Loose Panniers of K12Gt? - BMW Luxury Touring Community
 1Likes
  • 1 Post By meese
post #1 of 3 Old May 3rd, 2019, 4:16 pm Thread Starter
The panniers on my 07 k12gt seem a bit loose. They've been like that since I bought the bike nearly 8 months ago, but I'd like to know of there are any solutions out there to get them to fit a bit tighter. I'm 200% sure they're latched properly. Any input will be appreciated.
Thanks!
eliastfk is offline
post #2 of 3 Old May 3rd, 2019, 4:31 pm
Re: Loose Panniers of K12Gt?
BMW released Service Bulletin # 46 006 07 (059) "Play at Saddlebag Mounts" on this problem.
Go to the K1200GT parts diagram, click on 46-Frame, Fairing, Cases, and scroll down to diagram 46_1367 - CASE, LOWER PART.
Part # 22 46 54 7 699 847 SUPPORT $12 is what pushes up against the bottom of the side case rail and keeps things tight.
Note that the diagram also shows part # 22 46 54 7 712 002 SET: SET OF CLAMPS WITH BRACKET $8, which I believe gives you several different height options so that you can choose the one that fits snug, but not too tight.
No, I don't know why one piece is listed at $12, and a set of 4 is listed at $8.
I'd have your local dealer check the service bulletin listed above to be sure.
Or just order the 46 54 7 712 002 kit, as it's not all that expensive.
eliastfk likes this.
post #3 of 3 Old May 3rd, 2019, 4:47 pm Thread Starter
On it. Thanks!
eliastfk is offline
Loose Screws? hopz RT Series 46 Feb 2nd, 2016 5:38 pm
99 R1100RT shift lever gets loose? biometrics RT Series 3 Oct 11th, 2011 6:06 pm
Protecting Panniers Zardoz RT Series 4 Aug 18th, 2011 1:27 pm
00 Speedo jerky, Sensor Ring loose jello4 K1200LT 16 Oct 1st, 2010 11:14 am
Loose rear rotor Billmer K1200LT 14 Jun 1st, 2007 10:53 pm
