valentine problem - BMW Luxury Touring Community
post #1 of 24 Old Aug 20th, 2006, 6:28 pm Thread Starter
valentine problem
Have just put a valentine on the 2006gt. Having a problem. When I turn ignition on it works fine. But when bike is started it lights up and keeps going crazy. All lights and beeps. I have tried directly off battery and it does same thing. There is a Garmin/xm also installed but they work fine. Any help or direction would be appreciated. Have had a lot of bikes but none with such new electronics. Am enjoying this site immensely. Thanks in advance
Wetrider is offline
post #2 of 24 Old Aug 20th, 2006, 7:16 pm
My friend Tom (tmgs) told me that whenever I get near his LT with my new GT, his radar detector goes nuts! We tested it parked next to each other, and sure enough. IIRC, I think it was the X-Band that was freaking out.
Now the big question is, what can be done about it?
post #3 of 24 Old Aug 20th, 2006, 7:34 pm
Ridesalot's Avatar
electrical noise
That is strange
i am sure the brain on the gt is shielded and the electronics
i wonder if the noise is coming from the alternator ...
it probably is cranking out some big amps ( how many Joe?)
and typical shielding , grounding and filters may help???
Ridesalot
2005 LT "The grey one with the bugs on it."
Ridesalot is offline
post #4 of 24 Old Aug 20th, 2006, 7:48 pm
The alternator puts out more on the GT than the LT. 945 vs. 840 watts
Hhmmn...not enough shielding perhaps?
Anyone?!
post #5 of 24 Old Aug 20th, 2006, 7:57 pm
Ridesalot's Avatar
emf pen
hey joe
do you have an emf pen
the little pen that lights up when it is near AC
fire up ur gt and see if she lights up (as you walk around the motor / bike)
that will answer the sheilding question
also a portable AM radio hold it close to the bike ( on of course) while running
and see if it spazzes out
if it is sheilding then the mfg (Valentine ) is responsible
for adaquit sheilding for their product
a call or email to their tech support may offer a solution
Ridesalot
post #6 of 24 Old Aug 20th, 2006, 8:20 pm
Exclamation Solved?
Tried the AM radio test. Turn a little AM radio on near the GT. When the GT is running, I hear terrible CLICKING . . . like a freakin' Geigor counter! It stop when I shut the bike off. Me thinks it's the alternator boys and girls.
post #7 of 24 Old Aug 20th, 2006, 8:51 pm
Ridesalot's Avatar
Shielding
Wetriders Garmin/xm are not giving him a problem
I assume (Joe) your Garmin is working without a problem
adequate shielding for the garmin and the XM
Joe any noise on your phone do you have it connected to the GT yet ?
I would surmise from my remote location that the alternator is electrically noisy hence the "ticking"
Wetrider could you do the AM radio test ? maybe with the same results
The problem is not BMW's but the individual mfg.
Some shielding (this would detract from the sensitivity of the Valentine) may help. The Valentine is looking for externial signals and the alternator may be overloading the front end of the reciever..
If there is an ac component on the dc power on the bike.
a scope would show us this.
The fastest solution to this problem may be a different Mfg of radar detectors
Ridesalot
post #8 of 24 Old Aug 21st, 2006, 9:12 am
SilverBuffalo's Avatar
I had the same problem, my Valentine would light up ka band rear,
it turned out to be caused by my XM radio antenna,
here's what happened:
I bought the XM (Roady2) it came with about 20" of antenna wire,
I didn't like that so I purchased another antenna with a 4' wire,
it just so happened that my Valentine arrived the same day,
I wired it up and put the new antenna on at the same time,
drove me crazy for a couple of days until I put the original XM antenna back on,
problem disappeared and has not re-occured since.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #9 of 24 Old Aug 21st, 2006, 3:07 pm
philspace's Avatar
I have tons of ignition noise, alternator noise is more of a whining sound that will change pitch with RPM.
