Scala G4 Battery - BMW Luxury Touring Community
post #1 of 5 Old Oct 23rd, 2013, 4:17 pm Thread Starter
Scala G4 Battery
Apparently the battery has gone bad in my Scala G4. Scala's customer support told me I could send the unit in and for $50 they would replace the battery. If it does not fix the problem, they will refund $10 and send it back. I have opened the unit and the battery is easy to replace but I have not been able to locate a source for the battery and Scala refuses to sell me one. Does anyone have a suggestion where I can purchase a LIP451949-2HDJ?
kc5ero is offline
post #2 of 5 Old Oct 23rd, 2013, 8:49 pm
gbaltyn's Avatar
Re: Scala G4 Battery
Have you tried Battery Plus? They seem to have a food selection of odd ball stuff. Bought a $40 replacement battery for a Fluke meter and it works like a charm.
gbaltyn is offline
post #3 of 5 Old Oct 24th, 2013, 2:57 pm Thread Starter
I have tried Battery Plus with no luck. I also have e-mails out to several manufacturers in China. May need to buy 1000 and go into business supplying replacement G4 batteries.
kc5ero is offline
post #4 of 5 Old Oct 25th, 2013, 4:50 pm
You should be able to ID the battery from voltage, dimensions and connection locations using a std table of such. I doubt Scala gets a bespoke battery fabbed just for them.
The numbers you gave look like some Scala or makers part number, not a battery ID, to me. Is there any other identifying info on it?
racer7 is offline
post #5 of 5 Old Oct 30th, 2013, 6:48 pm Thread Starter
I have a a couple of batteries on order from China. I believe I will be able to connect them in parallel and have the same battery that was original. I will post again once the batteries arrive and I have put it all together.
kc5ero is offline
Battery question CMV K1200LT 9 Aug 25th, 2010 11:13 pm
My battery story. motorman587 K1200LT 3 Nov 26th, 2008 3:19 pm
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 10:11 am
