2007 K1200GT clutch R&R - BMW Luxury Touring Community
 7Likes
post #1 of 51 Old Dec 28th, 2017, 2:54 pm Thread Starter
Upon viewing a couple videos on how-to clutch R&R it is clearly not difficult. What seems an obvious question may not have an obvious answer: What is to stop me from disassembling the clutch pack in situ and simply replacing the plates and spring? It surely looks as though I can do that without removing the large nut securing the ďback plateĒ.
Joe
Joe's '06 RT is offline
post #2 of 51 Old Dec 28th, 2017, 9:43 pm
Re: 2007 K1200GT clutch R&R
I've done several of these Slant/4 clutches over the years.
If the outer basket isn't worn, then you don't need to remove it.
My experience shows that the grooves that hold the friction plates tend to wear, making the clutch noisy or jerky, so you may have to replace the outer basket as well. Not cheap, and only available from BMW...
A friend bought the clutch holding tool from BMW (again, not cheap).
Another friend and I just made our own tool in his machine shop.
It is possible to do it wth a large strap wrench or something similar holding the outer clutch basket, but having a proper tool that won't slip makes it a whole lot easier.
post #3 of 51 Old Dec 29th, 2017, 5:36 pm Thread Starter
Thanks, meese, for the information. I did order both the holding tool and locking pin; if I remove more than just the plates Iíll have them available.
Joe
post #4 of 51 Old Dec 30th, 2017, 1:55 am
There are some good videos on YouTube that go into the whole multi-plate wet clutch replacement process in great detail. Just make sure it's for an '06-'09 Slant/4 motor as opoosed to the single-plate dry clutch used in the older Flying Brick motors from the LT, RS, and earlier GT bikes.
Note that the K1300GT has a redesigned inner hub, clutch plates, and outer basket. All these parts can be retrofitted to the K1200GT, and it's likely what you'll get if you order the parts new from BMW now. There's also a guy in the UK that was doing a great job rebuilding/reworking the 1200 clutches, but most all of his improvements have now been incorporated into the 1300 clutch design.
You can find some good clutch squawk discussion at this link.
I don't know how long you've had the bike, but you should make sure you have the cam chain jump guard and latest cam chain tensioner installed while you're in there. Your local dealer can check the VIN against his records to see if those were done on your bike. If not, now is the time to get it done, as it may well save you from a munched engine...
More cam chain info can be found at this link.
Also, have a read through this thread to learn more than you wanted to know about the K1200GT.
Once you sort out these issues, then it really is a fine bike.
XMagnaRider likes this.
post #5 of 51 Old Jan 2nd, 2018, 9:00 am Thread Starter
Thanks again meese for the info.
The bike does have the jump guard installed.
Of course upon removing the spring retainer and spring I see why the nut must be removed to replace the plates.
Iím waiting on delivery of the clutch holder tool and crank lock tool to complete the job.
Joe
post #6 of 51 Old Jan 6th, 2018, 4:38 pm Thread Starter
I did the clutch replacement today; not a difficult task if one has the right tools, and a cheater-bar to break the nut loose.
Mine had the typical signs of a worn or worn out clutch: creeping when dropped into first, squeal leaving a stop, difficult to find neutral if not rolling, hard shifting, a very narrow engagement band way out at the end of lever travel, and slipping at higher revs under harder acceleration. The friction plate against the pressure plate was bare making for the metal-on-metal squeal leaving a stop. I used a Dremel with a sanding drum to gently knock down the ridge on the pressure plate.
I look forward to warmer temps to enjoy better drivability.
All that said, I now have the BMW crankcase lock tool, a thin-wall socket, and a clutch holding tool I ordered from an outfit in the U.K. Cymarc | The home of handcrafted quality motorcycle parts made in Britain. BMW Specialist Now since these tools are likely to see a very limited use, I offer them out for loan to anyone in the continental U.S. who is willing to pay shipping both ways.
Joe
post #7 of 51 Old Jan 6th, 2018, 7:14 pm
NOw that's a very generous offer.
