Dongle for BMW Voice II for bluetooth?? - BMW Luxury Touring Community
post #1 of 4 Old Oct 14th, 2011, 5:41 pm Thread Starter
bowdon's Avatar
Question Dongle for BMW Voice II for bluetooth??
Hi guys;
I hear that there was a dongle which could be attached to the Voice II ( aux jack??) which would make the radio bluetooth and able to use a Sena SMH10 wirelessly for two helmets.
Is this a possibility? Who has done it and how??
Its an 2005 LT
Regards,
Bowdon
bowdon is offline
post #2 of 4 Old Oct 14th, 2011, 6:52 pm
Zeke's Avatar
Re: Dongle for BMW Voice II for bluetooth??
Chatter box has one that I use for my Zumo. Just plugs in the side,Pair it up with your headset and off you go. As far as i know it will only do one headset at a time. What I did is use a splitter for the zumo and then connected 2 of the dongles. But you still have to listen to one thing at a time. Both of you can only listen to same thing. But it does not interfere with your paired headsets. But that is for the Zumo.
Hope that helps.
Zeke
2002 K1200LT
2016 R1200RT
IBA # 41935
Zeke is offline
post #3 of 4 Old Oct 14th, 2011, 7:34 pm Thread Starter
bowdon's Avatar
Hope that helps.
Zeke
Zeke;
I have the Voice II and a Pilot 2820 (BT available) can we listen to the radio,GPS and Intercom? Is so this might be an option.
Would I connect the dongle to the Voice II aux output, and then pair the GPS and head sets??
Thanks in advance,
Bowdon
bowdon is offline
post #4 of 4 Old Oct 14th, 2011, 8:27 pm
Zeke's Avatar
Originally Posted by bowdon
Zeke;
Thanks in advance,
Bowdon
We have the interphone F4's.. Those are paired to eachother, then the headsets are paired to each dongle. So, we use the intercom as usual, and the rest of the GPS stuff is fed thru the dongle. But the dongle is plugged directly into the Zumo 550. We don't have the voice II. so I cant really speak on that system. But the way I use it i can hear her with the headsets, the GPS, and the XM thru the dongle, also the phone.
2002 K1200LT
2016 R1200RT
IBA # 41935
Zeke is offline
Question: VOICE II comm system - CB radio connector charleslaine Intercom, CB, & 2-Way Radios 3 Oct 5th, 2013 8:32 pm
Need help..upgrading VOICE to VOICE II Gabriel Intercom, CB, & 2-Way Radios 0 Feb 7th, 2009 12:02 pm
Help Pls - Valentine V1 into VOICE II relic K1200LT 11 Jul 19th, 2008 12:52 am
Hearing NAV III voice instructions via Bluetooth IndyNW GPS 2 Jan 13th, 2008 7:15 pm
