Fuel gauge level after calibrating new strip - BMW Luxury Touring Community
 1Likes
  • 1 Post By meese
post #1 of 11 Old Mar 1st, 2017, 2:10 pm Thread Starter
I've hooked up a new fuel strip and calibrated it through the GS-911.
The fuel gauge now displays about halfway between the bottom and the first marking (don't have the post count to upload an image).
It seems strange that the gauge is reading anything at all, since the strip is outside the tank and dry.
Should I recalibrate it?
Thanks in advance.
Elwin is offline
post #2 of 11 Old Mar 1st, 2017, 3:38 pm
mtrevelino's Avatar
Re: Fuel gauge level after calibrating new strip
How did you calibrate it through the GS-911? If it is a new strip, some say it does not need any calibrating, that it will settle out after a couple of tanks of fuel.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #3 of 11 Old Mar 2nd, 2017, 1:57 am Thread Starter
Thanks for your reply, mtrevelino,
I calibrated it as much as possible according to BMW's procedure (can't post due to low post count)
However, they state that if voltage should drop below 12.6V, the procedure will abort. I'm using an optimate charger to top up the battery but the voltage starts dipping below 12.6V after seconds and ends up around the 12.0V mark at the end of the procedure.
With the new strip, GS-911 says "Sensor calibrated, but there are fault codes logged".
My old fuel strip appears to be broken as GS-911 says "Error calibrating fuel strip".
Is the procedure really that sensitive to battery voltage?
It would be great to have the strip settle after a few tanks of fuel, although getting to the tank is such a hassle that I prefer to calibrate it while I have access to it.
Elwin is offline
post #4 of 11 Old Mar 2nd, 2017, 7:35 am
mtrevelino's Avatar
Someone else would have to comment on this. I do not know how the GS-911 can calibrate the fuel strip. The only calibration I know of is with the LT's, but they have a float. And the LT's procedure is to drain the tank and put one gallon of fuel in it.
If you do a search for "fuel strip" you should come up with some interesting reading.
Mike Trevelino
Williamsburg, VA
2008 RT
post #5 of 11 Old Mar 2nd, 2017, 1:19 pm Thread Starter
Thanks. I think I've read every fuel strip thread there is to find on the internet
Haven't come across the answer yet.
Would be great if someone with fuel strip experience could shed some light.
Elwin is offline
post #6 of 11 Old Mar 2nd, 2017, 1:34 pm
beech's Avatar
I thought BMW gave a 12 year warranty on these now. No need to buy one.
Beech
beech is offline
post #7 of 11 Old Mar 2nd, 2017, 3:44 pm
Biker-Paulo's Avatar
Details in the procedure files with the GS911 tool.
On the road again.
Paulo
ID:	123122   Click image for larger version
ID:	123130   Click image for larger version
ID:	123138   Click image for larger version
K1200RS - 1997
K1200LT - 1999
K1200GT - 2008
Ride With Pride
Blue Knights France - Chapter V
Biker-Paulo is offline
post #8 of 11 Old Mar 2nd, 2017, 9:03 pm
That doesn't calibrate the fuel strip or float to its total range, it just sets the point at which the Low Fuel light comes on.
mtrevelino likes this.
post #9 of 11 Old Mar 4th, 2017, 6:37 am Thread Starter
On the road again.
Paulo
Thanks Paulo,
Meanwhile I've hooked up a new battery and re-calibrated the strip.
It now showed empty, outside the tank!
When inserted into the 1/3 full tank though, the gauge still reads empty 8-|
Guess I'll put the bike back together, take it for a spin and hope the gauge magically starts working again.
Elwin is offline
post #10 of 11 Old Mar 4th, 2017, 9:16 am
It will settle out after a few tank fulls. Mine in my GS was always off a little after a repair and always settled out after two tanks.
post #11 of 11 Old Mar 4th, 2017, 12:44 pm Thread Starter
You're right!
Ignition on / of a few times, let it run, now it works!
Thanks for your input guys.
Elwin is offline
2010 RT Fuel Gauge Problem fl0950 RT Series 58 May 2nd, 2017 10:50 am
R1150RT Fuel Gauge Newport RT Series 15 Aug 22nd, 2014 11:44 am
Fuel Strip Reimbursement Firenailer Bike Talk 2 Aug 20th, 2014 12:34 pm
Quick fuel strip revisit (sorry) Entropyd RT Series 4 Feb 18th, 2013 3:53 pm
Fuel Gauge continuing problems JOHNF K1200LT 18 Jul 14th, 2009 10:32 am
