re-visit pad wear sensor ! - BMW Luxury Touring Community
post #1 of 8 Old Nov 10th, 2007, 9:12 pm Thread Starter
EzyMount's Avatar
Thumbs down re-visit pad wear sensor !
yep, factory design sucks. good intentions, but does not work worth a flap !
with a little over 6K on odo and careful breaking habits, my warning is also on !
i'll take Griff's advice and put a square of black vinyl tape over the sucker
Jim Lawson 2016 R1200RT
Retired to NC !
EzyMount is online now
post #2 of 8 Old Nov 10th, 2007, 11:52 pm
Florian's Avatar
Jim,
The design is good, its the assembly that sucks. My light went off 3 times before my pads got changed. Seems that the zip-tie that holds the harness is too tight and as your pads wear, even minimally, there isnt enough room for the harness to 'give' which in turn fatigues the wiring between the harness and brake pad and leads to intermittant shorts....
DAMHIK
F
BMWMOA
12 GTL
Florian is offline
post #3 of 8 Old Nov 11th, 2007, 12:03 am
My rear pads wore beyond the point when I should've been warned. No assembly issue here, the wear status just didn't work.
post #4 of 8 Old Nov 11th, 2007, 8:40 am
grifscoots's Avatar
You can also unplug the sensor harness and jump across the two points in the plug. I've still to hear if the GS-911 will reset a brake fault. One guy said it wouldn't, but he hadn't fixed the problem yet.
-=grif=-
Grok
grifscoots is offline
post #5 of 8 Old Nov 11th, 2007, 8:58 pm
Florian's Avatar
were talkin fronts...
F
BMWMOA
12 GTL
Florian is offline
post #6 of 8 Old Nov 11th, 2007, 8:59 pm
Florian's Avatar
Grif,
GS-911 doesnt reset the fault....I tried, no joy.
F
BMWMOA
12 GTL
Florian is offline
post #7 of 8 Old Nov 11th, 2007, 9:38 pm
I had this happen on my GT - dealer fixed it under warranty. The service techs now know the problem, and do a better job of installing the zip-ties.
- Bob
Cowboy Bob Menton
Greenville SC USA
bob_menton is offline
post #8 of 8 Old Nov 12th, 2007, 9:36 pm
I had the front brake sensor wire break and it was fixed under warranty.
Much later I had the light come on again and assumed it was the same problem. Turns out it was the rear sensor, and the pads were significantly worn. Unfortunately, I was in the middle of a 30-hour rally running up and down some pretty steep mountains and by the time I got a chance to swap the pads out they were toast.
So sometimes the sensors do work as advertised.
meese is online now
Help, O2 sensor cables mixed! pozo_izquierdo K1200LT 4 Oct 20th, 2015 10:24 pm
Wasn't the O2 sensor. Gene_Chapman K1200LT 2 Oct 9th, 2006 1:49 am
O2 Sensor Replacement STYLNLT K1200LT 3 Sep 27th, 2006 11:02 am
Rear Drive Speed Sensor dgl57 K1200LT 12 Jan 13th, 2006 5:08 am
Measured Metzler tire wear Moonshine Tires 3 Dec 2nd, 2005 3:21 pm
