06 K1200GT Power socket - BMW Luxury Touring Community
post #1 of 7 Old May 1st, 2009, 6:18 am Thread Starter
I am having problems with my power socket fiited as standard. The manual states it will cut out at over 8 amps.
I go touring quite a lot and use the power socket for a small compressor to pump up my air bed, I have to keep turning the ignition on and off, restaring the bike, etc. before it will work properly.
I also have a compressor to pump up tyres incase of puncture, i can only get this to work for about 2 seconds max before it cuts out and then it won't work again.
Does anyone know a way to cure this problem? http://www.bmwlt.com/forums/misc.php...=0&forumid=43#
GreyPaintSteve is offline
post #2 of 7 Old May 1st, 2009, 6:43 am
seahabit's Avatar
Re: 06 K1200GT Power socket
I have an LT with a similar situation. My plan is to install a 15 amp covered fuse block to the
positive on the battery, a common terminal for the battery negative, and connect these to
another power socket. I think quite a few guys have already done this.
seahabit is offline
post #3 of 7 Old May 1st, 2009, 8:16 am
Yup, I have 2 extra Powerlet outlets on the GT - one for my Gerbings jacket, one for the wife's. Both go thru a fuse directly to the battery. You can also use one of these new outlets to charge your battery with an ordinary charger. The only liability is that you can accidentally leave an electrical device on, even when the ignition key is off, and drain the battery. I've never done this ... yet.
- Bob
Cowboy Bob Menton
Greenville SC USA
bob_menton is offline
post #4 of 7 Old May 1st, 2009, 3:19 pm
coxreno745's Avatar
Intall power block to accommodate five or so accessories. see attached
File Type: pdf One of the best ways to connect various accessories to Canbus system.pdf (284.7 KB, 351 views)
David Cox
06 K12GT
09 K13GT
07 F800ST
coxreno745 is offline
post #5 of 7 Old May 1st, 2009, 3:46 pm
DavidTaylor's Avatar
Get another power socket and wire it directly to the battery. There are punchouts on the panel to mount more sockets and Powerlet makes the rest of the hardware.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #6 of 7 Old May 1st, 2009, 11:59 pm
PerfectSwitch's Avatar
Start-up current for a compressor motor, and other types of induction motors, usually pull three times the running current. So your 8 amp pump will pull about 20-25 amps at startup which is why the computer shuts it down. As others have said, run it directly from the battery and bypass the computer.
PerfectSwitch is offline
post #7 of 7 Old May 5th, 2009, 5:09 am Thread Starter
Thumbs up Re: 06 K1200GT Power socket
A BIG thanks to you all for your valuable help.
Battery charger through power socket 02lt K1200LT 13 May 6th, 2009 12:38 am
Peculiar power socket pdeseymour RT Series 8 May 5th, 2009 8:33 am
power socket jpgcycle K1200LT 8 Dec 18th, 2007 6:46 pm
Extra power socket fitting slparry K1200/1300GT (The Next Generation) 6 Nov 26th, 2007 11:18 am
