SS bolts on "07 k1200gt clutch cover? - BMW Luxury Touring Community
 1Likes
  • 1 Post By meese
post #1 of 5 Old May 23rd, 2018, 12:35 pm Thread Starter
Has anyone replaced the aluminum bolts on the clutch cover with Stainless Steel. If so what did you torque them to? I guess the reason for the aluminum ones are to keep the threads in the case from being stripped out?
dantroop is offline
post #2 of 5 Old May 24th, 2018, 12:44 am
Re: SS bolts on "07 k1200gt clutch cover?
How often do you remove the clutch cover?
Just get the proper aluminum bolts, torque them correctly and in the correct order, then forget about it for tens of thousands of miles...
beech likes this.
post #3 of 5 Old May 28th, 2018, 2:49 am Thread Starter
Of course you are correct. Silly of me to think about it. I mean, this is the first time I've had the cover off in 70k. An insignificant cost when put in perspective.
dantroop is offline
post #4 of 5 Old Jun 15th, 2018, 11:33 am
selyab's Avatar
Also, the aluminum bolts stretch when torqued as part of the design so they are only supposed to be used once then replaced. Bottom line is a lot of engineering in this installation so probably better to follow the original design.
selyab is offline
post #5 of 5 Old Jun 18th, 2018, 9:30 am
Without consideration for cost of repair. Every time you need to peek inside the clutch cover, it costs you over $50 in stretch bolts.
Some people re-use them. Obviously there is a risk.
Does anyone have a cheaper source for new stretch bolts?
XMagnaRider is offline
I fought the clutch and the clutch won. Slammer Chit Chat 3 Apr 15th, 2013 12:56 am
Clutch Reservoir Cover Leaking quohog K1200LT 3 Apr 29th, 2012 1:01 pm
k1200gt 03 clutch be gone garthspeaks Other K-Bikes Discussion 2 Feb 10th, 2008 6:22 pm
