Bluetooth request - BMW Luxury Touring Community
post #1 of 15 Old Aug 1st, 2011, 3:32 pm Thread Starter
garry_kramer's Avatar
Bluetooth request
Would it be too hard to have a device like this?
power - 12vdc input - no batteries needed - supplied from motorcycle
input - 3.5mm stereo male plug input (that could be hooked to the existing speakers on a motorcycle)
Output - Dual channel (for 2 riders at the same time) Bluetooth 2.0 or better with stereo output.
Pairing that does not forget what headset it is connected to.
Turned on when the 12vdc turns on so that it can be located remotely.
I think you would sell many of these to the motorcycle community.
I know of a few that could be sold right away including me.
Does anyone know of a such device??????
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
garry_kramer is offline
post #2 of 15 Old Aug 1st, 2011, 3:44 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Bluetooth request
All But the 12V from the bike, The Scala G4 does everything else plus you can have 4 units paired together. I've had mine turned on & plugged into my IPod on my old LT for over 12 hours, now I have it on my GTL (Hardwired to bikes speakers). I just charge it up over night for the next day. I'm not sure if you can use the G4 while it is being charged or not but I'll try that & if you can it would be easy to plug the charger into the bike.
Stevie Shreeve
katnapinn is offline
post #3 of 15 Old Aug 1st, 2011, 4:17 pm Thread Starter
I have the Scala G4's need the device for BT. Would prefer to not have a battery as they can't transmit when charging. What type of BT dongle are you using with the G4? I have a BTAV101 but it won't pair with the G4.
http://www.dinodirect.com/bluetooth-...r-btav101.html
This one looks like it may work. It still works while charging.
http://www.miccus.com/products/blubridge-mini-jack
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
post #4 of 15 Old Aug 1st, 2011, 5:10 pm
katnapinn's Avatar
I'm not using any dongles. I just plug it into the bike with the 3.5 mm cable that came with it & go. I have my phone paired to it plus my wives G4 so we can talk. When I ride with another Friend with a G4 we pair them also.
Stevie Shreeve
post #5 of 15 Old Aug 1st, 2011, 6:37 pm
Garry are you trying to set up something so your passenger can listen to the bike audio via BT at the same time you do? It's a great idea and I would want one.
Peter
TWheels is offline
post #6 of 15 Old Aug 1st, 2011, 8:42 pm Thread Starter
Peter
Yes, I am going to wire in a 3.5mm jack into the speaker wires then plug in a "Y" adapter then plug in 2 BT transmitters so that we can bypass the GTL limitation of only 1 non BT device to the bike. I'll need a 5vdc power supply to power the BT adapters also. Also when you use the BT on the GTL it completely shuts off the speakers. I think the BluBridge one might work. I have an email into them to see if 2 BT transmitters will work side by side.
I would like to hook the interface under the seat where the Alpine box is, so if anyone knows the speaker colour codes for the unit that would help. Otherwise I will have to take some tupperware off to get to the speaker wires at the speakers.
katnapinn, did you take any pictures of the wires and colours or note the colours when you did your mod?
Does anyone know the correct wiring of the 3.5mm plug? ie: left channel, right channel and common,
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
post #7 of 15 Old Aug 1st, 2011, 9:03 pm
Bighopper's Avatar
Gary,
The SENA units have a 3.5mm female plug on the mount that will do what you want + they can be charged while in use.
You can see the small access plug on the backside of the mount.
http://www.senabluetooth.com/product..._menu=overview
And SENA just updated there unit to enable firmware updates, (they just released an update to resolve some pairing issues with some smart phones & music issues.) I also understand that they are going to release an update so 4 units can talk the same as the G4.
BIGHOPPER (Phil)
BGB 602
2006 K1200LT Grey
1973 Norton Interstate
1965 Atlas 750
Bighopper is offline
post #8 of 15 Old Aug 1st, 2011, 9:20 pm Thread Starter
Originally Posted by Bighopper
Gary,
I want to mount the 2 BT units on the bike to transmit TO the G4. The G4 has the same wired input you are talking about. If I have a BT headset why would I want to plug a wire into it?