I'm not in the US, I'm in Australia and, I don't have a bike requiring the use of these tools, I have a loan BMW K100LT a friend insisted I borrow till I get my car engine built and back in my car. Now I have the bike the car is no longer a priority and I'm enjoying riding again after having too long a break (plenty of friends bikes ridden in between).
One thing I will mention, not trying to be a kill joy, I've loaned out plenty of specialty tools over the years and have lost so many. What hasn't been lost has mostly been damaged and now when some of the same acquaintances come and ask "oh, do you have such and such tool?" I tell them to go buy their own because I either never get them back or they come back damaged and when I actually require them myself, I have to purchase another one.
One such example is a classic, a friend of 30 years started telling me he has a 17mm socket Allen key (hex key) and I said "yes, it's mine, I loaned it to you a few years back and you never returned it!"
He said "I don't know where I borrowed it but it's not yours, why would you even own one?"
I retorted it fitted the free lift pins on forklift masts and having been a forklift technician for several years it was a much used tool. I also told him I loaned it to him to do the gearbox on his VW Transporter.
I never got it back!
I'm not saying the fine folk on this forum are going to be the same and I'm sure there are plenty of members here who would greatly appreciate the loan and also respect the tool and return it promptly in the condition they received it, just saying I've lost a couple of thousand dollars worth of tools I have never gotten back ( having a crappy memory and forgetting I've loaned it out (and to whom) till it's missing when I need it doesn't help).
Patric likes this.
Leo_G is offline
post #8 of 51 Old Jan 6th, 2018, 10:36 pm Thread Starter
Yeah, I know loaning tools is a risk. Twelve years or so ago a young kid living just across the street from me was working on a pickup heíd acquired somehow. Of course he didnít have any tools but knew I liked to work on my motorcycle and had tools. The short version is I loan him and his buddy some Craftsman tools. When I get the tools back some have been replaced with lesser quality items. Turns out I got some of his buddyís tools and his buddy got some of mine. The kid didnít know one tool brand from another, and I never saw his buddy again. Iíve long since replaced the off-brand with my favorite Craftsman brand, and the off-brand bits are in my traveling kit.
Mark65 and Leo_G like this.
post #9 of 51 Old Feb 26th, 2018, 8:02 pm
Any takers on your tool loan offer? I have a 2006 K1200S and I need to replace my clutch plates and would love to borrow your tools!
BrianK1200S is offline
post #10 of 51 Old Feb 27th, 2018, 7:18 am Thread Starter
Where are you located, BrianK?
post #11 of 51 Old Feb 27th, 2018, 3:56 pm
I'm in Seattle, WA. I am having a really hard time replying to you - multiple different security issues keep popping up (token expiring???). Anyways I did sign up to this forum to respond to your earlier post - I am a member of another forum (I-BMW), but hadn't seen on offer to borrow some of those special tools in there. Of course I hadn't really asked My K1200S definitely needs new clutch plates - finding neutral is almost impossible, and I have to put on my brake when I shift into first so I don't leap out in an uncontrolled manner. Makes driving around town and stop and go traffic even more of a bear than normal!
post #12 of 51 Old Feb 28th, 2018, 9:02 am Thread Starter
OK, youíre on to borrow the tools as long as you pay the shipping both ways. When would you like to have them?
post #13 of 51 Old Apr 9th, 2018, 9:37 pm Thread Starter
The clutch tools: engine lock, hub holder, and socket, went from me in North Carolina out to Seattle for Brian to use on his K1200S and have been returned. They are again available for loan.
bmwcoolk1200 and northguybkb like this.
post #14 of 51 Old Apr 11th, 2018, 5:28 pm
Talking Re: 2007 K1200GT clutch R&R
Joe, I wouldn't mind borrowing those clutch tools if they are available again, I am in Michigan.
northguybkb is offline
post #15 of 51 Old Apr 11th, 2018, 5:41 pm
Joe,
If the clutch tools are still available I would love to borrow them if I could. I am located in Michigan.
