Draw on battery - BMW Luxury Touring Community
post #1 of 29 Old Sep 30th, 2008, 10:32 pm Thread Starter
REWDOC's Avatar
Draw on battery
Since this is GT specific, I'm posting it here instead of "Batteries, Electrical, Etc.". I have a Battery Tender Plus - Gel and a power plug direct to the battery for maintenance charging. I've notice that if I leave the GT unplugged for 30-60 mins, it take the BT Plus several hours to recharged the battery back to full charge (green light). Also, I've notice when I've come in from a ride, that the battery is not fully charged and is usually in the >90% charged range (blinking green light). Is this normal? It seems to me that the battery should be fully charged if I've been riding the bike, other than the time it take for the Canbus to shut down.
When I first got the bike the battery light would come on a few time while idiling at red lights. A couple of times, it seems hesitant to turn over, but did. I said something about this at the 600 miles service and the mechanic found the negative ground was not tight and tightened it. I've really not noticed the light come on or the hesitation since then, but it seems the battery discharges fairly rapidly when not connected to the BT-Plus. Don't know if this is problem or not, but concerned because I had it disconnected for about an hour and the BT has been charging for about 3-4 hours and it's still blinking green.
Dick Wood
Previous 1995 HD FXDL
IBA #7393
REWDOC is offline
post #2 of 29 Old Sep 30th, 2008, 10:47 pm
Re: Draw on battery
The new GT has a MONSTER alternator (940 watts) ... but unfortunately, BMW did not equip the bike with the greatest of OEM battery IMHO. I don't think you have any cause for concern at this time. But sometime down the road, you should invest in that Odyssey battery that everyone raves about. If I was keeping my GT, I'd be buying one next Spring.
post #3 of 29 Old Sep 30th, 2008, 10:55 pm
cccpastorjack's Avatar
Re: Draw on battery
Agree with Joe...I stored mine all winter with no batt tender and it cranked right up. You don't have any of those farkles running directly off the batt do you? If you leave them on, you will get a drain.
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #4 of 29 Old Sep 30th, 2008, 11:41 pm Thread Starter
REWDOC's Avatar
Re: Draw on battery
Nope, everthing is hooked to the switched fuse block. I was ready the owners manual and it sound like some circuit might be on it the bike if the key is not in the locked position. I usually leave mine unlocked since I keep in it the garage with the key in it.
Dick Wood
IBA #7393
REWDOC is offline
post #5 of 29 Old Oct 1st, 2008, 11:42 am
blankshot's Avatar
Re: Draw on battery
Hi Dick,
Mine does the same and I have all my electronics running from a switch power source. I checked for a current draw and found none. It maybe like everyone is saying and it's just a poor choice in a battery. But just like the good Pastor I left mine of the charger all winter and it fired up with just a couple of cranks.
Cheers,
Jim
MSF Rider Coach
Haverhill, MA
66 R50/2
92 R100R
07 Silver KGT
blankshot is offline
post #6 of 29 Old Oct 1st, 2008, 1:18 pm Thread Starter
REWDOC's Avatar
Re: Draw on battery
Originally Posted by blankshot
Hi Dick,
Cheers,
This morning when I went to check on the Battery Tender, it was still blinking green (should have been solid green by then). I called Deltran and they said something must be wrong in the Battery Tender Plus circuit and to send it to them and they would replace it. I've not been having good luck with electronic devices lately. Zumo went Kaput after 9 days and I had to do the same with it.
Dick Wood
IBA #7393
REWDOC is offline
post #7 of 29 Old Oct 1st, 2008, 1:24 pm
kk610lt's Avatar
Re: Draw on battery
Can you try it on another bike?
On my LT it will go to solid green after a while but my GS only goes as far as a flashing green.
