Cam Chain Tensioner? - BMW Luxury Touring Community
 1Likes
  • 1 Post By jzeiler
post #1 of 11 Old Aug 17th, 2015, 6:33 pm Thread Starter
blankshot's Avatar
Hi All,
Has anyone had to replace the new and improved tensioner? Mine started to rattle on start up again and then it just quit. Thankfully it does have the skip guard installed so I hope it did not damage anything. I guess I may start carrying one of these if they are also failing.
Cheers,
Jim
Jim
MSF Rider Coach
Haverhill, MA
66 R50/2
92 R100R
07 Silver KGT
blankshot is offline
post #2 of 11 Old Aug 17th, 2015, 10:29 pm
Re: Cam Chain Tensioner?
Yes. My K1200GT had the new "piston" cam chain tensioner. About a year ago, it developed a mild cam chain rattle that went away. A year later, it came back. I had just returned from a 500 mile ride that day, parked the bike, shut off the engine, opened the garage, then restarted the engine to park it. It was incredibly loud; it sound like the engine was coming apart.
A friend dropped by a few days later. He immediately diagnosed the problem as a faulty cam chain tensioner. He had an APE tensioner with him, which I recommend. We (he) installed it, and all was well. It took ten minutes to remove the old tensioner and install and adjust the APE tensioner.
APE - World's Fastest Motorcycle Racing Components
Manual Cam Chain Tensioner - BMW K1200GT K1300GT - by APE Race Parts - - A&S BMW Motorcycle Parts and Accessories
The APE tensioner requires care when installing and periodic adjustment. It is a tradeoff between that and having another BMW oil reservoir tensioner eventually fail.
See this current thread for additional discussion:
Clutch noise? - K-Bikes.com - Excellence in Motion
XMagnaRider is offline
post #3 of 11 Old Aug 19th, 2015, 8:04 pm Thread Starter
blankshot's Avatar
Cam Chain Tensioner Up Date.
The GT is up and running. It did turn out to be the cam chain tensioner and after installing a new one it runs very quiet again. It must have been loosing pressure for a while and progressively getting worse and being next to the clutch I thought it was that was making the noise.
The root cause of failure was dirty oil. When I pulled off the tensioner from the reservoir nasty oil came out and when I looked down the plunger the check valve was not visible. Once I cleaned and cleared the valve in the plunger it started to take oil and pumped up. I then used a syringe to suck out the old reservoir and the oil was not good (see photos) and I had just done a oil change no more then 200 miles ago.
Not sure if more frequent oil changes will help or I should add a 2 year maintenance to clean out the reservoir and change out the o-rings.
ID:	87674   Click image for larger version
Jim
MSF Rider Coach
Haverhill, MA
66 R50/2
92 R100R
07 Silver KGT
post #4 of 11 Old Aug 19th, 2015, 8:20 pm
Re: Cam Chain Tensioner Up Date.
That oil looks just like normal BMW oil, its not dirty at all.
johnbaker15 likes this.
post #5 of 11 Old Aug 20th, 2015, 5:22 pm Thread Starter
blankshot's Avatar
All I can say to that is the oil in the sump looks almost new and the oil out of the CCT does not. If BMW thinks that oil is good... they might need new glasses.
Jim
MSF Rider Coach
Haverhill, MA
66 R50/2
92 R100R
07 Silver KGT
post #6 of 11 Old Sep 1st, 2015, 5:24 pm
kbmwgt's Avatar
Replaced mine a few years ago with the adjustable APE version.
Seems to wok...needs adjustment on occasion.
kbmwgt is offline
post #7 of 11 Old Sep 2nd, 2015, 1:17 pm
beech's Avatar
Here is the Oring kit that is needed to rebuild the cam tensioner.
11 31 7 705 460 SET: O-RING SET 1 $10.63
You don't need to buy a complete new unit.
Beech
beech is offline
post #8 of 11 Old Sep 30th, 2015, 8:57 pm
I have a '10 13GT and my 2nd tensioner just failed after only about 14 months. Probably put 15k mi on it? I'll be taking it back to the dealer to see if they'll help. Luckily this is not a difficult or expensive fix.
Jeff
'10 K13GT
'05 330i ZHP
88 E30 M3 Cabrio
o2bsenna is offline
post #9 of 11 Old May 8th, 2016, 7:08 pm
I just got from my first ride on my 08 GT since the cam chain jumped the tracks last August. My dealership missed doing the recall but did the ones on either side of it on the recall list.
I was lucky enough to find a used motor on ebay for $999. While the bike was apart I did everything else that might have needed service right down to having the steering stabilizer serviced.
At 60,000 miles I have had replacement parts, warranty costs and maintenance costs that are almost equal the cost of the motorcycle. If I take the cost of the bike and add in all of these costs costs, my 230 mile breakfast ride this morning has a cost to me of close to a $1.00 mile
Bill 310 is offline
post #10 of 11 Old May 11th, 2016, 12:04 pm Thread Starter
blankshot's Avatar
Mine just failed again yesterday in the parking lot at work, NOT HAPPY!
Going to order new guides and the APE.
All though the FJ9 is looking better and better every day now.
Jim
MSF Rider Coach
Haverhill, MA
66 R50/2
92 R100R
07 Silver KGT
post #11 of 11 Old Jun 23rd, 2016, 5:38 pm
kbmwgt's Avatar
Put in the APE years ago. Still has a slight rattle but not sure if its my ears just looking for trouble.
kbmwgt is offline
Cam chain tensioner liner CharlieVT K1200LT 2 Dec 14th, 2014 7:30 am
HELP Chain Tensioner nbbusa K1200LT 24 Mar 23rd, 2013 6:10 am
Chain Tensioner Rattle (Damage?) MattWhite RT Series 21 Dec 17th, 2012 9:58 am
Chain Tensioner Lining Help Needed ehaughn K1200LT 7 Apr 1st, 2008 10:48 pm
Help on Valve Adjustment lovetomotor K1200LT 4 May 6th, 2006 10:47 pm