40,000 miles on her and she started slipping like crazy.
post #16 of 51 Old Apr 11th, 2018, 8:36 pm
Joe,
If the option to borrow the clutch tools is still available I would love to borrow them. I am located in Michigan.
post #17 of 51 Old Apr 17th, 2018, 12:18 pm
I would love to rent those tools if available.
post #18 of 51 Old Apr 17th, 2018, 3:46 pm Thread Starter
Sure, rental fee is you pay shipping both ways. Send me a pm.
post #19 of 51 Old Apr 17th, 2018, 3:54 pm Thread Starter
Or just right here with your shipping info and when you want the tools.
post #20 of 51 Old Apr 18th, 2018, 9:12 am
pm sent
post #21 of 51 Old Apr 20th, 2018, 5:05 pm Thread Starter
Clutch tools are off to Michigan after their successful trip to Seattle.
They’ll be ready to travel again soon.
post #22 of 51 Old Apr 26th, 2018, 10:02 am
Tools are on there way back, a thousand thank you's sir.
Here is a picture of modification to the thrust pin, hopefully let more oil in to the clutch basket. I also added a hole on the clutch basket on the very edge of the shoulder. The clutch plates were in good shape except for the very outer one, a tremendous amount of pasty build up. Replaced with Barnett clutch plates.
ID:	143362   Click image for larger version
post #23 of 51 Old Apr 28th, 2018, 11:48 pm Thread Starter
Clutch tools are back from their Michigan adventure and are ready to be lent out again.
northguybkb likes this.
post #24 of 51 Old May 2nd, 2018, 10:19 am
I have a couple of procedural questions I hope you gents can help me with. I bought the clutch basket tool only from the UK. I removed the basket inspected, drilled an extra oil passage for the first (or last ?) plate where the hole was misplaced. I've also machined the thru pin to allow for more oiling. I am ready to re-assemble with Barnett plates and have installed the basket. These are the questions I have:
Why do you need to lock the crank? This seems redundant to me.
Why pin the ancillary gear also? I don't see any timing marks on the pulleys. The cam timing is done off the crank and the ancillary shaft ... why time that? I don't see any phase relationship.
perhaps the extra tools and work are to aid in reinstalling the split zero backlash gear on the clutch basket? I did not really have any issue installing the basket without... a couple taps and a twist and it fell right in to engage the oil pump drive.
So.. why bother locking the crank? You guys and all the vids are making self conscious :-)
Smddanny is offline
post #25 of 51 Old May 3rd, 2018, 7:44 am Thread Starter
Valid questions that I can’t answer. I bought the tools after watching a YouTube clutch change video. Then I simply changed-out the plates without making any mods. I questioned the crank lock tool as well, but it’s a quick installation and removal so I used it. Everything seems to be working well.
Joe
post #26 of 51 Old May 3rd, 2018, 10:32 am
I finished up my clutch last night on the K1200s. Initial results is that the clutch is much improved.. No shaking shuddering or squealing on take off from rest.
There is / was no penalty for not locking the crank or ancillary shaft gear. It was quite easy and simple actually.
The OEM BMW plates were in great shape still except as predicted the first plate was dry .. no oiling. I increased the size of the slot in the central push rod I drilled a couple of extra oiling holes in the basket in the "correct" position as per "sharealike1" vids on youtube. He's the one who really figured this all out. He also improves the springs in the basket if your early basket is rattling. His vids on you tube.. here is one:
Hats off to that British gent.
Now my clutch is almost as good as a Honda clutch :-)
Why couldn't the German's (faithfully) copy a tried and true design? Too egocentric :-)
Also the Barnett clutch plates set has steel plates with a mat finish not ground or polished like the Germans. Japanese plates usually have a stippled finish to give the oil a place to shear into when the clamping force increases. Sharealike1 also offers these stippled plates for the K1200.. I bet that is a improvement too.
Smddanny is offline
post #27 of 51 Old May 3rd, 2018, 10:33 am
So there is a clutch basket tool for the K12s in Ct also.
