How to calibrate fuel level sensor (K1200GT - 2008) - BMW Luxury Touring Community
post #1 of 9 Old Feb 27th, 2017, 9:40 am Thread Starter
Biker-Paulo's Avatar
I did a bad job with the GS911 tool.
I have a maximum blocked indication for the fuel level at the instrument panel.
What is the procedure for correct calibration fuel level sensor??
Paulo
K1200RS - 1997
K1200LT - 1999
K1200GT - 2008
Ride With Pride
Blue Knights France - Chapter V
[SIGPIC][/SIGPIC]
Biker-Paulo is offline
post #2 of 9 Old Feb 28th, 2017, 7:21 pm
Re: How to calibrate fuel level sensor (K1200GT - 2008)
There may not be anything you can do with the GS-911 if it is the fuel strip and it has failed. I have repaired many of these fuel strips in GS and RT bikes where the indication was either always full or always empty. You need to find the four pin connector on the fuel tank for the strip then hook up a BBQ grill push button starter to the two middle pins (the sensor strip that has broken). Snap the BBQ igniter several times and the HV arc will fuse the broken substrate in the fuel strip repairing it. It will not ignite the fuel. For more info go over to the AdvRider web site and search on fuel strip as there are several threads on it there. I carry a BBQ igniter in my saddle bag on my LT to help my fellow riders while on the road. I did my GS three times before I sold it and got a 1300GT with a float unit.
post #3 of 9 Old Mar 1st, 2017, 3:23 pm Thread Starter
Ok thanks John.
I'll try to this procedure. Is it necessary to remove the fuel tank to have this strip??
K1200RS - 1997
K1200LT - 1999
K1200GT - 2008
Ride With Pride
[SIGPIC][/SIGPIC]
post #4 of 9 Old Mar 2nd, 2017, 5:25 pm
In the US, there is an extended warranty for the fuel level sensor. The dealer will replace it at no cost. The warranty is 12 years from when the bike was first made, if I remember correctly.
I do not know whether it applies to France or other countries.
XMagnaRider is offline
post #5 of 9 Old Mar 3rd, 2017, 6:14 am Thread Starter
Unfortunately this extended 12 year warranty does not apply in France.
K1200RS - 1997
K1200LT - 1999
K1200GT - 2008
Ride With Pride
[SIGPIC][/SIGPIC]
post #6 of 9 Old Mar 4th, 2017, 9:19 am
You just have to access the connector. The strip can be in the tank to zap it. You will not blow up the fuel in the tank.
post #7 of 9 Old Mar 4th, 2017, 1:00 pm Thread Starter
I have done a calibration test with the GS911 tool and the dry sensor, the calibration has been corrected. Then, when the key is in the ignition position, the tank indication is full with the tank empty. I think the fuel sensor is faulty...
K1200RS - 1997
K1200LT - 1999
K1200GT - 2008
Ride With Pride
[SIGPIC][/SIGPIC]
post #8 of 9 Old Mar 4th, 2017, 5:32 pm
If you have an ohm meter measure between the two inside pins on the connector. You should see 2.7 kohms if the sensor is not fractured and measure an open if it is. That is what the BBQ grill piezo snap igniter will fix just keep zapping it then checking with the ohm meter until you get the 2.7 kohms.
If you a half hour to kill go look here for some fun info on the subject.
post #9 of 9 Old Mar 5th, 2017, 12:36 pm Thread Starter
Thumbs up Re: How to calibrate fuel level sensor (K1200GT - 2008)
Today, during my ride with the K1200GT, after a few miles the gasoline level gauge worked properly.
Calibration with the GS911 is a success. Thank you for your help.
Paulo
K1200RS - 1997
K1200LT - 1999
K1200GT - 2008
Ride With Pride
[SIGPIC][/SIGPIC]
Fuel Gauge continuing problems JOHNF K1200LT 18 Jul 14th, 2009 10:32 am
Fuel level Morley K1200LT 4 Apr 19th, 2008 11:27 am
Fuel Level Warning Light - not! bmwtwisty K1200LT 19 Oct 24th, 2006 4:09 pm
Fuel Level Warning Light Issue darkey K1200LT 8 Aug 11th, 2006 4:27 pm
