Centre Stand - BMW Luxury Touring Community
post #1 of 8 Old Jul 18th, 2008, 5:37 am Thread Starter
slparry's Avatar
Centre Stand
I understand early K-GT's had an issue with centre stands? Mine is a Spet 07 model and I've notived the stand arm is touching the floor, can't recall it being like that when I had it so OI'm now concerned it may be bending.
What's everyone else's like?
slparry is offline
post #2 of 8 Old Jul 18th, 2008, 8:36 pm
bonafidebob's Avatar
Re: Centre Stand
Here's a good post on the subject from a different board: http://www.bmwsuperbikes.com/forum/v...1a6f79d2d6736e
I think BMW is aware of the problem. The centerstand itself isn't bent, but the brackets that stop it from moving past vertical will bend, which leads to all kinds of bad things -- hard to get off the center, crack the fairing, etc.
Take it to a dealer and make them fix it.
bonafidebob is offline
post #3 of 8 Old Jul 18th, 2008, 11:53 pm
Re: Centre Stand
The end of the stand arm on my late-version 2007 GT definitely touches the floor, but it looks like it was designed to do that.
The stand arm itself arches slightly from the base of the center stand to the end. At the end of the stand arm is small bent plate. The curve of the bent plate is the part that touches the floor. It all looks normal to me.
The GT center stand has never felt that strong, especially compared with the stand on the '86 Magna, which was rock solid. For example, the GT stand flexes when I set the handlebars left or right to lock them. In my opinion, it should be completely rigid, no matter what I do.
I will be at the dealer's tomorrow, and will look at their GT center stands.
XMagnaRider is offline
post #4 of 8 Old Jul 19th, 2008, 5:22 am
Re: Centre Stand
Well, mine bent further and further forward over time then finally broke completely, causing me to drop the bike. See this thread for pics. That was at 24K miles.
At 52K miles, it broke again, in the exact same place. It's really gonna suck if I have to replace this thing every 6-9 months.
post #5 of 8 Old Jul 19th, 2008, 5:30 pm
Exclamation Re: Centre Stand
Steve,
Here is a picture of my centre stand. The arm touches the ground. The GT is a very early 06 (#68 USA) build date of March 06. The stand and stops are original.
Hope this helps.
norriscooper is offline
post #6 of 8 Old Jul 19th, 2008, 5:41 pm Thread Starter
slparry's Avatar
Re: Centre Stand
Phew ... thanks for that Norris
Bit of a pain tho' as I'm about to paint the floor in my garage and the footplate on the stand is going to dig into the floor at every use, I'll have to get a foot square by 1/2" piece of plywood to rest the bike on I think.
slparry is offline
post #7 of 8 Old Jul 19th, 2008, 9:00 pm
Re: Centre Stand
I use a thick rubber mat.
post #8 of 8 Old Jul 20th, 2008, 12:33 am
Re: Centre Stand
There were four K1200GTs at the dealer's, all on their center stands. All were identical to my K1200GT, exactly as pictured by Norris.
There were small pieces of carpet underneath each center stand, to protect the floor. The center stand arms projected past the carpets, but floated just above the floor without touching it, even though the carpet was thin. That will solve your problem.
REPORT: Retrofit '01 with a Power Center Stand midwilshire K1200LT 55 May 10th, 2016 11:51 am
K1200LT Centre stand BruceFPrichard K1200LT 3 Nov 7th, 2007 11:00 am
electric centre stand for LT1200 jusufbw K1200LT 5 Sep 4th, 2007 5:59 pm
Electo Hydraulic centre stand failure Hitman_LT K1200LT 5 Apr 11th, 2007 3:38 pm
Centre Stand Modification beamerles K1200LT 7 Aug 23rd, 2006 10:23 am
