BMW Luxury Touring Community
BMW Luxury Touring Community (https://www.bmwlt.com/forums/)
-   K1200/1300GT (The Next Generation) (https://www.bmwlt.com/forums/k1200-1300gt-next-generation/)
-   -   k1200gt clutch bleeding process. (https://www.bmwlt.com/forums/k1200-1300gt-next-generation/182643-k1200gt-clutch-bleeding-process.html)
eliastfk Apr 13th, 2019 10:53 am
Does anyone have a good step by step guide to bleeding the clutch on a k12/13gt? I just replaced the clutch, and it runs great but I figure I should show the fluid some attention. Is the bleed screw that tiny little one on the outside of the slave cylinder? Any input would be greatly appreciated.
Thanks!
jzeiler Apr 13th, 2019 1:23 pm
Re: k1200gt clutch bleeding process.
The BMW manual has you remove the grub screw and install a bleeder on the slave. It then has you connect a syringe to the bleeder and suck the old fluid out (open the reservoir cover). Next you use that same syringe to back fill the slave until the handle bar reservoir is full. This one uses mineral oil not DOT 4 brake fluid.
TF1200RT Apr 14th, 2019 8:28 pm
1 Attachment(s)
Here you go again.
BMW Luxury Touring is powered by: vBulletin Version 3.8.8
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
VerticalScope Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