Keith
kk610lt
2007 K 1200 LT
2004 R 1150 GS Adventure
2002 K 1200 LT (totaled by a SUV 10-7-08)
1988 Concours
Why do bullets bounce off of Superman, but he ducks when you throw a gun at him?
kk610lt is offline
post #8 of 29 Old Oct 1st, 2008, 1:28 pm Thread Starter
REWDOC's Avatar
Re: Draw on battery
Keith
Don't have another bike to try it on. Until last night it would alway go to green and stay there. It would usually blink for 10-15 mins after I connected it to the bike. The lady at Deltran said it takes that long for the charger to cycle through it's program and that it was abnormal for it to blink for 10 hours on a charged battery. I'll guess they'll test it when they get it and send it back if it's OK or replace it if it's not. I UPS'ed it to them today.
Dick Wood
IBA #7393
REWDOC is offline
post #9 of 29 Old Oct 1st, 2008, 5:06 pm
bonafidebob's Avatar
Re: Draw on battery
I've had similar issues with the stock battery. It seems a little underpowered in terms of being able to deliver current needed to start a hot bike. I've never had a problem starting when it's cold, but when it's hot I've occasionally had cranking problems and the accessory circuit (powering the GPS) shuts down briefly. The battery voltage was always good, showing 12.4 to 12.6 volts when I turn on the key.
I also talked with my dealer and had a bunch of diagnostics done. They found the alternator was strong, and the battery passed all the load tests. After some back and forth I persuaded them to replace the OEM battery under warranty, and things are better with the new battery but I still occasionally get a GPS reset when starting a warm bike.
I've got the stupidly expensive BMW charger rather than the Battery Tender, but I don't actually plug it in very often. When I do it also takes a while before it goes to green, showing the battery fully charged, even right after riding the bike. I always just chalked it up to the charger having to run its cycle before entering "trickle charge" mode.
Many others have recommended an aftermarket battery (Odyssey) which will provide more cranking power and presumably eliminate the hard start when hot problem. That's what I'll try next if the OEM battery starts to get worse again. I expect it would otherwise show the same behavior on the charger.
bonafidebob is offline
post #10 of 29 Old Oct 1st, 2008, 6:03 pm
fas
fas's Avatar
Talking Re: Draw on battery
Joe is right. BMW OEM battery has a nasty habit of going down fast, even if you have the best BMW trickle setup. Sills (my dealership) replaced two batteries for me under warranty.
And don't write about leaving your key in your new GT in your garage. Joe might drop in, take it for a ride to CA, and blow out your rear drive... He does not drop bikes. He blows them up...
Rob Nelson
Grey Goose
Toscana Temptress
fas is offline
post #11 of 29 Old Oct 1st, 2008, 7:40 pm
Re: Draw on battery
I do generally store mine with key in...but in the locked position. A learned habit from the LT! If you left that sucker in ANY position for more than a couple of weeks, it was dead as a hammer.
Jack Homesley
Cornelius, NC USA
post #12 of 29 Old Oct 1st, 2008, 9:50 pm
PerfectSwitch's Avatar
Re: Draw on battery
There's likely a difference between the alternator's voltage regulator setpoint, and the Battery Tender's float setpoint. So when you get back from a ride and immediately hook up the BT, IT indicates the battery is not fully charged when in fact the battery is fine. Quite frankly, I don't understand why you hook up the battery to the charger the second you get home. I ride my bike every Friday to work, and if I can't ride it for a few weeks, then I'll throw the charger on it overnight where it charges at a rate of 2 to 5 amps until the battery voltage and current trips the charger off. I can appreciate the concept of the battery tender, but I wouldn't get too concerned about BT indicating less than 100% charge upon return from riding.