Smddanny is offline
post #28 of 51 Old May 10th, 2018, 12:38 am
Well, with 90k on the clock it's time for a little clutch work. Thought the hard to find neutral symptom was due to the sloppy shifter. Did the "fix". While shifting better, neutral remains elusive at times. Ordered the clutch kit today. Funny thing is I was surfing to find the new style airbox ( you know why) and somehow got sidetracked to clutches. So now I have the new style airbox and clutch kit ordered. I'll be busy soon.
dantroop is offline
post #29 of 51 Old May 17th, 2018, 12:04 pm Thread Starter
Clutch tools are on their way to San Jose!
The box they are in is the box they came in on their way back from Seattle. The box has been to Michigan and back and is heading west again.
Joe
post #30 of 51 Old May 17th, 2018, 7:53 pm
Many thanks Joe. I'll keep my eye out for it.
dantroop is offline
post #31 of 51 Old May 20th, 2018, 4:00 am
The tools came today! Just removed the clutch pack. Thanks for the loan of the tools Joe. Bad thing is the hubs are scored (no material left on friction plates mating to hubs).
dantroop is offline
post #32 of 51 Old May 22nd, 2018, 1:10 pm
Can anyone tell me how to borrow the tools for the clutch replacement on my 04 K12GT. I found a man who would lend the tools, then you ship them back to him. But it has been years since I found his contact. I have the parts I just need the tools. Please help!
post #33 of 51 Old May 29th, 2018, 7:23 pm
Clutch done! Haven't taken it out to test ride. Can't thank Joe enough for the generous loan of tools! Also a shout out to Mk19. At first the pics wouldn't come up. Then I read the one sentence that said, "the factory manual doesn't say it but you have to rotate the eengine to locate the alternator alignment hole!!!!! I'd still be orking on it if I haden't seen that.
Cheers, Chris
dantroop is offline
post #34 of 51 Old May 31st, 2018, 4:35 pm Thread Starter
The clutch tools are back from sunny San Jose and are ready to loan out again.
Thanks to Chris for returning them in a better box!
Joe
post #35 of 51 Old Jun 4th, 2018, 1:38 pm
Joe, I am in need of your clutch tools also, my 07 has 56000 mi. Tried to pm you but I don't think i have enough posts yet for that. Do you use paypal for shipping costs? Pm me with info and my address. Thanks
mohler is offline
post #36 of 51 Old Jun 10th, 2018, 5:03 pm
An update. Joe did contact me about loaning me his tools, he is a generous man. But I had been in the dealer the preveous day for a fuel strip replacement and ended up buying the tools. So his are probably still available.
Thanks again for the offer Joe.
mohler is offline
post #37 of 51 Old Jun 10th, 2018, 5:59 pm Thread Starter
The tools are again available for loan!
post #38 of 51 Old Jun 16th, 2018, 9:22 am
Having known about these clutchs having problems, I bought one about 7 years ago from a wrecked bike with around 2000 mi. on it. Paid $300 for it, what a bargain.
My original had 57000 mi. Each end plate and their mating surfaces were very worn and grooved. All the channels of the basket had wear from the plate ears. All the inner plates were in decent condition. On the new one I did drill an extra oil port close to the end plate.
What a difference, it's like a new bike again. For the last 2 years I've been bliping the throttle on down shifts to get a fairly smooth change. To get it into neutral, had to shut off the engine off.
ID:	146569   Click image for larger version
ID:	146577   Click image for larger version
mohler is offline
post #39 of 51 Old Nov 14th, 2018, 10:10 am
Hi Guys,
in the official BMW Reprom instructions there are four tools for the clutch and basket replacement:
1. The Hub Holder
2. crankshaft locker
3. alternator locking pin
4. excenter tool to set the oil pump chain tension.
Can i change my clutch and the basket in a 2007 GT without 3. and 4. ? What are role of the locking pin?
I think, the most important is the Hub holder. I have to buy one, i'm in Hungary, so i can't ask Joe to borrow his tools because our customer office wouldn't believe the lean
Andras
Szandras69 is offline
post #40 of 51 Old Nov 14th, 2018, 12:38 pm
beech's Avatar
Short answer is yes. Read this thread and I have a comment at the bottom of it.
http://www.i-bmw.com/showthread.php?t=53584
I just finished this job 3 days ago. If you have any questions you can PM me and we can exchange email addresses.
