Intercom problems on 2009 LT - BMW Luxury Touring Community
post #1 of 2 Old Sep 12th, 2011, 6:11 pm Thread Starter
FLYARNG's Avatar
2009 K1200L with BMW V.O.I.C.E. II communication system and J&M headsets. Works sufficiently when first turned on but after about 10 minutes of riding I can scream at the top of my lungs and the intercom will not click on. Backseat works better and she normally has to initiate conservations for us to talk. Tried multiple changes to the settings and seems to be the same. Radio, GPS, CD and Aux with IPod all work fine in the headsets. Can switch the radio off and back on and sometimes it allows me to get a quick word in before intercom stops picking up again. Appreciate any ideas.
FLYARNG is offline
post #2 of 2 Old Sep 12th, 2011, 6:48 pm
tholdroaddog's Avatar
Re: Intercom problems on 2009 LT
A big problem with this system is the lower cable from the helmet to the bike. I have had to use electrical tape to keep the connection tight. I have also followed the manual to set up the system and have made sure the speed sensor was in the off position. Every time I have had issues with the intercom it has been the connection until the tape trick. It took the wife and I awhile to figure out it was the cable. I even had to replace a lower cable especially if you forget to disconnect and try and walk to the top case to get something. Good luck solving your issue.
L. Jay Keeran
K6LJK
2009 LT "USS Defiant"
tholdroaddog is offline
2009 Dates For STC and Fall Reunion jzeiler Rides, Rallies and Get-togethers 12 Dec 20th, 2008 2:51 pm
CCR 2009 location selection Randy Curve Cowboy Reunion 1 Dec 25th, 2006 7:28 pm
Intercom SQUEEEL and ABS Blinking! pieceofficer K1200LT 7 Aug 20th, 2006 10:27 pm
Push to talk on Voice II intercom? leeh Intercom, CB, & 2-Way Radios 5 Nov 7th, 2005 10:50 pm