PerfectSwitch is offline
post #13 of 29 Old Oct 3rd, 2008, 8:28 am Thread Starter
REWDOC's Avatar
Re: Draw on battery
Originally Posted by PerfectSwitch
There's likely a difference between the alternator's voltage regulator setpoint, and the Battery Tender's float setpoint. So when you get back from a ride and immediately hook up the BT, IT indicates the battery is not fully charged when in fact the battery is fine. Quite frankly, I don't understand why you hook up the battery to the charger the second you get home. I ride my bike every Friday to work, and if I can't ride it for a few weeks, then I'll throw the charger on it overnight where it charges at a rate of 2 to 5 amps until the battery voltage and current trips the charger off. I an appreciate the concept of the battery tender, but I wouldn't get too concerned about BT indicating less than 100% charge upon return from riding.
Now that I'm getting older, I have to do things when I think about them or I'm liable to forget to do it. I think I will be riding the GT much more often than the LT, but I would go for up to 6 weeks without riding my LT. So, I got in the habit of hooking up the BT everytime I returned from a ride.
Dick Wood
IBA #7393
REWDOC is offline
post #14 of 29 Old Oct 8th, 2008, 6:14 pm Thread Starter
REWDOC's Avatar
Thumbs up Re:Deltran
Well, I called Deltran about my 2 weeks old Battery Tender Plus which was acting funny. I think the pizza delivery man stepped on it. I called Deltran and told them about it. They lady just said: "Pack it up, send it to us, and we'll send you a new one". She also gave me the website address of a company close to me that could provide me with a 12' BMW extension power cord, so I wouldn't have to leave the BT sitting in the middle of the garage floor. She said I could get it from them for less than she could send it to me because Deltran had a higher minimum for shipping. I sent the BT back to them last Wednesday and received a brand new one today. Now that's excellent customer service!
Dick Wood
IBA #7393
REWDOC is offline
post #15 of 29 Old Oct 8th, 2008, 7:33 pm
Re: Draw on battery
Hey Doc,
It sounded earlier like you have your tender hooked directly to the battery. Is this the case? And is so, why would there need to be a 12' BMW specific extension cord??? I have heard of several folks having a problem if they used a BMW style connector.
But...I bet you have that extra powerlet wired directly to the battery, don't ya?
Jack Homesley
Cornelius, NC USA
post #16 of 29 Old Oct 8th, 2008, 10:27 pm Thread Starter
REWDOC's Avatar
Re: Draw on battery
Hey Doc,
I meant to say BMW style. It's a 12' cord with the Gerbing style two prong adaptors on both ends. It plugs into the BMW male adaptor cord that I plug into to power socket connected directly to the battery. They other end connects to the 4' cord on the BT giving me 16' of cord from the charger to the bike.
Dick Wood
IBA #7393
REWDOC is offline
post #17 of 29 Old Oct 10th, 2008, 1:18 pm Thread Starter
REWDOC's Avatar
Re: Must have a bad battery
Well, the brand new Battery Tender Plus which Deltran sent me still will not show a full charge after 48 hours. Talked with them again and they said there has to be something going on with the bike.
Called BMW ATL and talked with Paul who told me it's probably the BMW Gel battery and to bring it back and they'll replace it with an Odyssey Battery! Wow, now that it just plain ole down right good ole country small town service. I gotta tell ya, BMW of Atlanta is a wonderfull dealership. I'll not go into all the other things they've done for me, cuz if you been readin' the site for long, you'll know.
If you live anywhere close to Atlanta, you should be using BMW of Atlanta.
Dick Wood
IBA #7393
REWDOC is offline
post #18 of 29 Old Oct 10th, 2008, 1:41 pm
grifscoots's Avatar
After putting in the new O2 Sensor, which cured the flat spots in my fueling map and some surging, I slapped it on the GS-911. It showed an under current fault, which I cleared. I haven't put the GS-911 on it since putting the new Odyssey in it. The gel battery just isn't up to snuff for these bikes. You'll be surprised how it turns over.
Also, you need to get a Datel Digital Voltmeter.
-=grif=-
Grok
grifscoots is offline
post #19 of 29 Old Oct 10th, 2008, 1:55 pm
Re: Draw on battery
I installed this...
www.lascarelectronics.com
post #20 of 29 Old Oct 10th, 2008, 4:06 pm Thread Starter
REWDOC's Avatar
Thanks Grif,
Where did you mount yours?