Running a V1 on mine, with no problems at all and it's sitting right next to my 2820 and GXM sat reciever.
Which version V1 do you have? You might want to call them. I had mine upgraded last year to the latest that supports PoP mode, maybe that's it
15 R1200RT - Ebony Metallic
09 F800GS
philspace is offline
post #10 of 24 Old Aug 24th, 2006, 7:58 pm Thread Starter
Wink Valentine Problem 06gt
Tried my friends Escort. No problem with any noise . Philspace said he upgraded to pop mode on his Valentine. When I called Valentine they said that I could try the Airport upgrade . Was wondering if that is the same upgrade? Also mine is 5 years old. Would like to thank all for there time and imput.http://www.bmwlt.com/forums/newreply...ote=1&p=98461#
Wetrider is offline
post #11 of 24 Old Sep 27th, 2006, 8:19 pm
Valentine problen
I just installed my valentine on my 06 GT, Works fine. I wired it into the accessory plug. I also have a Garmin street pilot lll installed.
hugoscheuer is offline
post #12 of 24 Old Oct 6th, 2006, 8:48 pm
Valentine Problem
Anyone?!
My Valentine falsed on the X band a lot. I called valentine. I was told to turn off my cel phone, as everytime it polled the tower, it set off the Valentine. Try it, turn off the cel phone and see if it helps.
Rusty
post #13 of 24 Old Oct 8th, 2006, 8:22 pm
Neither my Escort 8500K50 (in tank bag), nor my Valentine One (mounted on Big Mak mount on dash) have any unusual falsing problems. I do have some interference in my UHF ham radio, but it is periodic, not continuous, so it's not ignition noise, nor is it likely alternator noise. Moving to VHF solved that problem for now.
Ruben
2012 K1600 GTL
2007 R1200GS Adventure
Ruben is offline
post #14 of 24 Old Oct 25th, 2006, 11:01 am
philspace's Avatar
Hmmmm Airport upgrade. Wonder WTF that is?
09 F800GS
post #15 of 24 Old Oct 25th, 2006, 11:25 am
I just installed my V1 last week and I have the same problem. False alerts all the time especially when the RPM's are up. I have it mounted on a legal speed handlebar mount in their box. She is wired to the plug just foward of the battery. I have nothing else installed except a garmin 276c. I would be in the middle of a national forest and it would show 5 bogeys after me. It has even gone off when stopped and the engine off. The v1 works fine in my car. My V1 was upgraded to the latest about 9 months ago. Has anyone used a filter with any luck?
Brian Ley
WA State of mindless sheep
2007 K1200GT
2010 650GS
BMWOA 119892
sanjaun2 is offline
post #16 of 24 Old Oct 29th, 2006, 2:12 am
Apologize for the dumb question...
What's a "Valentine"?
How do you like the reception and general work-ability of the Roady2?
Thanks.... Rainman
RainmanEverson is offline
post #17 of 24 Old Oct 29th, 2006, 2:28 am
Cat Herder
tvguy's Avatar
Lightbulb False K & Ka readings
My Valentine works great on the LT around town. Just went 600 miles to the Los Angeles area in the car and had a lot of K & Ka false readings. There is not much radar use on I-15, so I am trying to figure it out.... Just gave the unit to a friend to road trip with to see if he has the same issues before calling Valentine..
tvguy
Tvguy
'16 R1200RT - "Golden Eye"
tvguy is offline
post #18 of 24 Old Oct 29th, 2006, 3:35 am
The Valentine V1 is arguably the best radar detector available. I don't ride anywhere without mine.
post #19 of 24 Old Oct 30th, 2006, 1:00 pm
Steve_R's Avatar
That sounds like a "Don't leave home without it" commercial.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #20 of 24 Old Oct 30th, 2006, 5:39 pm
Sure wish I would have had it in my wife's car when I was passing 5 vehicles downhill only to see a LEO at the bottom.
post #21 of 24 Old Dec 25th, 2006, 6:35 pm
Hulkster's Avatar
I just received one for xma. Manual states that if you put mode in advanced logic it will not report X bogeys.
