Bluetooth - am I doing something wrong - BMW Luxury Touring Community
post #1 of 5 Old Aug 3rd, 2011, 7:36 pm Thread Starter
I can't seem to resolve this and appreciate any suggestions.
If I pair my HTC Touch phone to my Zumo 665, I can place calls through the GPS no problem. If I walk away from the Zumo with the phone, it reconnects when I return and works correctly. I get the phone icon on the gps start page and can make and receive calls using the Zumo spkr and mic.
If I pair my Scala G4 to the Zumo I can make and receive calls through the headset. If I walk away from the bike and then return all appears to be working well. I get XM, MP3, spoken directions etc through the headset. But frequently if I attempt to answer or initiate a call , the other party can hear me but I get no audio in the headset. (if I am listening to music at the time, the music is muted as usual).
The only way I have found to correct this is to remove the G4 device from the bluetooth page on the Zumo, restart the Zumo and then have the Zumo rediscover the G4. I understand the the Zumo and the G4 are supposed to reconnect automatically once they have been paired. ( and it does seem to do so except for the phone )
Software for both the Zumo and G4 is up to date.
I understand the safety issues around using a phone while riding but at this time it is important that I can be reached from home.
Peter
TWheels is offline
post #2 of 5 Old Aug 3rd, 2011, 11:27 pm
garry_kramer's Avatar
Re: Bluetooth - am I doing something wrong
Peter
Hey Peter, I have my Samsung Wave paired to my Nav IV (Garmin 660) same as you. I have my G4 paired to the Nav IV. All is fine, my G4 connects and reconnects no problem. Not sure why yours doesn't.
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
garry_kramer is offline
post #3 of 5 Old Aug 4th, 2011, 8:04 am
CohesiveTechnology's Avatar
What you are describing is a software problem with Bluetooth profiles. Without getting too deeply technical I think the phone, which has several profiles, is taking over the "Hands Free Profile" from your headset.
http://en.wikipedia.org/wiki/Bluetooth_profile
The fix is tricky and dependent on the sequence in which you pair and the devices themselves.
Try pairing the headset first (I think you said that works) then the phone. Turn off the phone's "advanced audio profile" if you don't play music through it.
David Falkenstein
Cohesive Technology - seamless is everything
P: (603) 283-7624
CohesiveTechnology is offline
post #4 of 5 Old Aug 5th, 2011, 9:21 pm Thread Starter
Thanks for the input. The only profile listed on the phone now is "Hands Free". I removed the G4 and the phone devices from the Zumo bluetooth page and paired them anew. I paired the headset first and then the phone. All is working correctly now and I hope to test fully during a ride on Tuesday.
Cheers
Peter
TWheels is offline
post #5 of 5 Old Aug 8th, 2011, 6:55 pm Thread Starter
I carefully paired the G4 headset to the Zumo 665 and then the phone to the gps and went for a ride today. The initial results were encouraging but about an hour into the ride I was unable to make a call home. I turned off the GPS and then turned it back on. I was then able to make a call. A little while later, I tried making another call and it appeared to fail. But I have since learned that the call was actually made but I was unable to hear the ringing tone when the call was initiated and could not hear the other party answering. They could hear me.
I would like to at least isolate the problem in some way. I suspect that if I contact the phone, gps and g4 support people they will simply stand in a circle facing inwards and blame the person on their left.
Any help will be very appreciated.
Peter
TWheels is offline
Bluetooth that does work well with 2011 RT's Bluetooth jdsd-tourteam RT Series 3 May 30th, 2014 7:57 am
J&M Audio - Bluetooth headsets and hub - Any experience? blainem Intercom, CB, & 2-Way Radios 0 Jan 25th, 2011 6:44 pm
Vemar Jiano Bluetooth vs. Nolan N103 Jackson_HD Intercom, CB, & 2-Way Radios 2 Jul 3rd, 2010 11:27 pm
Hearing NAV III voice instructions via Bluetooth IndyNW GPS 2 Jan 13th, 2008 7:15 pm
2820 Bluetooth Functionality Question surfran GPS 5 May 2nd, 2007 3:23 pm