Dick Wood
IBA #7393
REWDOC is offline
post #21 of 29 Old Oct 10th, 2008, 4:06 pm Thread Starter
REWDOC's Avatar
Re: Draw on battery
I installed this...
I'll take a look at it.
Dick Wood
IBA #7393
REWDOC is offline
post #22 of 29 Old Oct 10th, 2008, 4:14 pm
grifscoots's Avatar
Originally Posted by REWDOC
Thanks Grif,
If I had it to do over I would put it high up on the inner fairing. Direct sun washes it out, which hasn't been a problem, really. It is fun watching the numbers change with use of blinkers, etc.
-=grif=-
Grok
post #23 of 29 Old Oct 13th, 2008, 11:03 pm
Re: Draw on battery
OK, which Odyssey battery fits the GT? I had one occasion (only once) when the bike didn't want to crank on the first try (hot engine).
- Bob
Cowboy Bob Menton
Greenville SC USA
bob_menton is offline
post #24 of 29 Old Oct 14th, 2008, 6:08 am
grifscoots's Avatar
Re: Draw on battery
- Bob
Damn newbies asking the same question over and over again
It's a PC680 (as found in the HoW on www.k-bikes.com) you can use the MJ version, if you wish.
The two rubber spacers on the hold down come off, or you can shim it.
-=grif=-
Grok
post #25 of 29 Old Oct 14th, 2008, 4:59 pm Thread Starter
REWDOC's Avatar
Re: Draw on battery
- Bob
Hi Bob,
Grif's right about the battery. BMW ATL just changed my 4 week old BMW Gel battery today, under warranty, to the Odyssey PC680. It is smaller than the BMW battery, however. It has about a 1/4" of loose room on two sides. We just put some cardboard shims in there so it wouldn't flop around. I'm going to cut some styrofoam shims to replace the cardboard. I don't know if water will get into the battery box or not, but I don't want soggy cardboard hanging around in there.
Here's a link for the battery:
http://www.batterymart.com/c-bmw-k1200lt-battery.html
Dick Wood
IBA #7393
REWDOC is offline
post #26 of 29 Old Oct 14th, 2008, 6:38 pm
Re: Draw on battery
Ok, but where's the best place to buy one?
I had my battery go dead once (I was working on the bike the day before), and I've had the hard-starting-when-hot happen twice now. Time for a new battery before I get stranded on this bike (again).
post #27 of 29 Old Oct 14th, 2008, 7:22 pm
grifscoots's Avatar
Re: Draw on battery
I'm not sure if you're serious... or not. But West Coast Battery has always been good to me. Good folks, nice, friendly and knowledgable. You can even talk to them on the phone if you have questions. Did I mention best price, too?
-=grif=-
Grok
post #28 of 29 Old Oct 15th, 2008, 6:34 am Thread Starter
REWDOC's Avatar
Re:Original battery was bad.
BMW ATL replaced my BMW gel battery with an Odyssey PC680, yesterday, even though the BMW battery past the load test. However, there still must have been something wrong with it, as I hooked up the Battery Tender Plus to the Odyessy yesterday afternoon when I got home. It blinked green for 8 hours, then turned solid green like it's suppose to. The last two times I left the BMW battery hooked up for over 72 hours and the BT never quit blinking green.
BMW ATL rocks!
Dick Wood
IBA #7393
REWDOC is offline
post #29 of 29 Old Oct 15th, 2008, 7:59 am
ibbones's Avatar
Re: Draw on battery
Alright Dick, glad you got it all figured out now. Battery problems are tough to figure out.
"BONES" <///><
2018 R1200RT
2002 K1200LTC--- Belle
ibbones is offline
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 10:11 am
Dog-Gone battery charger question! Yuck! wardenross K1200LT 17 Oct 24th, 2006 1:31 pm