Here is a longer discussion of the clutch in our bikes:
http://www.i-bmw.com/showthread.php?t=51004
Beech
beech is offline
post #41 of 51 Old Dec 4th, 2018, 2:20 pm
Huh, last weekend i have replaced the complete clutch with basket, lamellar package and the oil pump sprocket. It was not too hard. BEECH, MANY THANKS for your post on i-bmw.com!!!
But, i was schocked when i removed the clutch cover. There are few small plastic pieces in the cover... i discovered a broken cam chain side rail in my bike.
When you solve a problem, a new one appears immediately
Thanks guys, it's a very helpful thread!
Andras
post #42 of 51 Old Feb 5th, 2019, 12:23 pm
Hello Joe, I'm in Michigan - just North of Toledo Ohio. I was wondering if your clutch tools were still available. Thx. Steve
Stevo54 is offline
post #43 of 51 Old May 30th, 2019, 12:10 am
Joe, Couple of questions: 1) are your tools available? 2) any opinion on OEM versus Barnett discs? Thanks, Jim
bmwtaxman is offline
post #44 of 51 Old Aug 7th, 2019, 1:13 pm
Hi Joe,
Are you still willing to lend your clutch repair tools? I appreciate your generous offer!!!
Paul
PaulsK12GT is offline
post #45 of 51 Old Aug 9th, 2019, 1:45 pm
Originally Posted by PaulsK12GT View Post
Hi Joe,
Paul
Paul, have you decided if you are going to use BMW or Barrett parts? I still need to do my clutch and haven't received much feedback on the aftermarket parts.
Jim
post #46 of 51 Old Aug 9th, 2019, 8:24 pm
I have a new-in-box Barnett clutch pack for the K12/K13 motors.
I was gonna install it myself, but ended up taking the bike into the dealer to get some other work done so I just had them do everything while it was apart.
The Barnett clutch is superior to the older K12 clutch pack.
The factory K13 clutch pack has a ton of improvements over the K12 version, so it's a good choice too.
If you just need the clutch pack plates alone, Barnett is a solid choice.
If you need the inner hub as well, then BMW is your only option (and 6x the cost).
If someone needs a new Barnett clutch pack, then PM me and I can make you a good deal.
post #47 of 51 Old Aug 21st, 2019, 9:55 pm
Ken--I finally woke up and noticed that you responded to this post and answered my query on Barnett. Thanks! Do you still have the Barnett pack available? I think this post will put me up to 13 and I will also try to PM. Thanks, Jim
post #48 of 51 Old Aug 22nd, 2019, 2:09 am
Yes, the Barnett pack is available.
I'll see if I can send you a PM.
post #49 of 51 Old Aug 22nd, 2019, 5:31 pm
Thanks Ken. I received your PM. I am still trying to get up to 15 posts to PM Joe to see if he is still loaning the tools to tear into my bike. This will put me up to 14. Thanks for giving me a reason to post!
Jim
post #50 of 51 Old Aug 22nd, 2019, 5:41 pm
Ken,
I think you need to update your garage to include the "new" old LT? Just noticed your location--how apropos. I get spoiled down here in the bay area with only 14 inches of rain on average. I can't imagine having to deal with your 40 inches or so!
Back to the clutch. Since I do not have the tools yet, I do not know the condition of the basket. On another forum someone advises just going straight to the k1300GT basket which are about $800 used. Have you had any discussions with anyone as to this particular procedure? Benefits/cons, etc.
(Thanks for your patience--trying to get to 15 posts)
Jim
squealing clutch on 07 k1200gt rlv K1200/1300GT (The Next Generation) 4 Mar 24th, 2014 2:04 am
$1,600 for R&R clutch? EddieLo K1200LT 12 Jan 18th, 2013 9:50 pm
RT Clutch Adjustment Nebish RT Series 17 Apr 1st, 2009 10:51 am
clutch slipping, how to R&R? thanx madejasmile K1200LT 8 Jun 1st, 2007 11:53 am
