FRS with Voice system - BMW Luxury Touring Community
post #1 of 8 Old Jul 31st, 2013, 11:55 am Thread Starter
I have a 2005 LT, which has the Voice 1 system.
Does anyone have this system and are using FRS?
Should I have a PTT button on the handlebar? I have an old PPT button from my 2002 LT, but that was using the BC system. I am not sure if the switch is the same.
Help
ehaughn is offline
post #2 of 8 Old Jul 31st, 2013, 12:21 pm Thread Starter
Re: FRS with Voice system
I have found what I believe is the part number for the PPT button.
65 41 2 337 302
I did remove the handlebar cover, but I do not see any connectors for this.
ehaughn is offline
post #3 of 8 Old Jul 31st, 2013, 5:57 pm
Old Dawg
scottydawg's Avatar
65 41 2 337 302
I have the PTT for my 2005 and it is different from the PTT I had on my 2003. I don't think the bike was prewired but I will check and let you know.
Scott
Sacramento CA
HDDC Posse
''03 Ducati ST4S with ABS - '12 KTM 500EXC - '19 BMW GS/A
(Jessica Focker's) '15 BMW S1000RR - '17 KTM 350EXC-F - '09 Yamaha XT250
Some of the most asinine things people do are typically preceded by the two words "Watch this."
scottydawg is offline
post #4 of 8 Old Aug 1st, 2013, 8:34 am Thread Starter
Great, thank you.
If you have a part number and any pics would be helpful.
I would also be interested in where the connector plugs into. Under the handlebar cover or somewhere else.
ehaughn is offline
post #5 of 8 Old Aug 2nd, 2013, 12:46 am
Old Dawg
scottydawg's Avatar
I don't have any idea what the part number is, it has probably been 6 years since I bought it.
Here is a photo if that helps:
Scott
Sacramento CA
HDDC Posse
post #6 of 8 Old Aug 2nd, 2013, 7:30 am Thread Starter
Thanks.
Do you recall if there was a connector under the handlebar cover?
Or, did it run thru the handlebar cover and connect into VOICE system, under stingray?
ehaughn is offline
post #7 of 8 Old Aug 2nd, 2013, 10:04 am
Old Dawg
scottydawg's Avatar
I am pretty sure it had to be run to the VOICE system.
Scott
Sacramento CA
HDDC Posse
post #8 of 8 Old Aug 2nd, 2013, 11:17 pm Thread Starter
Thanks for your help.
Anyone have a part number for this?
ehaughn is offline
Problem with com system - welcome suggestion Alpac Intercom, CB, & 2-Way Radios 5 Aug 24th, 2012 9:01 am
2007 VOICE II problem Voyager Intercom, CB, & 2-Way Radios 18 May 30th, 2009 11:54 am
'05 Voice 1, Comm System Power Leads ehaughn K1200LT 3 Apr 1st, 2009 2:20 pm
Recommended CB Units other than BMWCB with Voice II Hanshi Intercom, CB, & 2-Way Radios 0 Mar 22nd, 2009 8:49 pm
voice 2 comm system question giokas Intercom, CB, & 2-Way Radios 1 Dec 3rd, 2006 6:51 pm
