oil pump chain adjustment while doing clutch - BMW Luxury Touring Community
post #1 of 6 Old Apr 18th, 2018, 1:58 pm Thread Starter
Anyone help with information on adjusting or replacing the oil pump chain while changing clutch plates? I have a 2006 K1200gt with 40,000 miles, I am going to start on the clutch next week, already have it torn down, just waiting to receive some grateful loaner tools. When I was looking in there the oil pump chain looks loose.
Ideas??
northguybkb is offline
post #2 of 6 Old May 2nd, 2018, 11:00 am
Re: oil pump chain adjustment while doing clutch
I'm in there now too.. I do some some adjustment procedure.. you can see if here even if you can't get the language :-)
Smddanny is offline
post #3 of 6 Old May 2nd, 2018, 12:22 pm
beech's Avatar
Actually there are a couple of screws that can be loosened and adjust the tension. But, it is normally very loose. So don't be deceived. There is a inexpensive tool that is used to measure the tension. Don't adjust it snug just by eye. The drive gears are just stamped not machined and it is made to run a little looser than seems reasonable.
Screw #1 is at top of the tension rail, #2 is at the bottom and is the one that slides, it pivots on #1. The tool is:
11 1 931 or order # 041 502.
here are some words from the DVD
Loosely install screw (2).
Insert eccentric gauge (No. 11 1 931) between the sprocket and the gearbox input shaft.
Align the mark on the eccentric (arrow) at right angles to the oil pump drive chain.
Use your hand to push the tensioning rail toward the chain and tighten screw (2).
Few people mess with it. I really think it is worth it to buy the DVD and read through it for the factory details. You can integrate this with your Clymers and other information.
Beech
beech is offline
post #4 of 6 Old May 10th, 2018, 12:57 am
I haven't seen anyone in videos replacing the clutch mention this. The shop manual addresses it, but is it necessary if you don't pull the clutch basket?
dantroop is offline
post #5 of 6 Old May 10th, 2018, 1:16 pm
beech's Avatar
No, But many times the clutch basket is trash. If it has notches from the plates, it is done.
Beech
beech is offline
post #6 of 6 Old May 10th, 2018, 7:45 pm
Oh boy! Definitely will check that. Thanks.
dantroop is offline
New DIY K1600/1300 Oil Change Video 14wntr K1600GT/GTL 53 Jun 6th, 2017 6:47 am
Changing the oil myself for the first time AntRT RT Series 24 Jun 11th, 2014 5:09 am
How To Do A $65 Oil Change For $13 southern_nj K1200LT 109 Sep 19th, 2013 5:16 pm
OIL - Red Light after 24K service LTFan K1200LT 11 Apr 21st, 2012 1:38 pm
Clutch adjustment? REWDOC K1200LT 15 Mar 6th, 2007 10:19 am
