Clutch lever relacement? - BMW Luxury Touring Community
post #1 of 6 Old May 10th, 2015, 11:33 am Thread Starter
kbmwgt's Avatar
So I had a fall off stopped dismount which bent my clutch lever. Still useful but has a big curve.
Is a clutch lever replaceable?
Costs guess?
Easy to install or need clutch bleeding and all?
I'm off on a 2 week two up ride in June so i thought I'd check to see if I could fix it.
kbmwgt is offline
post #2 of 6 Old May 10th, 2015, 1:34 pm
Re: Clutch lever relacement?
It's a straight forward job and only take a few minutes.
If you are thinking of replacing with aftermarket levers beware the K1200GT 2006/2008 have a unique to that model clutch lever, not however the brake lever. If you are replacing with OEM lever then no problem.
raesewell is offline
post #3 of 6 Old May 10th, 2015, 1:43 pm Thread Starter
kbmwgt's Avatar
Thanks.
A few minutes tells me a lot. I'll get right on that.
kbmwgt is offline
post #4 of 6 Old May 25th, 2015, 1:40 pm
lkchris's Avatar
In the spirit of "teach a man to fish," here's the web address of a complete illustrated parts system for BMWs, including yours. You can look up the illustrated parts breakdowns to learn what's a separate part and what isn't for example, and many times a price is listed, too.
RealOEM.com Online BMW Parts Catalog
Kent Christensen
Albuquerque
lkchris is offline
post #5 of 6 Old May 25th, 2015, 9:23 pm
GTLRider's Avatar
About 5 minutes if you have your tools assembled...
Cliff
2014 K1600 GTL Damask Red Metallic
[SIGPIC][/SIGPIC]
GTLRider is offline
post #6 of 6 Old Jul 16th, 2015, 2:35 pm Thread Starter
kbmwgt's Avatar
Thanks guys
I took the lever off and carefully bent it back some. All is good.
kbmwgt is offline
'014 RTW clutch lever adjustment mod littlefield RT Series 0 Jan 6th, 2015 9:32 am
R1200RT Clutch Hand Lever Adjustment Modifications/Options Dimond RT Series 7 Aug 8th, 2014 7:07 pm
clutch lever mushy mpillis K1200LT 2 Nov 24th, 2007 9:13 am
Clutch failure sonnata K1200LT 12 Aug 14th, 2007 11:19 am
