2008 1200GT oil change. - BMW Luxury Touring Community
post #1 of 14 Old May 26th, 2008, 10:48 am Thread Starter
Having been riding R bikes for 20 some years I have come over to the dark side of the "K" bikes. Does anyone know where I can get info on changing the oil on a 2008 K1200GT?
Pat Patteson
Desertbum is offline
post #2 of 14 Old May 26th, 2008, 10:52 am
Super Moderator
DavidTaylor's Avatar
Re: 2008 1200GT oil change.
Go check out our sister site - www.k-bikes.com. It's focused more on the newer K engine and I would guess you could find some information there. Check the Hall of Wisdom located under the "Technical" link at the top of the page.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #3 of 14 Old May 26th, 2008, 10:53 am
grifscoots's Avatar
Pat Patteson
www.k-bikes.com right in the Hall of Wisdom, specifically:
http://www.k-bikes.com/forums/faq.ph...ew_faq_engines
-=grif=-
Grok
grifscoots is offline
post #4 of 14 Old May 26th, 2008, 11:01 am
Beemerider's Avatar
Think I'd start with the owner's manual...
Ride On!
Goodyear, AZ
"Yeah but its a warm heat!"
'13 SILVA K1600GTL
Beemerider is offline
post #5 of 14 Old May 26th, 2008, 11:19 am
grifscoots's Avatar
The owner's manual is good, but doesn't mention using an earplug to plug the straw while pulling it down from the tank.
The sites (bmwlt, k-bikes) really beat any manual as you get replies about hands on experiences and gotcha's.
-=grif=-
Grok
post #6 of 14 Old May 26th, 2008, 1:06 pm
It also doesn't tell you to grab some aluminum foil and use it to keep from getting oil on your pipes.
post #7 of 14 Old Nov 11th, 2008, 9:18 pm
REWDOC's Avatar
Question Re: 2008 1200GT oil change with electric pump
I have an electric oil pump I use to change the oil on my boat. Can I use it to suction the oil out of the GT oil tank and thus avoid all the mess and trouble?
Dick Wood
Previous 1995 HD FXDL
IBA #7393
REWDOC is offline
post #8 of 14 Old Nov 11th, 2008, 9:58 pm
grifscoots's Avatar
Sure. You'll have to remove the basket that lives in the opening of the oil tank. Little fingers that press in to remove it. I broke the stays off mine so it just lifts out without having to play any games. Makes putting the oil in it easier.
Actually, draining the oil from the tank isn't the messy, or even hard part. The filter is the messy part. Make, or use something to direct the oil off the pipe, I use aluminum foil.
Don't forget to pull the plug on the pan under the engine.
-=grif=-
Grok
post #9 of 14 Old Nov 12th, 2008, 9:34 am
REWDOC's Avatar
Thanks, Grif.
Dick Wood
IBA #7393
REWDOC is offline
post #10 of 14 Old Jan 2nd, 2009, 7:18 pm
Just a tip from my personal experience:
Do not buy a Ilium works oil filter wrench.
It does not fit either an '07 nor '08 K1200GT.
Ask me how I know.
Best,
Bill
Bsquared is offline
post #11 of 14 Old Jan 2nd, 2009, 7:36 pm
cccpastorjack's Avatar
Thanks pal...I just use my channelock oil filter pliers...work great!
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #12 of 14 Old Jan 2nd, 2009, 9:48 pm
Yep, these work for me, too. Just don't go all gorilla when putting the new filter in.
post #13 of 14 Old Jan 2nd, 2009, 10:47 pm
Yep...and probably a WHOLE lot cheaper than anything made by some exotic european company....
Jack Homesley
Cornelius, NC USA
post #14 of 14 Old Jan 2nd, 2009, 11:00 pm
grifscoots's Avatar
I use the same thang, but they're not as nice looking.
Psst... the fancy oil change socket WILL work, you just have to remove the shift linkage. But why add another step?
-=grif=-
Grok
'04 GT engine oil change. Dick Other K-Bikes Discussion 2 Apr 26th, 2008 8:07 pm
oil change 2007 lt wstalker K1200LT 2 Apr 17th, 2008 8:12 pm
Oil Change Wrench for LT? Bighopper K1200LT 5 Mar 22nd, 2008 6:58 am
Thinking of getting a spare Final Drive after seeing muddy oil at oil change MattKas K1200LT 3 Feb 11th, 2008 3:51 pm
Oil Change country-bum K1200LT 4 Jan 19th, 2008 10:28 pm
