07 k1200gt Clutch Replacement Specialty Tools? - BMW Luxury Touring Community
 2Likes
  • 1 Post By bmwcoolk1200
  • 1 Post By beech
post #1 of 7 Old Mar 19th, 2019, 11:45 am Thread Starter
I got a private message about a user that is willing to lend me the tools. Unfortunately, I have not posed enough to be able to respond. So will someone please send me a personal email to e l i a s t f k @ g m a i l . c o m (no spaces).
thanks!
eliastfk is offline
post #2 of 7 Old Mar 19th, 2019, 1:20 pm
bmwcoolk1200's Avatar
Re: 07 k1200gt Clutch Replacement Specialty Tools?
thanks!
Run your count up here. Keep posting till you have enough.
eliastfk likes this.
Gordon
Sugar Hill, GA
[SIGPIC][/SIGPIC]
bmwcoolk1200 is offline
post #3 of 7 Old Mar 20th, 2019, 1:46 pm
beech's Avatar
I think you only need the clutch basket wrench and a thin wall 30mm socket. I use the Facom brand deep 12 point socket available on Amazon for a reasonable price. It is one thickness of electrical tape smaller that the spring pressure plate access hole. This allows you to put that tape on and line up the plate with the center bore (the nut). The crank lock device I used it but I don't remember if it really helped. I carefully blocked the handle of the basket holding tool so there was no movement of it. But that tool costs 96$, the wrench for the basket was near 100$'s. There are several threads on the job if needed. Using the factory tool on the drive scissor gear is less than ideal. I ended up with a drill bit in the hole. If you remove the basket this is part of it all. If you just change out the plate pack with out removing the basket many things are avoided. Here is a thread with a bunch of great photos, it basis is new springs in the basket, ignore that part. But the photos and techniques for the job are good.
http://www.i-bmw.com/showthread.php?t=53584
Beech
beech is offline
post #4 of 7 Old Mar 21st, 2019, 11:42 am Thread Starter
I also need the tool that goes in the crankshaft position sensor hole to stop rotation.
eliastfk is offline
post #5 of 7 Old Jun 6th, 2019, 11:58 pm
Did you ever get a hold of the member who has the clutch tools? Thanks, Jim
bmwtaxman is offline
post #6 of 7 Old Aug 7th, 2019, 1:36 pm
Hi, does anyone have the tools needed for the clutch replacement for the k1200gt and would be so kind to lend them out? It would be greatly appreciated!
By the way is the crankshaft holding pin necessary to do the job? What can occur if you don't lock the crankshaft as recommended?
Thanks!
PaulsK12GT is offline
post #7 of 7 Old Aug 9th, 2019, 1:38 pm
Thanks!
Looks like you and are looking for the same answers!
Jim
Need DIY Clutch Plate Installation Advice - R1200RT '08 Dimond RT Series 2 Jul 5th, 2015 8:32 pm
squealing clutch on 07 k1200gt rlv K1200/1300GT (The Next Generation) 4 Mar 24th, 2014 2:04 am
Opinions on clutch replacement Voyager K1200LT 24 Oct 11th, 2013 9:46 am
k1200gt 03 clutch be gone garthspeaks Other K-Bikes Discussion 2 Feb 10th, 2008 6:22 pm
