The brake pad 'wear sensors' on the GT... - BMW Luxury Touring Community
post #1 of 13 Old Apr 6th, 2008, 11:37 pm Thread Starter
Question The brake pad 'wear sensors' on the GT...
Any way to simply eliminate these silly things? Frankly, I view these things as nothing more than a point of failure waiting to happen. Brake pad inspection on a bike is so simple, I just don't 'get it'.
I'm getting ready to change the rear pads and wonder if anyone has eliminated theirs as of yet? I guess I could just zip-tie them up out of the way. Hhmmn...
post #2 of 13 Old Apr 7th, 2008, 6:00 am
®win's Avatar
Re: The brake pad 'wear sensors' on the GT...
Yes, as long as the loop created by these wires is not interrupted.
Erwin
R1200GS Adventure LC 2018, Blackstorm/Schieferdunkel Matt/Achatgrau (Triple Black), in full options, BMW Navigator V
R1200GSA LC '18 <- R1200GSA LC '14 <- K1600GTL '12 <- R1200GS Adventure '09 <- K1200GT '07 <- K1200LT '05 <- K1200LT '99 <- K1100LT '95 <- K75RT '92
®win is offline
post #3 of 13 Old Apr 7th, 2008, 6:33 am Thread Starter
That's what I thought. I could just splice the current sensors together, I suppose.
post #4 of 13 Old Apr 7th, 2008, 6:43 am
®win's Avatar
Don't know what you mean by that. There is one sensor at the front brake and one at the rear brake. The sensor is nothing more than a two core wire where the ends are connected into a piece of plastic. Just remove the piece of plastic from the brake pad and zip tie the wire somewhere onto the frame where it can't be damaged. That way you'll keep the loop intact and the wire won't break by wear.
Erwin
®win is offline
post #5 of 13 Old Apr 7th, 2008, 7:39 am Thread Starter
The sensor on my rear pads was a bit worn, but not down to the wire. But just to make sure, I could cut that sensor portion off and splice the two wires together so that the circuit is completed.
When I sell the bike, I will have to advise the buyer of my alteration ... or simply install a new sensor.
Thanks for the confirmation.
post #6 of 13 Old Apr 7th, 2008, 7:55 am
grifscoots's Avatar
Or, unplug it and stick a piece of wire in the plug at the bike end.
-=grif=-
Grok
grifscoots is offline
post #7 of 13 Old Apr 25th, 2008, 12:07 pm
blankshot's Avatar
How many miles did you go before the brake light came on? Mine just did it at 8500 and the sensors don't look like they are rubbing yet, but close. I hope this is not a trend with brake pad wear, 2 sets of pads to a set of tires.
Jim
MSF Rider Coach
Haverhill, MA
66 R50/2
92 R100R
07 Silver KGT
blankshot is offline
post #8 of 13 Old Apr 25th, 2008, 12:30 pm
grifscoots's Avatar
I've got 20k with the light never coming on, nor changing pads.
-=grif=-
Grok
post #9 of 13 Old Apr 25th, 2008, 2:25 pm
Sounds like the known problem of the sensor wire breaking but the pads still being good. Take it to your dealer for a warranty fix.
post #10 of 13 Old Apr 25th, 2008, 6:19 pm
It happened to my K1200GT at 5400 miles. I visually inspected the brake pads and they look brand new. Warranty repair is scheduled on Tuesday. 'Course, I never use the brakes. I just swerve around all the obstacles: http://www.youtube.com/watch?v=SbY0Jh9_RJ8
XMagnaRider is offline
post #11 of 13 Old May 20th, 2008, 8:53 am
I have had my bike back at the dealer 4x and they can not seem to get the brake sensor light to go away. They have tried replacing the sensor (rear) and I have pulled the sensors off the brake pads and tied them up, but the sensor comes back on within 10 miles after clearing it. Neither of the sensors have worn through the plastic and wire. My gt has 24K miles. I am beginning to believe we are barking up the wrong tree. there must be a bad wire or connector in the system? In any case, I am getting an attitude about bmw developing an answer when there was no question. Visual inspection of the brake pads is easily done and part of the service. Just like the electronic oil check. It is pretty tough to LOOK at a oil sight glass! I think maybe i bought the wrong motorcycle and need to find a brand that will "keep it simple".
stevemartin is offline
post #12 of 13 Old May 20th, 2008, 11:05 am
®win's Avatar
Not the plastic end is the culprit, but the wire to it is. It is zip-tied too tightly, causing the wire to break. Your dealer will either have to repair the wire or replace it. Only then they must reset the computer. Failing to repair / replace the wire will let the light come on time after time...
Let them check both front and rear brakepad wear indicators.
Erwin
®win is offline
post #13 of 13 Old May 20th, 2008, 8:16 pm
fas
fas's Avatar
Talking Re: The brake pad 'wear sensors' on the GT...
Pad thickness is easy to inspect. But, be mindful of tapered wear, both axial and radial. As long as you have warranty coverage, get the thing fixed at the dealership.
Rob Nelson
Grey Goose
Toscana Temptress
fas is offline
Rather longish, but good tips & info! vvk Bike Talk 7 Jun 19th, 2011 4:43 pm
brake pad wear indicator light HowardRichman K1200/1300GT (The Next Generation) 1 Oct 10th, 2007 9:20 pm
Rear Brake Disc (Rotor) Wear alanprorib K1200LT 3 Nov 8th, 2006 3:06 pm
No brake pad wear . . . dfinazzo K1200LT 13 Jul 18th, 2006 12:08 am
Holding Brake at Stoplight - Will it wear out Servo Assist motor? Toolman K1200LT 16 Apr 1st, 2006 6:53 am