Hulkster 2002 BMW K1200LTE "Hulkster Green"
Hulkster is offline
post #22 of 24 Old Dec 25th, 2006, 8:20 pm
Hulkster's Avatar
I just got one for Xmas...I want to ability to disconnect from bike and use in auto also. I have the 2002 LTE and I by searching searching the website that there are connections for radar under left handle bar plastic that integrates into 2002 LTE com system. It is suggested to send your valentine to J&M to get a compatible wiring done for com system. Questions?
1) Is there any advantage in sending or buying the remote audio adapter and having compatible wiring to this accessory, instead of the main unit?
2) Will J&M wiring cancel the company warranty due to modification?
3) Like the GPS I would like to flip the Radar back and forth to auto and bike. If I send unit to J&M for wiring do I still have ability to use in Auto. Can I still use the lighter adapter. Do not know how it is wired by J&M?
Please advise. Thanks
Hulkster is offline
post #23 of 24 Old Dec 26th, 2006, 11:27 am
1. I can't imagine why anyone would want to wire it any way OTHER than to use the Valentine audio adapter made for the purpose. Run the 12V power from somewhere on the bike to the Valentine direct wire 12V power adapter, then to the audio adapter. Both alert audio and 12V power run from the audio adapter to the main radar detector in a single cable. Audio then connects to the audio adapter, and when you want to use the Valentine in your cage, just unplug the main unit, and leave everything else on the bike. One simple cable to unplug. In the cage you can use the cigarette adapter and the windshield mount.
2. I'm not sure what you have in mind, but I would NOT allow anyone to open the Valentine detector. You have invested in a device that should last a LONG time, due to it being upgradeable. Once modified, I suspect that you'd be on your own. More to the point, its not necessary.
3. See explanation #1
You need:
- Valentine One detector - check
- Valentine audio interface - ?
- Valentine direct wire power adapter - Check (it's included with the detector)
- An audio cable to connect the audio interface with your audio amplifier. The audio interface has both a 3/32" and 1/8" jacks. I like to use a cable with a ground loop isolator in it, just in case that might get to be a problem. That might be what you are referring to getting from J&M. They won't need your detector or your bike to do that.
- An audio amplifier. I'm guessing from what you indicated that you are planning on using the built in amp from the LT. Make sure the cable goes from mono (the detector) to stereo (your amp) to get alerts in both channels, and you should be good to go.
Good luck
Ruben
2012 K1600 GTL
Ruben is offline
post #24 of 24 Old Dec 26th, 2006, 12:30 pm
Hulkster's Avatar
Reuben thanks for the reply.
My 2002 LTE has a J&M built integrated priority com system. It has a designated three prong connection that will specifically designed for radar . This priority system will allow you to hear in helmut speakers. When radar goes off it will take priority over all other active devices such as Radio,CD,CB,Casette,GPS,Cell Phone, and other aux devices.
Can J&M make a compatible cable that would fit into the Valentine Audio interface. Those three prong connections coming from J&M harness located under left steering wheel plastic for com system include power to valentine and audio. I do not want to loose the com system capabilities and would rather not have them add the pig tail directly to the Valentine detector.
I guess I need to call J&M. If some one already posed this question please advise.
Thanks again for your time in this matter. I am closing in on a decision.
Hulkster is offline
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 12:30 pm
Sputtering problem speedy K1200LT 22 Nov 20th, 2009 12:17 pm
Weird electrical problem ronbok K1200LT 5 Jul 2nd, 2008 11:37 pm
Problem with lamp alignment. JPSpen Lighting 0 Apr 17th, 2006 10:17 pm
Battery problem or what else johnkeyes K1200LT 2 Feb 13th, 2006 8:14 pm
