Kenwood FRS/GMRS cable question - BMW Luxury Touring Community
post #1 of 7 Old Aug 6th, 2012, 10:39 pm Thread Starter
knoticalone's Avatar
For any of thos that have the cable to connect a Kenwood FRS to a Voice II comm system, is a a straight 3.5 mm to 3.5 mm and 2.5mm to 2.5 mm or are there jumpers within the cord? I was hoping to avoid the $ and use two seperate cords, a 3.5 stereo and a 2.5 stereo.
Ride Hard or Stay Home
2006 K1200LT
2006 Yamaha Venture (sold)
2006 Yamaha FJR (sold)
2008 Concours 14 (sold)
2005 R1200RT (sold)
2002 K1200LT E (sold)
knoticalone is offline
post #2 of 7 Old Aug 7th, 2012, 12:27 am
shoswell's Avatar
Re: Kenwood FRS/GMRS cable question
You are correct, they are simple 2.5 and 3.5 cords that you can normally pick up at Radio shack. If you look on line there will be a few sites that sell the kenwood cable. They are however "cloning" cables that are missing one connection.. I.e. do not work.
The 2.5 is a little tricky to find, however. I just purchased the connections and made my own...
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #3 of 7 Old Aug 7th, 2012, 7:46 am Thread Starter
Thank you. I was hoping this was the case but you never know with BMW if they will switch a few or add a jumper to make you pay the big bucks.
2006 K1200LT
2005 R1200RT (sold)
post #4 of 7 Old Aug 10th, 2012, 9:50 am Thread Starter
I found the 2.5 and 3.5 cables but after reading more on the forum there seems to be conflicting information. Most schematics show the speaker and mic terminals to be in a different position on the Kenwood end from the voice end. Here is one example
http://www.bmwlt.com/forums/attachme...achmentid=4423
This shows speaker + going from tip to sleeve and negative going from sleeve to tip..
Similar flip on the mic connections. Any input would be appreciated as I will be getting a Kenwood TK-3160 within a day or two.
2006 K1200LT
2005 R1200RT (sold)
post #5 of 7 Old Aug 13th, 2012, 1:16 am
shoswell's Avatar
That link did not work for me, but I had an OEM cord and simply did a continuity check. tip to tip, base to base... can;t remember if the mid was operational...
Hoss
shoswell is offline
post #6 of 7 Old Aug 13th, 2012, 8:58 am Thread Starter
Thanks again. The diagram in the link was showing tip to base and base to ring and a crossover wire between the speaker ground and mic pin. Bmw likes to make easy things complex sometimes.
I would just use the OEM cord but I am putting the radio a little ways from the intercom and that cable is just too short.
2006 K1200LT
2005 R1200RT (sold)
post #7 of 7 Old Aug 13th, 2012, 7:15 pm
shoswell's Avatar
Hell, that schem may have been mine. the cross over was needed to connect and I-com to the BC3 system (PS2 end)... The bikes were made with Kenwood in mind, so its a direct match...
Hoss
shoswell is offline
Cable Routing & Tupperware Removal Question Gizmo1137 K1200LT 1 Aug 30th, 2011 2:50 pm
kenwood cable cw1200lt K1200LT 2 Mar 3rd, 2011 7:45 pm
Valve Cover Bolt Torque R100RT JPSpen RT Series 3 May 3rd, 2010 12:41 pm
BMW CB Antenna Discovery -- Range-- GBaker Intercom, CB, & 2-Way Radios 3 Dec 6th, 2007 8:41 am
Strange Cruise Cable Question Dochatley K1200LT 4 Mar 1st, 2006 9:38 am
