Battery or Alternator Issue? - BMW Luxury Touring Community
post #1 of 6 Old Dec 23rd, 2008, 12:29 pm Thread Starter
Have had a 2006 K1200GT mostly stored for the past two yrs pending retirement and it has been on a BMW charger most of that time. 1300 miles on it total. Took in for annual inspection and during the software check, the tech noted the battery was a bit down and put a charger on it. Afterwards I rode it for about an hour. When I put it up and placed the charger on it, the light was red. Overnight it changed to green. Not sure if this is just a worn out battery or how to check. Any suggestions? Thanks
Docsigmund is offline
post #2 of 6 Old Dec 23rd, 2008, 12:46 pm
Re: Battery or Alternator Issue?
You "may" not have a problem at all. My (non-BMW) trickle charger(s) always charge for a bit when first connected, then after a while sense that the battery is "charged" and fall back to trickle, turning the indicator to green.
I think there is a "solid state" checker available now, but not cheap, that can check the status of a battery in seconds. Or, you could use the old standby of putting a somewhat heavy load on the battery for a bit, and see if the battery voltage stays up. Your local BMW dealer likely has one or the other ways of checking it.
If the battery can reliably start the engine after sitting unused and off the charger for a couple of weeks, its likely the battery is fine.
Its very unlikely that you have any alternator issues with such low miles.
Ruben
2012 K1600 GTL
2007 R1200GS Adventure
Ruben is offline
post #3 of 6 Old Dec 26th, 2008, 4:30 pm
larrykay's Avatar
Sounds normal to me...Even after a long ride,, when I put the charge on, it starts off in the red position, then turns to green a short time later.
Larry
2009 Deep Blue K1300GT
larrykay is offline
post #4 of 6 Old Jan 26th, 2009, 9:17 pm
It is normal. Don't take tension.
kumarbike is offline
post #5 of 6 Old Jan 27th, 2009, 9:50 pm
cccpastorjack's Avatar
Originally Posted by Docsigmund
Have had a 2006 K1200GT.....1300 miles on it total.
Oh my gosh!!!! I finally found someone who rides LESS than me!!!!!!!!!!!!
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #6 of 6 Old Jan 28th, 2009, 6:36 pm
mdm_rides's Avatar
Let it sit a few days without the charger, test run it to make sure that you aren't running on a surface charge.
It really sucks to have it sit on the charger, start great in the garage and later in the day 3-500 miles from home go.......click....click.....click.
Ask me how I know.
mdm_rides is offline
My battery story. motorman587 K1200LT 3 Nov 26th, 2008 3:19 pm
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 10:11 am
