AMA, BMWMOA
Booze Brother #4
post #20 of 33 Old Jun 19th, 2009, 6:44 am
Spirit_Rider's Avatar
Just wait until your wife does you a "favor" and washes your bike and Armour-alls the seat! talk about sliding around. I had to wear a cup for two weeks until that stuff wore off.
Spirit_Rider is offline
post #21 of 33 Old Jun 19th, 2009, 7:57 am
RonKMiller's Avatar
Nah - you're about a year and a half behind what the current cover fabric is. Our new fabric - Polar Mesh - is completely hydrophobic. I ain't talking rabies here either.
Where Alcantara used to absorb water yet dry quickly, the new material allows water to drain completely through, then run off the waterproof polyethylene barrier below it. Then rain cover is built in.
You sit 4mm above any water - even in a heavy downpour.
Since there are no needle holes or seams in the cover there is no way for water to penetrate into the foam. The barrier is glued onto the seat in one piece.
Problem solved.
"Like Butt-ahh!"
post #22 of 33 Old Jun 19th, 2009, 8:10 am
RonKMiller's Avatar
[QUOTE=DavidTaylor
SPAM
[/QUOTE]
Hardly, just joining in on the conversation and bringing folks up to date on new, engineered solutions to old problems.
I guess you would prefer that Vendors who support this site (and btw, I was the very first one to do so) never comment on their products once in a while.
"Like Butt-ahh!"
post #23 of 33 Old Jun 19th, 2009, 8:56 am
messenger13_ver2's Avatar
The more things change ... the more they stay the same.
messenger13_ver2 is offline
post #24 of 33 Old Jun 19th, 2009, 12:34 pm
Super Moderator
Just poking at you with a stick, Ron. You did see the laughing smiley at the bottom, right??
David Taylor
San Jose, CA
AMA, BMWMOA
Booze Brother #4
post #25 of 33 Old Jun 19th, 2009, 12:41 pm
RonKMiller's Avatar
LOL - you got me right in the spokes!
"Like Butt-ahh!"
post #26 of 33 Old Jun 19th, 2009, 12:47 pm
RonKMiller's Avatar
Messenger 13: Lurker?
Say it ain't so!
"Like Butt-ahh!"
post #27 of 33 Old Jun 19th, 2009, 4:02 pm
THE Democracy Doctor
jayjacobson's Avatar
....Yes, and a tremendous amount of water, too. .....Yep - right up until it rains.
Nothing the matter with a monthly shower--whether you need it or not!
jayjacobson is offline
post #28 of 33 Old Jun 19th, 2009, 5:45 pm
OK Ron, I hadn't realized you had addresses the water issue. Good to know.
post #29 of 33 Old Jun 21st, 2009, 10:06 am
mdm_rides's Avatar
Well true I used to own an LT & didn't move much except when the centerstand started dragging, but as an old track day/sport bike/off-road guy I can't help but move around when in the tight stuff. Old habit that I probably wouldn't need to do I guess. Kind of like remembering not to try and steer with the rear on the pavement and not to use much front brake in the dirt. It may just be ADD & can't hold still for long.
In any event smooth, safe, fast, & upright means it's all good no matter who you are
post #30 of 33 Old Jun 21st, 2009, 7:32 pm
REWDOC's Avatar
Today I rode with the seat in the high position and my knees and legs seemed more comfortable, though I didn't ride but 28 miles. I'll have to try it on a longer trip soon.
Dick Wood
IBA #7393
REWDOC is offline
post #31 of 33 Old Jun 22nd, 2009, 8:15 pm
There's nothing wrong with moving around on the bike - it's just one more way to control the bike. It might not be necessary in normal circumstances, but keeping that skill honed could come in handy someday. It's probably good for the circulation, too.
neilgundel is offline
post #32 of 33 Old Jun 24th, 2009, 9:53 pm
mdm_rides's Avatar
May be because I still have the stock 07 seat
post #33 of 33 Old Jun 25th, 2009, 5:25 am
Say it ain't so!
That's ÜberLurker to you.
Raising the seat for tall guys pozo_izquierdo K1200LT 12 Jul 1st, 2013 7:27 pm
A Rick Mayer seat Testimonial (basicly a rant) atlmichael K1200LT 51 Aug 5th, 2009 12:41 pm
Corbin Seat W/Heat Triple Threat RT Series 15 Jun 21st, 2009 11:11 am
Rear Seat alstrickland55 Ergonomics & Rider Comfort 5 Apr 22nd, 2007 8:20 pm
Ari’s winter farkle projects part 4 (power seat height adjuster) pozo_izquierdo K1200LT 21 Apr 7th, 2006 11:45 am