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
post #9 of 15 Old Aug 1st, 2011, 9:35 pm
Bighopper's Avatar
Pin Out http://pinouts.ru/connector/3_pin_st...onnector.shtml.
Sorry about the plug into the headset....i miss read your requirement.
As to the Blue tooth dongles you have in another post, I have the first one & it works but is hard to get to pair sometimes due to the small button & also not being able to charge while in use is also a draw back as you mention.
I also have had some issues when trying to get 2 BT devices connected located on the LT. Have found that you have to power on the devices, then one headset & let it connect then the 2 headset for it's BT devices.
As for 5V I am using one of those small cigarette device with USB that plugs into the a cigarette plug, I'm sure you could plug it apart & hard wire it without any problem.
http://reviews.cablesunlimited.com/p...to-5V-USB.html
Garry
BIGHOPPER (Phil)
BGB 602
2006 K1200LT Grey
1965 Atlas 750
post #10 of 15 Old Aug 2nd, 2011, 1:54 am Thread Starter
Thanks for the plug link.The second BT dongle (BluBridge) will work when plugged into power.
Got an email back from BluBridge people, they say that 2 units will work off the same input to 2 different headsets. Asked if the will turn on by themselves when power is added to them, waiting for an answer on that one.
I have one of these in my top box already with 2 USB outlets. For $15 I think I can tear it apart and separate the USB side to make it smaller for the power.
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
post #11 of 15 Old Aug 2nd, 2011, 6:31 am
katnapinn's Avatar
Garry
Garry no pics but here is the color code.
Left speaker
yellow / Black stripe +
Yellow / red stripe -
Right speaker
Blue / Black stripe + (mine was solid blue no stripe but dealer manual shows a stripe)
Blue / red stripe -
Stevie Shreeve
post #12 of 15 Old Aug 2nd, 2011, 7:21 am Thread Starter
Left speaker
Right speaker
Blue / red stripe -
Thanks Steve, Any chance of showing the manual on the radio wiring?
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
post #13 of 15 Old Aug 2nd, 2011, 5:20 pm
WildBil's Avatar
Garry
3 - Ground
2 - Right
1 - Left
Also known as:
3 - Sleeve
2 - Ring
1 - Tim
wild bil
07 K1200LT Biarritz Blau
WildBil is offline
post #14 of 15 Old Aug 3rd, 2011, 10:17 am
calvarez's Avatar
Doesn't everyone own a phone with Bluetooth and media playback these days? Why are we still talking about "bike audio" in 2011??
Carlos Alvarez
Gilbert, AZ
2000 K1200LT-I
calvarez is offline
post #15 of 15 Old Aug 19th, 2011, 7:47 am Thread Starter
Smile Re: Bluetooth request working
All done installing the BT to the speakers. There are a couple limitations. The music out the BT doggle is delayed about 3/4 sec. which is no real problem, just turn down the radio and turn up the headset. The other is a limitation of the G4. I can only attach 1 BT at a time to the headset. each work great indipendantley but not together. this means I can attache the GPS or the radio, but not both. This is OK for the passenger as they only need the radio, but not so much for the rider. So what I did is order a BT receiver for the BT transmitter and will plug the receiver into the hardwire port of the G4 and everything should be OK.
BT transmitter: http://cgi.ebay.ca/ws/eBayISAPI.dll?...84.m1439.l2649
BT receiver : http://cgi.ebay.ca/ws/eBayISAPI.dll?...84.m1439.l2649
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
Bluetooth that does work well with 2011 RT's Bluetooth jdsd-tourteam RT Series 3 May 30th, 2014 7:57 am
J&M Audio - Bluetooth headsets and hub - Any experience? blainem Intercom, CB, & 2-Way Radios 0 Jan 25th, 2011 6:44 pm
Vemar Jiano Bluetooth vs. Nolan N103 Jackson_HD Intercom, CB, & 2-Way Radios 2 Jul 3rd, 2010 11:27 pm
Hearing NAV III voice instructions via Bluetooth IndyNW GPS 2 Jan 13th, 2008 7:15 pm
2820 Bluetooth Functionality Question surfran GPS 5 May 2nd, 2007 3:23 pm
