Clutch hub resurfacing - BMW Luxury Touring Community
 1Likes
  • 1 Post By dantroop
post #1 of 8 Old May 20th, 2018, 4:06 am Thread Starter
Got the clutch pack out tonight, 2007 K 1200 GT with 90K, Hubs are scored (grooved) . I'm sure they will need resurfacing. Is there a limit to how much machining can be done with out negatively affecting clutch operation?
dantroop is offline
post #2 of 8 Old May 28th, 2018, 2:51 am Thread Starter
Re: Clutch hub resurfacing
Fixed! Bought a used basket and hubs off ebay.
beech likes this.
dantroop is offline
post #3 of 8 Old May 28th, 2018, 1:40 pm
beech's Avatar
A new bearing for that basket can be had at Motion Systems, there are several all around the country.
NK35/30TV. Will take vibration out of the assembly. BMW does not sell them.
(35mm ID 45mm OD and 30 mm wide. roller bearing. )
Beech
beech is offline
post #4 of 8 Old May 29th, 2018, 7:17 pm Thread Starter
Thanks beech Gonna make a note of that in my binder.
dantroop is offline
post #5 of 8 Old May 30th, 2018, 12:20 am
beech's Avatar
Here is the thread where the info came from. Hints that the factory original bearing was not the best.
http://www.i-bmw.com/showthread.php?t=62365
Beech
beech is offline
post #6 of 8 Old Jun 7th, 2019, 12:06 am
Dan,
I also in San Jose. Any chance we chat--my clutch is in need of replacement. I do not have enough posts yet to PM. Thanks, Jim
bmwtaxman is offline
post #7 of 8 Old Jun 9th, 2019, 5:45 pm Thread Starter
bmwtaxman. Start posting!!! How many posts do you need 5?
Sent you a pm. hopefully you can read it. I assume you have a k1200-1300? How many miles on your clutch? What are the symptoms?
Joe's '06 RT loaned me the tools to do the job. Thanks, again Joe. Pm him.
I'd be happy to share what I learned replacing mine with you and since you're in SJ could walk you through it, though it's been a while.
dantroop is offline
post #8 of 8 Old Jun 20th, 2019, 2:40 am
Thanks for the reply and PM. I have a 2007 K1200 GT with 53,500 miles. I knew it was a matter of time on the clutch. Have all the classic symptoms--heavier than normal clunk, can still find neutral but a good 25% of the time won't get there, very recently the clutch spins when on the throttle in 4th, 5th and 6th.
I just hope that I have not worn a grove in the basket (after reading other posts I am now worried about this)
Did you use bmws parts or aftermarket?
Jim
The Anatomy of Motorcycle Clutch. PadG RT Series 26 Apr 12th, 2016 11:01 am
Clutch use question Teach RT Series 52 Jun 6th, 2012 4:53 am
Clutch Dragging after New Clutch install NRuest K1200LT 5 Mar 28th, 2010 10:19 am
Clutch Party Report! hallzee K1200LT 5 Jan 17th, 2010 9:06 pm
Is it time to start drilling TWO weep holes? Dean_BMW K1200LT 10 Dec 5th, 2007 6:29 pm
