K1200GT front ESA - BMW Luxury Touring Community
 1Likes
  • 1 Post By meese
post #1 of 4 Old Mar 2nd, 2017, 6:28 am Thread Starter
K1200GT front ESA
Thanks to my GS-911 I found out that my front ESA had an open circuit.
I was able to trace it to one of the white wires that leads to the shock.
Now that I've fixed the broken wire, the fault code is gone. I don't know how to tell if the damping adjustment is working, though.
When cycling through the modes (comfort, normal, sport) I can hear the rear shock make a small whirring noise. The front shock, on the other hand, doesn't make any noise at all.
Does this mean it's broken? Should there be a noise? What's the best way to test it?
Thanks.
Elwin is offline
post #2 of 4 Old Mar 5th, 2017, 2:16 pm Thread Starter
Re: K1200GT front ESA
Just to update you guys.
I've simply fixed the wire and I seem to be able to change the damping. Not 100% sure, it feels like a noticeable difference between comfort and sport.
So no noise from the front shock when changing damping modes apparently.
Elwin is offline
post #3 of 4 Old Mar 5th, 2017, 5:32 pm
The rear shock adjusts preload as well as damping, and the front shock only adjusts damping.
I wouldn't take the noise alone as any indicator.
Go for a ride on a bumpy road, and you should be able to tell the difference between Comfort and Sport pretty easily.
XMagnaRider likes this.
'13 Dark Graphite Metallic K16GTLD, 24K miles and counting...
'09 Magnesium Beige Metallic K13GT, 63K miles miles and counting...
All lower 48 states plus Alaska on the K13GT in two weeks . . .
post #4 of 4 Old Mar 6th, 2017, 9:33 am
It works on smooth roads, too. In Sport mode, you can feel the texture of the pavement.
XMagnaRider is offline
New front oil leak while on the road. Advice? TomD K1200LT 12 Aug 20th, 2007 1:24 pm
Front and shake/ shimmy front, ... revisited andy K1200LT 12 Jan 12th, 2007 7:16 pm
Front end shimmy gregorysharp K1200LT 21 Oct 28th, 2006 10:43 am
