Used K1200r - BMW Luxury Touring Community
post #1 of 6 Old Jun 17th, 2009, 12:10 pm Thread Starter
spokane1200lt's Avatar
Used K1200r
I am thinking of purchasing a 2006 K1200R with 17000 miles on it. It has an after market exhaust, ABS. Anything I should look for when doing the pre buy inspection??
Al
Spokane WA
spokane1200lt is offline
post #2 of 6 Old Jun 17th, 2009, 2:51 pm
Super Moderator
DavidTaylor's Avatar
Re: Used K1200r
Assuming he has kept good service records (which I always take as a sign of a resonsible bike owner) ask for all of the service receipts for review to verify schedule maintenance was done correctly. This will also show any issues, service bulletins, etc. addressed. Look for scuff marks low on the bike. footpegs and such not so much but any scrapes low on the bike could indicate it has been down (sometimes folks only replace the damage higher on the bike, never got that). If he has it services at the local dealer talk to them about the bike and have them give it a once over before sealing the deal. If he still has the stock exhause make sure it comes with the deal, along with any other stock parts that have been removed/replaced.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #3 of 6 Old Jun 17th, 2009, 4:20 pm
seahabit's Avatar
Re: Used K1200r
While the LT is on center stand, rock rear wheel by grasping outer edge of tire and feel for unusual movement ( may as well check front wheel as well). Place face against floor, look up ( or use mirror ) and check for fluid leaks. If maintenance records aren't available, check clarity of fluids: oil, clutch, brake and coolant.
Then cross fingers, hand over the money, and ride like the wind.
seahabit is offline
post #4 of 6 Old Jun 18th, 2009, 1:21 am
Super Moderator
Re: Used K1200r
Uhhh.. the K1200R doesn't have a center stand, and isn't an LT.
David Taylor
San Jose, CA
AMA, BMWMOA
Booze Brother #4
post #5 of 6 Old Jun 18th, 2009, 10:43 am
seahabit's Avatar
Re: Used K1200r
Ooooops...
seahabit is offline
post #6 of 6 Old Jun 18th, 2009, 8:33 pm
Rider Journeyman
BillyOmaha's Avatar
Re: Used K1200r
Howdy David,
Wolfgang has a center stand (see below), it's an optional accessory.
Bill "Omaha"
BillyOmaha is offline
vibration and harshness -06 K1200R, S &GT 685ursus Other K-Bikes Discussion 15 Jun 29th, 2009 11:28 pm
K1200R opinions Josmas Bike Talk 6 Feb 5th, 2008 9:06 am
K1200R drag racing dshealey K1200/1300GT (The Next Generation) 6 Apr 29th, 2007 7:16 pm
Dyno run on K1200R RaffyK Other K-Bikes Discussion 10 Jan 25th, 2006 11:20 am
