Lubing the lower rear shock needle bearings - BMW Luxury Touring Community
post #1 of 1 Old Dec 22nd, 2018, 10:39 pm Thread Starter
Just finishing up the 18k service on my 07 k1200 gt (now with 96K). Thought it would be a good time to lube the lower rear shock needle bearings. I didn't find the exact thing on the reprom disk. Whats there is replacing the rear spring strut. Preparatory work involves removing a lot of parts???
I think if I have the bike supported on the frame at the location of the center-stand bearings, a jack on the swing arm, rear tire removed, I should be good to go.
Am I missing something?
Cheers, Chris
dantroop is offline
Rear Shock Leak? pathy RT Series 3 Jul 29th, 2012 10:56 am
Cheapish rear new Wilbers shock... in Oz cws Australia, New Zealand, and AsiaPac 3 Jun 25th, 2012 8:11 pm
Broken rear shock, or more ? ltlfeat K1200LT 2 Jul 7th, 2010 10:56 am
Another Final Drive Pivot Needle Bearings Post Bear-KLT K1200LT 17 Mar 10th, 2009 7:08 pm
rear shock pull - remove fuel tank? hmmmm90s K1200LT 4 May 5th, 2008 1:13 pm
