GT Sealed Final Drive - BMW Luxury Touring Community
post #1 of 11 Old Feb 23rd, 2008, 11:42 am Thread Starter
avonfloater's Avatar
Cool GT Sealed Final Drive
Any breaking news as to whether BMW intends to modify the GT final drive to add a drain plug?
Denny
avonfloater is offline
post #2 of 11 Old Feb 23rd, 2008, 12:12 pm
Re: GT Sealed Final Drive
I've heard some of the '08 bikes come with a drain plug. Not sure which models though. And I doubt they'd modify existing drives, so you'd have to buy a new housing. Preferably wrapped around a whole new bike, if BMW has any say in the matter.
post #3 of 11 Old Mar 7th, 2008, 7:36 pm
cccpastorjack's Avatar
I have a special (large) syringe with some thin tubing so I can remove the old fluid, flush it out with some new and then refill it withing 30 minutes without ever having to remove the final drive to drain. Works like a champ!
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #4 of 11 Old Mar 7th, 2008, 7:58 pm
That's how my dealer (Touring Sport) does it, Jack, but they've got the system automated: they use a vacuum device driven by their shop compressor to get the old fluid out. Works great.
- Bob
Cowboy Bob Menton
Greenville SC USA
bob_menton is offline
post #5 of 11 Old Mar 7th, 2008, 8:47 pm
- Bob
Cool...I've got my friend that makes tools working on something like that too. I am hoping it will work well.
Jack Homesley
Cornelius, NC USA
post #6 of 11 Old Mar 8th, 2008, 7:21 am
bruce2000ltc's Avatar
Can you describe your procedure in more detail? Sounds like a great idea.
Bruce Hodges
bruce2000ltc is offline
post #7 of 11 Old Mar 8th, 2008, 10:00 am
Super Moderator
DavidTaylor's Avatar
My 08 GT appears to be sealed; no drain plug in the bottom. I guess Jack might make a few bucks on his "sucker/filler" contraption once it gets finished!
Seriously, if you end up with an easy to use solution you should think about marketing them.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #8 of 11 Old Mar 8th, 2008, 10:07 am
Jack
Do you have a pic of that tubing? I tried to use a very small diameter tubing and it still wouldn't fit. If you have something that works that easy, I'll prolly change my final drive fluid every oil change (6000m). I changed it on my Wing every other oil change and never had a problem with well over 100k on the clock.
If you friend comes up with a solution, how about a group buy?
JamesM is offline
post #9 of 11 Old Mar 8th, 2008, 10:56 am
I'll get a pic of it up soon. (I can't find the syringe and tubing right now )
The following is from an earlier post:
Just changed mine using a really large syringe with a long piece of small diameter (1/8") tubing attached. Did it through the drain hole!
Fed the tubing down to the very bottom of the drive, sucked it all out real good...added a little fresh gear oil...turned the wheel a few times...let it settle and sucked that small portion out...then refilled with with 220ml of fresh fluid (and on my 07 GT 220 ml filled it to just beginning to run out of the drain hole) buttoned it up and was ready to go in less than 25 minutes. No rear drive removal!!!! Worked like a champ!
Jack Homesley
Cornelius, NC USA
post #10 of 11 Old Mar 8th, 2008, 5:47 pm
I'll see if I can find some 1/8", the tubing that I had was more like 1/4" and wouldn't fit around the gears.
JamesM is offline
post #11 of 11 Old Mar 13th, 2008, 10:40 am
Last week while at Daytona Bike week, I test rode a
K1200GT. The final drive had a 6 o'clock drain plug and
4 o'clock filler plug. I took this as good news in that
possibly BMW has changed & improved the problematic FD's and also made fluid service easier. However, when I checked with the local dealer here in Canada, the 2008 GT they had on display did not have the same FD, there was only a 3 o'clock drain?
They claim there has been no change in FD's and could not explain why I saw otherwise on the 2008's in Daytona.
If anyone owns or has seen the FD drain configuration on a 2008 bike, please advise if you are seeing this change?
The 2008 LT on the floor however did have these drain plugs! Something is going on and BMW is not being forthcoming.
bhewson is offline
Final Drive failure - no BMW warranty support BobbyLT K1200LT 28 Aug 21st, 2014 3:14 pm
Final Drive failure...05LT....49,000 miles DRothermel K1200LT 51 Jan 3rd, 2012 3:08 am
Sealed for life final drive - any thoughts? brianbeemer RT Series 21 Sep 13th, 2007 9:17 pm
So what is a final drive worth ? Patric K1200LT 12 Jun 27th, 2007 3:47 pm
Final Drive Seal @ Drive Shaft Crestwood330 K1200LT 3 Jun 25th, 2007 7:58 pm
