Fuel pump assembly flange tool - BMW Luxury Touring Community
post #1 of 5 Old Apr 5th, 2018, 6:40 am Thread Starter
The back story: A few weeks ago the fuel strip in my ‘07 GT failed. I let it go because the bike isn’t going any further than 100 miles or so until summer. Then I decide to go ahead with the replacement and that was done on March 28th at my local BMW shop as a warranty job. On the 30th I walk into my garage and it smells like I have an open container of gas in there. No puddle of gas, but since the fuel strip was the last thing done that’s gotta’ be it; the smell is especially strong just above the tank filler. I pull the body panels, raise the tank and and using long-nosed pliers I run a paper towel around the wet look at the pump flange. Looking in again with a flashlight I can see gas ever so slowly seeping from the bottom of the flange. The BMW tech says it sounds like he pinched the o-ring when reinstalling the assembly and to bring it back for him to fix ... on April 10th. I’m OK with this because I have my RT to ride in the meantime. I asked the tech if it was something I could do and he told me I need a special tool to remove the flange. I’ll let them do the repair, and I’ll ask if the dozen o-rings I have for a Ducati ST3 I had are the same ones. My ‘07 GT has another year on the recall if this fuel strip fails. So after all that my question: what is the special fuel pump assembly flange tool? I may as well have one, or the same in non-BMW make.
Joe
Joe's '06 RT is offline
post #2 of 5 Old Apr 7th, 2018, 1:02 pm
Re: Fuel pump assembly flange tool
It is not really an o-ring but a gasket and here is the tool.
Next time you fuel strip goes out just zap your old fuel strip with a piezo BBQ lighter and it will "weld" the broken substrate in the sensor. I have done it on GS's and RT's for several bikes. It may only last a year or so but you can repeat it as often as you want. Just hook up to the two center pins in the four pin connector on the fuel flange and zap away. No you will not blow up the bike.
ID:	142226   Click image for larger version
ID:	142234   Click image for larger version
ID:	142242   Click image for larger version
ID:	142250   Click image for larger version
post #3 of 5 Old Apr 7th, 2018, 9:04 pm Thread Starter
That's goodbye info, thanks. Question: The photo is a spare assembly for my '06 RT. Will it also fit my '07 GT?
Joe
post #4 of 5 Old Apr 7th, 2018, 10:37 pm
beech's Avatar
Compare part numbers on this site to see if they are the same for both bikes. Also a good place to learn about gaskets and orings.
https://shop.maxbmw.com/fiche/PartsFiche.aspx
Beech
beech is offline
post #5 of 5 Old Apr 9th, 2018, 6:01 am Thread Starter
Will do, Beech, thanks.
Fuel Pump ,,your thoughts please kclineman10 K1200LT 12 Nov 1st, 2016 1:12 pm
1999 K1200LT fuel pump ozboxer Australia, New Zealand, and AsiaPac 10 May 27th, 2016 1:34 am
K1200 LT Starting Issues jamcwhirter K1200LT 4 Sep 10th, 2015 7:28 am
'99LT fuel problem, please help mta0202 K1200LT 22 Mar 8th, 2015 8:54 pm
Fuel Filter Replacement and the Rotten Hoses. azccj K1200LT 11 Jun 6th, 2013 9:32 pm
