difficulty starting k1300gt - BMW Luxury Touring Community
 2Likes
  • 1 Post By meese
  • 1 Post By alstrickland55
post #1 of 6 Old Nov 29th, 2014, 8:22 am Thread Starter
alstrickland55's Avatar
After the engine reaches operating temperature on my K1300GT, many times when starting it the starter will barely turn the engine over. It's like the battery is nearly dead. I replaced the battery with a new Odyssey battery but no change. It has not failed to start yet but sometimes I have to bump the starter button two or three times. It doesn't appear to do this when the engine is cold. Is this just characteristic of the high compression engine or is something else going on?
Al Strickland
Blairsville, Georgia
1967 Honda Cub
1972 Honda CB350
1979 Suzuki GS750E
2009 R1200GS
2013 K1600GTL
2009 K1300GT
alstrickland55 is offline
post #2 of 6 Old Nov 29th, 2014, 11:06 am
Re: difficulty starting k1300gt
Yes, on both counts.
These high-compression bikes are known for hard starting when hot. Usually, the Odyssey PC680 battery fixes it by providing much more cranking power.
At some point, BMW decided the main battery/starter cable was sized to small, thus limiting the available current to start the bike. Some dealers would install additional cables alongside the factory cables to increase available current flow, until BMW developed an official kit with larger diameter cables. This wasn't a recall, but some dealers did provide it under warranty.
The upgrade kit is BMW part # 12 41 8 532 735 SET AUXILIARY CABLE STARTER. It includes larger diameter cables between the battery and alternator, battery and starter relay, and starter relay and starter. See this thread over at K-Bikes.com for more detail.
Talk to your dealer and see if they're aware of this fix.
beech likes this.
post #3 of 6 Old Nov 29th, 2014, 10:24 pm
Ken,
You beat me to it but I had a good excuse for not being on the forum this morning as I was putting new tires on the old girl. Wow what a difference as the tires that came on it were a fairly worn PR3 on the rear and a very worn PR2 ( more on the sides vs. middle) on the front. Put PR4 GTs on both.
post #4 of 6 Old Dec 21st, 2014, 2:29 pm Thread Starter
I hope I have this fixed now. I am powering the starter with #6 wire running through a car solenoid triggered by the wire that was attached to the starter. I also grounded the chassis with another #6 wire from battery.
beech likes this.
Al Strickland
1967 Honda Cub
1972 Honda CB350
1979 Suzuki GS750E
2009 R1200GS
2013 K1600GTL
2009 K1300GT
post #5 of 6 Old Dec 24th, 2014, 12:55 am
Super Moderator
dfinazzo's Avatar
Al,
My 2010 K1300GT had the problem and with a lot of research on all the forms I
opted to start solving my "hot restart issues" by installing an Odyssey PC680 and
this hard start issue went away. It was discussed however that this did not
eliminate the root cause - of which Ken mentioned - the battery just over
powered what ever was causing the issue. There was also the discussion that
fuel would be placed in the combustion chamber also pre-igniting and causing
hard starts or stalls. Sold the bike and told the new owner of the issues. Never
heard back.
in any case when I got my new to me 2008 K1200GT I put an Odyssey in it and
and have had no issues.
Let us know if your #6 wire does the trick . . . as I had to call AAA twice for a
jump but after things cooled off the bike would start right up
Dan Finazzo
dfinazzo is offline
post #6 of 6 Old Dec 24th, 2014, 2:25 pm Thread Starter
My bike had an Odyssey battery in when I got the bike but I replaced it witha new Odyssey battery thinking the old one was not holding a charge. After putting in the new battery the hard starting problem was still present. I haven't had a problem since rewiring it, but the weather has been cold so I don't know if it will work when the weather gets hot. I will let you know...
Al Strickland
1967 Honda Cub
1972 Honda CB350
1979 Suzuki GS750E
2009 R1200GS
2013 K1600GTL
2009 K1300GT
I'm starting to consider a used 2009 K1300GT but I've got a couple of questions. Humbucker K1200/1300GT (The Next Generation) 15 May 2nd, 2012 6:05 pm
Starting issues... rowie K1200LT 4 Oct 17th, 2011 7:46 pm
Another 2005 LT starting problem gremlin Redleg_Rider K1200LT 8 Apr 28th, 2010 10:27 am
Home video of K1300GT acceleration Bruce_Yates K1200/1300GT (The Next Generation) 0 Sep 7th, 2009 7:16 pm
Another Trouble Starting Thread Ranger K1200LT 4 Apr 26th, 2009 1:32 pm
